[REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
- pgielen
- Domoticz version: 2020.2
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Would it not be simpler to control Tradfri lights without the gateway, just using a Raspberry Pi and an XBee board?
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
Hello, someone can helpme plz?
I run
else if I run
How I can proceed?
I run
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py 192.168.0.201 PSW
usage: configure.py [-h] {config,service} ...
configure.py: error: argument command: invalid choice: '192.168.0.201' (choose from 'config', 'service')
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py config 192.168.0.201 PSW
Error: Unable to import pytradfri. Please check your installation!
moroen
You're missing the pytradfri library. If you've installed it with pip3, make sure that you have only one python3 interpreter installed...Alessio78 wrote: Tuesday 19 March 2019 20:29 Hello, someone can helpme plz?
I runelse if I runCode: Select all
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py 192.168.0.201 PSW usage: configure.py [-h] {config,service} ... configure.py: error: argument command: invalid choice: '192.168.0.201' (choose from 'config', 'service')How I can proceed?Code: Select all
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py config 192.168.0.201 PSW Error: Unable to import pytradfri. Please check your installation!
Regards,
M
schulpr
I have the same error "configure.py: error: argument command: invalid choice: '192.168.2.1' (choose from 'config', 'service')". How can I check if there are more interpreters installed? (And remove them.)
I build Domoticzfrom scratch and right after this I tried to install the Tradfri plugin.
Thanks for the help!
Kind regards, Rob
Kind regards, Rob
moroen
Please check the command, the syntax has changed in the latest version:schulpr wrote: Friday 22 March 2019 17:35 Hi,
Kind regards, Rob
$ ./configure.py config 192.168.2.1 PSK
M
schulpr
Hi M,
Thanks for your fast response! I used this description:
12. ./configure.py --debug <IP adres tradfri hub> <security KEY on rear of hub>
13. python3 tradfri.tac
14. ./configure.py –-skip-config –-create-service
15. sudo cp ikea-tradfri.service /etc/systemd/system
16. sudo systemctl daemon-reload
Is step 14 also changed? Edit: Yes, ./configure.py service create
Kind regards, Rob
Kind regards, Rob
moroen
Yes, it is... Please check the updated readme, but in short:schulpr wrote: Friday 22 March 2019 18:40 Hi M,
Kind regards, Rob
12. ./configure.py config <IP address tradfri hub> <security KEY on rear of hub>
14. ./configure.py service create
M
schulpr
Hi M,
Thanks again. I was unaware of a description and just followed the explanation in this thread. Sorry for this.
Rgards, Rob
Rgards, Rob
moroen
No problem, hopefully you've gotten it to work?schulpr wrote: Friday 22 March 2019 19:40 Hi M,
Rgards, Rob
Regards,
M
schulpr
Yes, it's fine now!
I have the same problem. I tried these suggestions already:moroen wrote: Thursday 07 February 2019 12:49fotogen wrote: Tuesday 05 February 2019 1:04 Hi
Kind of desperate since im stuck in one of the first steps![]()
I could read that another user had the same problem but no solution. When running the ./configure.py i get error message that there is no module named "pytradfri". But i can clearly see that it is there when cheching pip3 list. I have been uninstalling/re-installing python and the different scripts. Do any one have any clue? Please make my day![]()
$ /usr/bin/env python3 -m pip list
returns among the needed modules:
cryptography (0.6.1)
pytradfri (6.0.1)
Twisted (18.9.0)
python3 configure.py config 192.168.1.x xxxx
Running on a standard raspbian system.
Another error I get, which is probably caused by the same euh, cause: when I start tradfri.tac, it cannot find the cryptography module:
python3 tradfri.tac
'No module named 'cryptography.x509''
When I reinstall pytradfri, I get the following SyntaxError, even thought pip3 afterwards claims it is installed succesfully:
Installing collected packages: pytradfri
Found existing installation: pytradfri 6.0.1
Uninstalling pytradfri:
Successfully uninstalled pytradfri
Running setup.py install for pytradfri
/usr/lib/python3.4/distutils/dist.py:260: UserWarning: Unknown distribution option: 'python_requires'
warnings.warn(msg)
File "/usr/local/lib/python3.4/dist-packages/pytradfri/api/aiocoap_api.py", line 67
async def _get_protocol(self):
SyntaxError: invalid syntax
Successfully installed pytradfri
Cleaning up...
Is there anything else I can check?
moroen
@axello2,
I reread your output a couple of times before I spotted this:
I would recommend upgrading to latest 3.6.x (3.6.8) or 3.7.x (3.7.3) but any version from 3.5.3 and higher should work!
Regards,
M
You need at least python 3.5.3 in order to use pytradfri and thus the Tradfri-plugin...axello2 wrote: Thursday 28 March 2019 17:20Code: Select all
Regards,
M
Oh flup, I remember reading that somewhere in the beginning, so I apt upgraded everything, but that was not good enough. I guess I have to update my linux distribution as well. Pity, that's for another time.
Thanks for your swift answer!
Axel
Axel
jojo26
Hi, I am pretty new to all of this but when I put in all the commands I got finally no errors. But when I submit the Tradfri to my Domoticz Hardware i do not get the option of an Identity or to fill in the key. What do i do wrong? Also I get the logfile saying "failed to connect to IKEA tradfri COAP-adapter! Status: 111 "
In python i have this
"ikea-tradfri.service created:
[Unit]
Description=IKEA Tradfri COAP-adapter
[Service]
Type=simple
ExecStart=/usr/local/bin/twistd --nodaemon \
--rundir=/home/pi/domoticz/plugins/IKEA-Tradfri \
--pidfile=/home/pi/domoticz/plugins/IKEA-Tradfri/twistd.pid \
--python=/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri.tac
User=pi
Group=pi
Restart=always
[Install]
WantedBy=multi-user.target"
Where do I go wrong?
Jojo
[Unit]
[Service]
Type=simple
User=pi
Group=pi
Restart=always
[Install]
Jojo
Hi Moroen,
Thanks for your help. After updating to Stretch and re-installing all the dependencies again, I got it working. Apart from the update polling, but that's a known issue I guess.
issue: When I switch the Trådfri bulbs On with Domotics, the status given to the event system is correct, but when I switch On with the Trådfri remote or the Trådfri app it is still reported as Off, and vice-versa]
Cheers,
Axel
Cheers,
Axel
schulpr
Good morning,
Unfortunately I had do re-install my Domoticz from scratch. I have all the python plug-ins working again except the Tradfri. I get this message:
I removed python v2.7, re-installed 3.5.3. I'm on the latest beta of Domoticz. Does anyone has an idea what goes wrong?
Thanks for the suggestions!
Kind regards, Rob
2019-03-31 08:13:32.339 Error: (IKEA-Tradfri) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/IKEA-Tradfri/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-03-31 08:13:32.339 Error: (Tradfri) Module Import failed, exception: 'ImportError'
2019-03-31 08:13:32.339 Error: (Tradfri) Module Import failed: ' Name: colors'
2019-03-31 08:13:32.339 Error: (Tradfri) Error Line details not available.
Kind regards, Rob
moroen
That's my fault... I've been doing some restructuring in preparation for a coming major change (ditching coap-client), and managed to mess up the master branch. If you pull the latest commit, it should be fixed now... Sorry for the inconvenience!schulpr wrote: Sunday 31 March 2019 8:25 Good morning,
I removed python v2.7, re-installed 3.5.3. I'm on the latest beta of Domoticz. Does anyone has an idea what goes wrong?Code: Select all
2019-03-31 08:13:32.339 Error: (IKEA-Tradfri) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/IKEA-Tradfri/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'. 2019-03-31 08:13:32.339 Error: (Tradfri) Module Import failed, exception: 'ImportError' 2019-03-31 08:13:32.339 Error: (Tradfri) Module Import failed: ' Name: colors' 2019-03-31 08:13:32.339 Error: (Tradfri) Error Line details not available.
Kind regards, Rob
Regards,
M
schulpr
Hi M,
No problem, it's a hobby
git pull didn't do the trick. I removed everything and started all over. When I install " pip3 install service-identity" I get this error:
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-ksul_5ak/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-s7qsqisb-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-ksul_5ak/cryptography/
When I continue the ressult is the same.
Kind regards, Rob
Kind regards, Rob
moroen
This isn't a tradfri issue, but I would guess you're lacking the libssl-dev package?schulpr wrote: Sunday 31 March 2019 20:11 Hi M,
No problem, it's a hobby.
Kind regards, Rob
Regards,
M
schulpr
Hello M,
Your suggestion brought me a bit further. Next error:
pi@raspberrypi3:~/domoticz/plugins/IKEA-Tradfri $ python3 tradfri.tac
IKEA-tradfri COAP-adaptor version 0.8.7 started (command line)!
Couldn't listen on any
[Errno 98] Address already in use.
Even killed the complete Domoticz directory and started all over.
Kind regards, Rob
Kind regards, Rob
Users browsing this forum: gizmocuz and 1 guest
