I tried to remoce a device into zwave configuration.
First with Domoticz interface
Second with zwave interface
in both cases, the resutl is still the same : the device is still here
What is the solution in order to remoce a device into zwave please ?
Best Regards.
PS : I would like to remove device in order to reload this device FGR223 with the right parameters. If you have solution in order to refresh parameters loaded with the configuration, it will be ok for me.
Remove Device Zwave
Re: Remove Device Zwave
Hi..you can do it with Zensys tools.
http://docs.incontrolha.com/home/remove-a-failed-device
Success,Hans
Success,Hans
