Zigate Plugin release 4.1.0 Topic is solved
pipiche
Post by pipiche »
Release 4.1.0 will be on stable branch soon.
Please take the time to read this document which introduce it.
https://github.com/pipiche38/Domoticz-Z ... ase-4.1.md
ATTENTION, you need to plan a MIGRATION step (moving files from one place to an other)
In case of trouble, please use the following:
1. Wiki pages (https://github.com/sasu-drooz/Domoticz-Zigate/wiki)
2. This forum
Domoticz version: 2026.3
Re: Zigate Plugin release 4.1.0
pfloryann
Domoticz version: 2026.2
Post by pfloryann »
Hi i've updated plugin and now i have:
"git status
On branch pre-4.1
Your branch is up-to-date with 'origin/pre-4.1'"
This is stable 4.1 stable version?
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Post by pipiche »
No pre-4.1 was just a branch in preparation of 4.1. That one is discontinued
You need to switch back to stable branch by git checkout stable
pfloryann
Post by pfloryann »
i have tried and i have this error
git checkout stable
error: Your local changes to the following files would be overwritten by checkout:
Conf/DeviceConf.txt
Conf/PluginConf.txt
Please commit your changes or stash them before you switch branches.
Aborting
pipiche
Post by pipiche »
Cela indique que tu as modifiés ces fichiers qui sont sous control de version
Devrait t'aider
git reset --hard
git checkout stable
Tu peux également copier ton fichier PluginConf.txt en PluginConf-xx.txt (avec xx le HardwareID du plugin), cela t'evitera par la suite d'avoir ce soucis.
pfloryann
Post by pfloryann »
That worked and is done
"git status
On branch stable
Your branch is up-to-date with 'origin/stable'."
Thank you Pipiche!
jjnj
Post by jjnj »
How many devices can connect to zigate?
The maximum amount of devices.
Verstuurd vanaf mijn LM-V405 met Tapatalk
fredo
Post by fredo »
jjnj wrote: Wednesday 03 April 2019 5:39 How many devices can connect to zigate?
This has nothing to do with the plugin. The limitation is on the hardware itself.
https://zigate.fr/2019/02/11/maj-firmwa ... sion-3-0f/
70 devices in total where 40 in direct pairing
If you want more, please use : https://github.com/fairecasoimeme/ZiGate
pipiche
Post by pipiche »
That is correct 70 devices in total with 40 in direct. If you want to know more and especially what 40 in direct versus 70 , please contact the Zigate vendor, as from a plugin standpoint I don't really care ...
mpx2
Domoticz version: 4.10717
Post by mpx2 »
There's this radio analysis feature.
https://github.com/pipiche38/Domoticz-Z ... -Status.md
How can I run it?
pipiche
Post by pipiche »
mpx2 wrote: Tuesday 16 April 2019 23:35 There's this radio analysis feature.
How can I run it?
You need to set networkScan 240 in the Conf/PluginConf.txt file so the network Interference report will be trigger 4 minutes after plugin start
for more information: https://github.com/pipiche38/Domoticz-Z ... onf.txt.md
mpx2
Post by mpx2 »
pipiche wrote: Wednesday 17 April 2019 9:32
How can I run it?
My PluginConf.txt is now
'channel':'11,15,19,20,25,26',
'vibrationAqarasensitivity':'medium',
'resetMotiondelay':'30',
'enablegroupmanagement':'0',
'logLQI':'0',
'logFORMAT':'0',
'networkScan':'240'
but I cannot see any reports in "Zigate Status 8" or "Zigate Notifications 8".
pipiche
Post by pipiche »
What about Logs ?
mpx2
Post by mpx2 »
pipiche wrote: Wednesday 17 April 2019 11:18 What about Logs ?
Domoticz log:
2019-04-17 13:19:31.062 (ZiGate) NwkMgtUpdReq - scan channel(s): 6188800 duration: 05 count: 1 >0000061888000501010000<
pipiche
Post by pipiche »
At least the line you show, tell that the plugin has requested the Scan which is good
mpx2
Post by mpx2 »
pipiche wrote: Wednesday 17 April 2019 13:21 At least the line you show, tell that the plugin has requested the Scan which is good
After setting software reset to true in Zigate settings I notices this in the log.
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzVersion: 4.9700
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzHash: xxxxxxxxx
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzBuildTime: 2018-06-23 17:24:51
2019-04-17 14:26:05.060 Status: (ZiGate) The current Domoticz version doesn't support the plugin to enable a number of features
2019-04-17 14:26:05.060 Status: (ZiGate) switching to Domoticz V 4.10355 and above would help
pipiche
Post by pipiche »
You need a Domoticz Version higher than 4.10355 in order to have a number of features enabled which is mainly the regular update of Last Seen field in domoticz
