Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
Interesting @salvacalatyud - can you 'sync my devices' and try again?
Madgeni wrote:Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
o_0
Can you try again? Have you added any new devices? Controlicz is working, and can't see any errors for you in the logs
ah - if this was open/close - it should be ok now. can you try percentages also?
Quite a time ago I registered.
Got Controlicz running, still see my devices in Google Home.
Would like to subscribe but I can't login with my gmail address. User unknown.
Can anyone confirm that they have Controlicz working properly with a Google Home Routine?
I have setup a Google Home Routine to activate a Domoticz Scene via Controlicz. This works as expected but each time I voice activate the routine, I get a voice response from Google Home saying "Sorry, I can't reach the Controlicz, please try again later". This response occurs even though there is clearly a connection to Controlicz since the Scene is activated properly. I tried re-linking my Controlicz account in Google Home but it had no effect.
Is anyone else seeing this issue or found a way to disable this voice response?
jimm2 wrote: Wednesday 10 April 2019 17:51
Hi -
i've just tested a Scene in a routine - Activate <SceneName> works fine
Hi -
[/quote]
Thanks. Then is there anyway to troubleshoot why I'm getting the Controlicz connection error message when there is clearly a connection established between Controlicz and Google Home?
Had a few issues with my Harmony Hub but they're solved now.
When I'm asking GH to turn on the lights, it's not only turning the lights on but also My TV, Radio, Netflix, Spotify, Spotify on TV, Youtube and my mediaplayer.
If I tel GH to turn off my lights, she sais: OK, I'm turning off 13 (?) lights.
Is this something on your side or mine and can you help my fix this?
