Logitech Media Server (LMS) dzVents adapter
Re: Logitech Media Server (LMS) dzVents adapter
stephanvdplas wrote: Saturday 16 March 2019 12:04 Hello, I use the LMS DZVents adapter with much pleasure. I've only got a small feature request.
Is it possible to expand this function with VolumeUp and VolumeDown?
I do not own an LMS so can you please test this updated device adapter (see below) and report back ?
To do this:
from your domoticz dir
cp  dzVents\runtime\device-adapters\logitech_media_server_device.lua  dzVents\runtime\device-adapters\logitech_media_server_device.bak
and after that replace dzVents\runtime\device-adapters\logitech_media_server_device.lua with this updated version
test the commands
domoticz.devices(<name>).volumeUp()
domoticz.devices(<name>).volumeDown()
Updated adapter code
local TimedCommand = require('TimedCommand')
	baseType = 'device',
	name = 'Logitech Media Server device',
	matches = function (device, adapterManager)
		local res = (device.hardwareType == 'Logitech Media Server')
		if (not res) then
			adapterManager.addDummyMethod(device, 'switchOff')
			adapterManager.addDummyMethod(device, 'stop')
			adapterManager.addDummyMethod(device, 'play')
			adapterManager.addDummyMethod(device, 'pause')
			adapterManager.addDummyMethod(device, 'setVolume')
			adapterManager.addDummyMethod(device, 'startPlaylist')
            adapterManager.addDummyMethod(device, 'playFavorites')
            adapterManager.addDummyMethod(device, 'volumeUp')
            adapterManager.addDummyMethod(device, 'volumeDown')
		return res
	end,
	process = function (device, data, domoticz, utils, adapterManager)
		device.playlistID = data.data.levelVal
		function device.switchOff()
			return TimedCommand(domoticz, device.name, 'Off', 'device', device.state)
		function device.stop()
			return TimedCommand(domoticz, device.name, 'Stop', 'device', device.state)
		function device.play()
			return TimedCommand(domoticz, device.name, 'Play', 'device', device.state)
		function device.pause()
			return TimedCommand(domoticz, device.name, 'Pause', 'device', device.state)
		function device.setVolume(value)
            value = tonumber(value)
			if (value < 0 or value > 100) then
				utils.log('Volume must be between 0 and 100. Value = ' .. tostring(value), utils.LOG_ERROR)
				return TimedCommand(domoticz, device.name, 'Set Volume ' .. tostring(value), 'device', device.state)
		function device.startPlaylist(name)
			return TimedCommand(domoticz, device.name, 'Play Playlist ' .. tostring(name), 'updatedevice', device.state)
		function device.playFavorites(position)
            position = tonumber(position)
			if (position == nil) then
				position = 0
			return TimedCommand(domoticz, device.name, 'Play Favorites ' .. tostring(position), 'updatedevice', device.state)
        function device.volumeDown()
            local url = domoticz.settings['Domoticz url'] ..  "/json.htm?type=command&param=lmsmediacommand&action=VolumeDown" ..
                       '&idx=' .. device.id
            return domoticz.openURL(url)
        function device.volumeUp()
            local url = domoticz.settings['Domoticz url'] ..  "/json.htm?type=command&param=lmsmediacommand&action=VolumeUp" ..
GieBek
Domoticz version: 4.10717
Post by GieBek »
Hello.
Sorry for my English
VolumeUp and VolumeDown works great.
Please help, I have a problem with running LMS on raspberry pi zero with logitech squeezebox from max2play.
Sometimes it starts up and sometimes not, I do not know what it depends on.
I would like a script that will give me a radio after activating the PIR sensor, the hour defines the volume.
I tried it like the code below but sometimes it works and sometimes it does not. How to add volume: SetVolume will not turn on the radio, I do not understand why.
I know the script is from something else but I tried. :oops:
What is the better code is very please.
		devices = {'PIR Kuchnia - Sensor'}, -- Change out PIR
   execute = function(dz, PIR)
        local Radio = dz.devices('Kuchnia LMS') -- Change out light
        local dimTimeTable  = { --  [   'timeSlot'   ]  = dimValue
                                    ['at 00:01-09:00']  = 5,
                                    ['at 09:01-12:00']  = 30,
                                    ['at 12:01-22:00']  = 25,
                                    ['at 22:01-24:00']  = 10,
        if PIR.state ~= 'On' then
            --Radio.switchOff().afterMin(1)
            Radio.stop().afterMin(1)
           -- dz.log(Radio.name .. ' switched Off')
            for timeSlot, dimValue in pairs (dimTimeTable) do
               if dz.time.matchesRule(timeSlot) then
                    --if Radio.state ~= 'Off' or Radio.state ~= 'stop' then
            Radio.SetVolume(20)
            Radio.Play()
                    --dz.log(Radio.name .. ' switched On (Volumelevel: ' .. dimValue .. ')')
                    return false
Earlier I had such a code, but it was the same problem as delete setVolume and the radio started up.
		devices = {
        if device.state == 'On' and domoticz.devices('Kuchnia LMS').state == 'Off' and domoticz.time.hour >= 9 and domoticz.time.hour <= 12  then
	        domoticz.devices('Kuchnia LMS').switchOn()
	        domoticz.devices('Kuchnia LMS').setVolume(30)
	        domoticz.devices('Kuchnia LMS').play()
        elseif
            device.state == 'On' and domoticz.devices('Kuchnia LMS').state == 'Off' and domoticz.time.hour >= 13 and domoticz.time.hour <= 15  then
	            domoticz.devices('Kuchnia LMS').setVolume(20)
        elseif
            device.state == 'On' and domoticz.devices('Kuchnia LMS').state == 'Off' and domoticz.time.hour >= 16 and domoticz.time.hour <= 22  then
        elseif
            device.state == 'On' and domoticz.devices('Kuchnia LMS').state == 'Off' and domoticz.time.hour >= 23 and domoticz.time.hour <= 8   then
	            domoticz.devices('Kuchnia LMS').setVolume(15)
	            domoticz.devices('Kuchnia LMS').switchOff().afterSec(300)
GieBek wrote: Wednesday 27 March 2019 23:35 I have a problem with running LMS on raspberry pi zero with logitech squeezebox from max2play.
Not sure I completely understand but can you try this and report your findings ?
        dz.log(Radio.name .. ' state: ' .. Radio.state .. '; level: ' .. Radio.level )
        local dimTimeTable  = { --  [   'timeSlot'   ]  = volume
                                    ['at 00:00-09:00']  = 5,
                                    ['at 22:01-23:59']  = 10,
            for timeSlot, volume in pairs (dimTimeTable) do
                    if Radio.state ~= 'Off' and Radio.state ~= 'stop' then
                        Radio.SetVolume(volume)
                        Radio.Play()
                        dz.log(Radio.name .. ' switched On (Volumelevel: ' .. volume .. ')' )
                        return false
GieBek
Post by GieBek »
Thanks for answering, I know my English is very weak. :cry:
If:
there is an error
2019-03-28 01:32:36.833 Status: dzVents: Error (2.4.15): ...ipts/dzVents/generated_scripts/Radio test v5 DzVents.lua:8: attempt to concatenate field 'level' (a nil value)
But it does not matter.
        --dz.log(Radio.name .. ' state: ' .. Radio.state .. '; level: ' .. Radio.level )
                                    ['at 00:00-09:00']  = 9,
               		Radio.setVolume(volume)
                        Radio.play()
                        return false
When setVolume(volume) is over Radio.play() the music starts to play the volume does not change.
When Radio.play() is over setVolume(volume) the volume changes, music does not play. :shock:
I thought maybe there must be a delay. AND YES
                        Radio.play().afterSec(5)
                        return false
The code above works properly. :) One second also works.
I will test it a few days and I will answer if it works 100%
Thank you very much for your help. Greetings.
stephanvdplas
Domoticz version: 2023.1
Post by stephanvdplas »
test the commands
Hello Waaren,
This works perfectly. Thank you for implementing this. Only 1 thing: It does change the volume (up or down) with step 2. It would be great if the step could be set by parameter of the function (e.g. domoticz.devices('kitchen').volumeDown(10) would lower the volume with 10)
Regards,
Stephan
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
stephanvdplas wrote: Tuesday 07 May 2019 10:20 It would be great if the step could be set by parameter of the function (e.g. domoticz.devices('kitchen').volumeDown(10) would lower the volume with 10)
I can try but don't have an LMS so if you can you send me the result of a
domoticz.devices('kitchen').dump()
I might have enough information to work with.
GieBek
Post by GieBek »
Hello, although there is movement on the watch, the LMS switches off after 3 minutes.
What can be changed for the Radio to play when there is movement in the room.
		devices = {'Kuchnia - Sensor'}, -- Change out PIR
                                --  ['at 00:00-08:00']  = 15,
                                    ['at 08:01-09:59']  = 18,
                                    ['at 10:00-21:00']  = 24,
                                    ['at 21:01-23:59']  = 13,
            Radio.switchOff().afterMin(3)
               if dz.time.matchesRule(timeSlot) and Radio.state == 'Off' then
                        Radio.setVolume(volume-12)
                        Radio.play().afterSec(1)
                        Radio.setVolume(volume-10).afterSec(2)
                        Radio.setVolume(volume-8).afterSec(4)
                        Radio.setVolume(volume-6).afterSec(6)
                        Radio.setVolume(volume-4).afterSec(8)
                        Radio.setVolume(volume-2).afterSec(10)
                        Radio.setVolume(volume-1).afterSec(11)
                        Radio.setVolume(volume).afterSec(12)
                        --dz.log(Radio.name .. ' switched On (Volumelevel: ' .. volume .. ')' )
                        return false
GieBek wrote: Tuesday 04 June 2019 12:46 Hello, although there is movement on the watch, the LMS switches off after 3 minutes.
Try with inserting
Radio.cancelQueuedCommands()
at line 17
