Detailed temperature data for more than 24 hours
Metlik
Post by Metlik »
Is it possible to see the detailed temperature graph for more than last 24 hours? Temperature graph for last month is not so precise... :(
Thank you!
Re: Detailed temperature data for more than 24 hours
Metlik wrote: Tuesday 12 March 2019 20:16 Is it possible to see the detailed temperature graph for more than last 24 hours? Temperature graph for last month is not so precise... :(
Thank you!
Use [setup] [system] [Log History] [Short Log Sensors] to choose 1 - 7 days worth of data in short term log.
Metlik
Post by Metlik »
Thank you!
kimot
Domoticz version: v3.8153
Post by kimot »
You can setup Domoticz to send data to InluxDB.
So you have got all detail data from your history.
Visualisation with Grafana, for example.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
Prutsium
Post by Prutsium »
Example of Domotixz > Influx > Grafana:
https://snapshot.raintank.io/dashboard/ ... fysUe9jQHX
In this setup various devices put their data directly into Influx and a few devices are pushed by Domoticz into Influx.
At the end visualization is made by Grafana.
