Zigate Plugin release 4.1.0 Topic is solved
Release 4.1.0 will be on stable branch soon.
Please take the time to read this document which introduce it.
https://github.com/pipiche38/Domoticz-Z ... ase-4.1.md
ATTENTION, you need to plan a MIGRATION step (moving files from one place to an other)
In case of trouble, please use the following:
1. Wiki pages (https://github.com/sasu-drooz/Domoticz-Zigate/wiki)
2. This forum
2. This forum
- Domoticz version: 2026.3
Re: Zigate Plugin release 4.1.0
pfloryann
Hi i've updated plugin and now i have:
"git status
On branch pre-4.1
Your branch is up-to-date with 'origin/pre-4.1'"
This is stable 4.1 stable version?
"git status
On branch pre-4.1
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
No pre-4.1 was just a branch in preparation of 4.1. That one is discontinued
You need to switch back to stable branch by git checkout stable
pfloryann
i have tried and i have this error
git checkout stable
error: Your local changes to the following files would be overwritten by checkout:
Conf/DeviceConf.txt
Conf/PluginConf.txt
Please commit your changes or stash them before you switch branches.
Aborting
git checkout stable
Conf/DeviceConf.txt
Conf/PluginConf.txt
Aborting
Cela indique que tu as modifiés ces fichiers qui sont sous control de version
Devrait t'aider
Tu peux également copier ton fichier PluginConf.txt en PluginConf-xx.txt (avec xx le HardwareID du plugin), cela t'evitera par la suite d'avoir ce soucis.
Devrait t'aider
git reset --hard
git checkout stable-
pfloryann
That worked and is done
"git status
On branch stable
Your branch is up-to-date with 'origin/stable'."
Thank you Pipiche!
"git status
On branch stable
Thank you Pipiche!
jjnj
How many devices can connect to zigate?
The maximum amount of devices.
Verstuurd vanaf mijn LM-V405 met Tapatalk
fredo
This has nothing to do with the plugin. The limitation is on the hardware itself.jjnj wrote: Wednesday 03 April 2019 5:39 How many devices can connect to zigate?
https://zigate.fr/2019/02/11/maj-firmwa ... sion-3-0f/
70 devices in total where 40 in direct pairing
If you want more, please use : https://github.com/fairecasoimeme/ZiGate
That is correct 70 devices in total with 40 in direct. If you want to know more and especially what 40 in direct versus 70 , please contact the Zigate vendor, as from a plugin standpoint I don't really care ...
mpx2
- Domoticz version: 4.10717
There's this radio analysis feature.
https://github.com/pipiche38/Domoticz-Z ... -Status.md
How can I run it?
How can I run it?
You need to set networkScan 240 in the Conf/PluginConf.txt file so the network Interference report will be trigger 4 minutes after plugin startmpx2 wrote: Tuesday 16 April 2019 23:35 There's this radio analysis feature.
How can I run it?
for more information: https://github.com/pipiche38/Domoticz-Z ... onf.txt.md
mpx2
My PluginConf.txt is nowpipiche wrote: Wednesday 17 April 2019 9:32You need to set networkScan 240 in the Conf/PluginConf.txt file so the network Interference report will be trigger 4 minutes after plugin startmpx2 wrote: Tuesday 16 April 2019 23:35 There's this radio analysis feature.
How can I run it?
'channel':'11,15,19,20,25,26',
'vibrationAqarasensitivity':'medium',
'resetMotiondelay':'30',
'enablegroupmanagement':'0',
'logLQI':'0',
'logFORMAT':'0',
'networkScan':'240'
What about Logs ?
mpx2
Domoticz log:
2019-04-17 13:19:31.062 (ZiGate) NwkMgtUpdReq - scan channel(s): 6188800 duration: 05 count: 1 >0000061888000501010000<Re: Zigate Plugin release 4.1.0
At least the line you show, tell that the plugin has requested the Scan which is good
mpx2
After setting software reset to true in Zigate settings I notices this in the log.pipiche wrote: Wednesday 17 April 2019 13:21 At least the line you show, tell that the plugin has requested the Scan which is good
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzVersion: 4.9700
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzHash: xxxxxxxxx
2019-04-17 14:26:05.060 Status: (ZiGate) DomoticzBuildTime: 2018-06-23 17:24:51
2019-04-17 14:26:05.060 Status: (ZiGate) The current Domoticz version doesn't support the plugin to enable a number of features
2019-04-17 14:26:05.060 Status: (ZiGate) switching to Domoticz V 4.10355 and above would helpRe: Zigate Plugin release 4.1.0
You need a Domoticz Version higher than 4.10355 in order to have a number of features enabled which is mainly the regular update of Last Seen field in domoticz
