Would it be possible to add an option for monitoring your public IP address say every 30 mins (user settable) so in the event it changes domoticz could email you the new address.
Dave
Public IP email report
elmortero
- Domoticz version: 3.9639
Re: Public IP email report
I use this dzvents script:
timer = { 'at *:06', 'at *:32','at 14:21'},
httpResponses = { 'getip' } -- matches callback string below
execute = function(domoticz, triggerItem)
local WanIp = domoticz.devices('WanIp') -- this is a virtual text sensor I created for this script so I can see the IP address
local prevWanIP = tostring(WanIp.text) -- here we read the current content of the text sensor
if (triggerItem.isTimer) then
domoticz.openURL({
url = 'https://ifconfig.co/json',
method = 'GET',
callback = 'getip'
elseif (triggerItem.isHTTPResponse) then
local response = triggerItem
if (response.ok and response.isJSON) then
local dirIP = tostring(response.json.ip)
if dirIP ~= nil and dirIP ~= prevWanIP then --check if the current IP is different from what is currently stored in the text sensor
dirIP = tostring(dirIP) --convert to string (just in case it is read as other type
WanIp.updateText(dirIP) --update the text sensor with the new IP
--here you can add the action you want, I send the IP via telegram to my phone and update dyndns
print('**getip failed to fetch info')
