I have a couple of Philips Hue bulbs but no Philips Hue Bridge
I would like to factory reset the bulbs and join them to my Domoticz / Zigate system.
Is it possible to do that, or can I only reset them with a Hue Bridge and Philips software?
I was able to successfully join other brands of bulb to the Zigate already
resetting Philips Hue without the Hue Bridge, only Zigate
Daniel Pocock, Debian Developer
https://danielpocock.com
Re: resetting Philips Hue without the Hue Bridge, only Zigate
Normaly you have to switch the bulbs in nutral (sort of)listening mode by switching the lightbulb a few times on and of. From that point the bulb is able to connect, the bulb needs te be in short range of the connector to exchange some info.
Verzonden vanaf mijn iPad met Tapatalk
drake
I have the same problem. Six bulbs that I need to reconect to Zigate.
After Zigate firmware upgrade I need to reconnect the six bulbs, but I can't do a factory reset of the bulbs. Switching on/off few times didn,t work.
Thorgal789
- Target OS: -
Switching on/off is for ikea
For philips you need the remote or a gateway with touchlink mode.
https://www.youtube.com/watch?v=qvlEAELiJKs
Unfortunately I'm afraid that you have to go for purchasing the Hue remote
