just download plugin.py from dropbox and replace existing one in your plugin folder.Darkneo wrote: Thursday 07 March 2019 7:04
Hi and thanks for your reply. Is there any way to upgrade the plug-in easily? Or do I need to remove the previous one and git clone the last?
Python Plugin : Broadlink RM2 V4
zak45
- Domoticz version: V2024.4
Re: Python Plugin : Broadlink RM2 V4
Darkneo
I'll try it out and keep you posted. Thanks.
For others: Please ensure to chmod +x the .sh file in the Broadlink dir (I also chmod the ones .py in the various directories). For me I went from nothing works to very close to make it work properly
Edit: @Zak45, you might also change the wiki page (transfered to httpS)
zak45
Done, thanksDarkneo wrote: Thursday 07 March 2019 17:28 Edit: @Zak45, you might also change the wiki page (transfered to httpS)![]()
Darkneo
I think it is better now. But I am having some issue with the switch created. Exemple: I have the ON/OFF IR button for my hifi (It is the same button, and I guess the same code).
After creating the switch, if the hifi is off, the switch powers it on. But if it's on, it does not powers it off. With the IHC app, both (ON/OFF with the same switch) works properly. I try to change the switch type from Push On button to On/Off but still not working. I will try to copy the Push On button to create a Push Off button and see what it gives.
(just forgot to mention that)
EDIT: For the Learn/Test/Save button, it is OK nowPush On button log
2019-03-08 07:55:55.759 Status: User: Darkneo initiated a switch command (19/Radio on-off/On) ==> Switch the hifi on
2019-03-08 07:55:55.919 Status: User: Darkneo initiated a switch command (19/Radio on-off/On) ==> Does not switch the hifi off
On/Off Switch
2019-03-08 07:56:32.837 Status: User: Darkneo initiated a switch command (16/Broadlink - Command/Set Level) ==> Switch the hifi on
2019-03-08 07:56:40.205 Status: User: Darkneo initiated a switch command (16/Broadlink - Command/Set Level) ==> Does not switch the hifi off
zak45
Some steps forward; niceDarkneo wrote: Friday 08 March 2019 10:13 EDIT: For the Learn/Test/Save button, it is OK now(just forgot to mention that)
kniazio
- Domoticz version: 3.7243
The new system
The Broadlink Plugin does not work
- winscp.jpg (57.18 KiB) Viewed 3069 times
- modules.jpg (46.68 KiB) Viewed 3069 times
- brdl.jpg (174.07 KiB) Viewed 3069 times
kniazio
Broadlink not running
- domot.jpg (82.61 KiB) Viewed 3067 times
Darkneo
Anyway, your broadlink folder is not correct (or not the one I used). In domoticz/plugins you shall have "BroadlinkRM2", copying the .py files within it, ns copy the broadlin folder (that shall contain ___init___.py file). Rename your broadlink folder to BroadlinkRM2 and copy the broadlink folder (for me, it was in /root/python-broadlink/broadlink) to the BroadlinkRM2 folder (a chmod +X on the __init___.py might be needed... I don't remember... try without the chmod and see what it gives
I think you're in the Device manager. After adding the hardware Broadlink, new switches are directly created. As you have no errors on your logs, I think t'oure on good track.
kniazio
Darkneo wrote: Friday 08 March 2019 14:40 Hi,
I think you're in the Device manager. After adding the hardware Broadlink, new switches are directly created. As you have no errors on your logs, please check that you have the Broadlink switch created correctly
EDIT: BTW, your broadlink folder is not correct (or not the one I used). In Plugin you shall have "BroadlinkRM2", copying the .py files within it, ns copy the broadlin folder (that shall contain ___init___.py file)
- brdl.jpg (45.36 KiB) Viewed 3060 times
- switches.jpg (62.98 KiB) Viewed 3063 times
Darkneo
Sorry I edited the previous post while comparing your installation folders to mine.
Editing all together
No you need to copy the Broadlink folder itslef (find -iname broadlink) with all the content. normally it shall ony content a file __init__.py and eventually a pycache folder)
And I guess you will have to restart your domoticz after doing so... OR at leat to "recreate" the hardware. I would recommand restart Domoticz
zak45
@kniazio
you will be on trouble if you need these ones: Broadlink plugin will not work in this case.
kniazio
It did not do anythingDarkneo wrote: Friday 08 March 2019 14:50 Sorry I edited the previous post while comparing your installation folders to mine.
Editing all together![]()
- brdl.jpg (57.89 KiB) Viewed 3049 times
Darkneo
__init__.py shall be in another folder.
~/BroadlinkRM2:
plugin.py
plugin_http.py
plugin_http.sh
plugin_send.py
~/BroadlinkRM2/broadlink:
__init__.py
As Zak said, also remove pycrypto (if you do not need it). I did not remove pycrptodome at the time... and I am able to connect to the Broadlink
~/BroadlinkRM2:
plugin.py
plugin_http.py
plugin_http.sh
plugin_send.py
__init__.py
kniazio
I do not have
- crypto.jpg (70.11 KiB) Viewed 3041 times
Darkneo
Typo issue on my side.
pycryptodome
On my side, as I said, I have still pycryptodome. Try to remove pycrypto only at first
pycryptodome
kniazio
hands are fallingDarkneo wrote: Friday 08 March 2019 16:14 Typo issue on my side.
pycryptodome
- pycrypto.jpg (73.87 KiB) Viewed 3039 times
kniazio
pycrypto removed
it still does not work
Can you specify the location of the files with the plugin?
Maybe I have bad files
Send me your files
Send me your files
Darkneo
Regarding your module list, we have the same files. But I cant send you a zip file later tonight.
in SSH could you please go to plugin folder:
Then:
Then:
Then:
cd /home/pi/domoticz/plugins
ls -aCode: Select all
cd BroadlinkRM2Code: Select all
ls -a-
kniazio
Waste of time
pvklink
- Domoticz version: latest b
Just bought a broadlink rm pro+ and installed it on my rpi 3b with raspbian stretch.
After that i got three switches: broadlink command, remote and import.
I can add devices by doing
-learning,
-save ,then
-generate and finaly
-import
-add the device
Only things that dont work are
- switch remote. When i click on the button it does nothing, its greyed-out.
The errorlog gives: 2019-03-08 21:00:14.967 Error: (broadlink2) ini file not found: /home/pi/domoticz/BroadlinkRM2-26-254.ini
- switch import/webstart.
The errorlog gives:
2019-03-08 21:03:50.453 Error: (broadlink2) 127
2019-03-08 21:03:50.453 Error: (broadlink2) /home/pi/domoticz/plugins/BroadlinkRM2/plugin_http.sh 0.0.0.0 9000 /home/pi/domoticz
2019-03-08 21:03:50.453 Error: (broadlink2) None
2019-03-08 21:03:50.484 Error: (broadlink2) Not able to start Web server
Is there a way to solves these two 'problems'....
The rest seemd to work ok!
-learning,
-save ,then
-import
-add the device
The errorlog gives:
sudo pip3 install broadlink
sudo pip3 install pyaes
download plugin.py
download plugin_send.py
download plugin_http.py
download plugin_http.sh
mkdir BroadlinkRM2 on the domoticx plugin folder
and copied the scripts to domoticz/plugins directory
chmod +x plugin.py
chmod +x plugin_send.py
chmod +x plugin_http.py
chmod +x plugin_http.sh
Hardware config
ip 192.168.20.61
mac 780f77fd8633
debug true
generate import true
ini folder /home/pi/domoticz
port 9000
Remote control RM2/RM mini3
domoticz latest beta
Version: 4.10547
Build Hash: a76a0fdb
Compile Date: 2019-03-08 03:04:06
dzVents Version: 2.4.15
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Jablotron connection, Ikea
