DOMOTICZ events not working without internet? Zigate not send commands
pfloryann
Domoticz version: 2026.3
Post by pfloryann »
I want to know if domoticz server is working if no internet connection...because the last night internet connection it was down for 7 hours and raspberry pi NOT AUTOCONNECT to internet and Zigate not controlled sensors and sockets all night...Today i had to restart raspberry pi to events and domoticz recorded logs to work again.
So domoticz not Working without internet connection?
Thx
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pipiche
Re: DOMOTICZ events not working without internet? Zigate not send commands
Post by pipiche »
I had quite few time my raspberry disconnected from Wifi and the all Domoticz management with Zigate operated without issues.
pfloryann
Post by pfloryann »
i used an wi-fi extender with lan port for raspberry pi because is Model B without wi-fi...and in base router i have reserved ip for raspberry pi. However Domoticz and zigate it did not work last night after internet connection it was down and it is a problem because heating system it's controlled by zigate
pipiche
Post by pipiche »
Is your Zigate based on Wifi ? In such case how does the router behave when you don't have Internet ? May be you lost the IP address and in such case loose the all intrenet connection
pfloryann
Post by pfloryann »
i use ZiGate USB-TTL is not wi-fi version
pfloryann
Post by pfloryann »
you may be right because wifi extender was off...for awhile last night. So if raspberry pi lost ip...The events and Zigate they will not work anymore?
pipiche
Post by pipiche »
You should have a look to the system and domoticz log on your RPI to understand what's happen
pfloryann
Post by pfloryann »
I tested and if router is off or no internet connection...domoticz switch to offline automatically
pipiche
Post by pipiche »
What do you mean domoticz switch off ? it shutdown ? so when the router is back and you access to the system domoticz is not running anymore ?
pfloryann
Post by pfloryann »
Yes domoticz auto switch off if no internet connection. When internet connection/router is back domoticz not running but raspberry pi it's on...i have to restart domoticz to running again. I think that is happend because of the domoticz events requiring live time(sunrise/sunset).
