Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
pipiche
Re: Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Post by pipiche »
@mcmikev, which version of Domoticz are you using ? Stable V.49700 or something else ?
Wiki is available here.
Zigbee for Domoticz FAQ
mcmikev
Post by mcmikev »
build from source, up2date till yesterday. Version V4.10532
pipiche
Post by pipiche »
And which branche of the plugin ? stable, beta or pre-4.1 ?
pipiche
Post by pipiche »
The TH devices are, but the THB not. Temp, Humi,Baro can this be applied as well please???
I'll have a look ... Indeed that is posisble
mcmikev
Post by mcmikev »
I run pre-4.1 plugin version
pipiche
Post by pipiche »
This looks strange, from the code side, the adjustment is made when receiving a new temperature, despite it is T, TH or THB
I'll investigate on my end
mcmikev
Post by mcmikev »
The Temp device Temp Humi devices are doing it right. But the THB device does nothing with the offset.
pipiche
Post by pipiche »
@mcmikev, could you do an update (git pull). I changed the way it was done, as I was not really happy with it.
Tested here with a Xiaomi device, and all T, TH and THB are updated based on the adjusted value that you have to set for each single widget.
So you need to put the Adj value on T, TH and THB
mcmikev
Post by mcmikev »
So if i only use and add the thb device it Will not work?
pipiche
Post by pipiche »
Yes, it should work
mcmikev
Post by mcmikev »
Testing now
mcmikev
Post by mcmikev »
Seems fine. Need Some more updates
