Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
Re: Zigate and Xiaomi temp/hum/baro sensors adjustment of temp
@mcmikev, which version of Domoticz are you using ? Stable V.49700 or something else ?
Wiki is available here.
Zigbee for Domoticz FAQ
build from source, up2date till yesterday. Version V4.10532
And which branche of the plugin ? stable, beta or pre-4.1 ?
The TH devices are, but the THB not. Temp, Humi,Baro can this be applied as well please???
I run pre-4.1 plugin version
This looks strange, from the code side, the adjustment is made when receiving a new temperature, despite it is T, TH or THB
I'll investigate on my end
The Temp device Temp Humi devices are doing it right. But the THB device does nothing with the offset.
@mcmikev, could you do an update (git pull). I changed the way it was done, as I was not really happy with it.
Tested here with a Xiaomi device, and all T, TH and THB are updated based on the adjusted value that you have to set for each single widget.
So you need to put the Adj value on T, TH and THB
So if i only use and add the thb device it Will not work?
Yes, it should work
Seems fine. Need Some more updates
