Darksky: Problem adding hardware
mgabor
I would like to add the Darksky but it is not working, error message: Problem adding hardware. What is the problem?
ulfh2018
Re: Darksky: Problem adding hardware
Same problem - anybody out there?
witteherder
- Domoticz version: 4.10717
I also did add it but I m not seeing extra devices after that
- Darksky Hardware
- Darksky.jpg (51.86 KiB) Viewed 2923 times
mgabor
When you press the add button, then you will get the problem message.
witteherder
I m not getting an error
Only the log file of Domoticz say this
- calimero
Same here. Now, since Weather Undergroup pulled the plug, looking for something new. Dark Sky aint cooperating.....
Nautilus
At least the API key is wrong. You just enter the key there, not a URL. Something like 20cc88b18c30ca7cc5d2c8726ggb8c23. Maybe you need to also allow new devices before hitting "add"/"update" unless you have them allowed by default.witteherder wrote: Thursday 28 February 2019 13:31 I also did add it but I m not seeing extra devices after that
- waaren
In the API key field you only need to enter the API key without quotes. Not the complete http string. Also allow for new devices to be added in domoticz settings. The devices will be created within a couple of minutes and appear in your devices tab with a green arrow. Enable them by clicking on the green arrow and give them the name you want.witteherder wrote: Thursday 28 February 2019 13:31 I also did add it but I m not seeing extra devices after that
