Error ToonThermostat
dressie
Domoticz version: V2020.2
Re: Error ToonThermostat
Post by dressie »
So if I understand correctly, this only work in the last beta? So no point trying to get it up and running in stable?
waspy
Domoticz version: 4.10430
Post by waspy »
Well, I have not tested it with the latest stable, but I was able to make it work using a symbolic link like I explained in my previous posts.
dressie
Post by dressie »
waspy wrote: Saturday 23 February 2019 0:03 Well, I have not tested it with the latest stable, but I was able to make it work using a symbolic link like I explained in my previous posts.
I used that trick, but it didn't take. Second PI with Beta works now.
rinyheuvelman
Domoticz version: 4.10427
Post by rinyheuvelman »
Although I thought the installation guide is pretty straight forward, it turned out it wasn't as I thought it would be..?
Followed the directions, But Log shows:
2019-02-23 04:10:23.669 Status: (Toon) Entering work loop.
2019-02-23 04:10:23.670 Status: (Toon) Initialized version 1.0.0, author 'John van de Vrugt'
followed by:
2019-02-23 04:22:26.420 Error: (Toon) 'onHeartbeat' failed 'KeyError'.
2019-02-23 04:22:26.420 Error: (Toon) ----> Line 169 in '/home/pi/domoticz/plugins/toonapilib4domoticz/plugin.py', function onHeartbeat
2019-02-23 04:22:26.420 Error: (Toon) ----> Line 94 in '/home/pi/domoticz/plugins/toonapilib4domoticz/plugin.py', function onHeartbeat
2019-02-23 04:22:26.420 Error: (Toon) ----> Line 101 in '/home/pi/domoticz/plugins/toonapilib4domoticz/plugin.py', function UpdateDevices
No devices added at all...?
Must be missing something, as others mentioned maybe a more step-by-step noob friendly install guide..?
Attie
Post by Attie »
After updating to the latest Beta I've got rit of the "failed to load 'plugin.py'" error and became a lot further.
Here is the log:
2019-02-23 10:02:49.316 Status: (Toon) Started.
2019-02-23 10:02:51.314 Status: (Toon) Entering work loop.
2019-02-23 10:02:51.315 Status: (Toon) Initialized version 1.0.0, author 'John van de Vrugt'
2019-02-23 10:02:51.519 Error: (Toon) 'onStart' failed 'NameError'.
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 141 in '/home/pi/domoticz/plugins/toonapilib4domoticz/plugin.py', function onStart
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 35 in '/home/pi/domoticz/plugins/toonapilib4domoticz/plugin.py', function onStart
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 101 in '/usr/local/lib/python3.5/dist-packages/toonapilib/toonapilib.py', function __init__
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 145 in '/usr/local/lib/python3.5/dist-packages/toonapilib/toonapilib.py', function _authenticate
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 122 in '/usr/local/lib/python3.5/dist-packages/toonapilib/toonapilib.py', function _get_challenge_code
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 258 in '/usr/local/lib/python3.5/dist-packages/toonapilib/toonapilib.py', function _patched_request
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 892 in '/usr/local/lib/python3.5/dist-packages/requests/models.py', function json
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 516 in '/usr/lib/python3/dist-packages/simplejson/__init__.py', function loads
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 374 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function decode
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 404 in '/usr/lib/python3/dist-packages/simplejson/decoder.py', function raw_decode
2019-02-23 10:02:51.519 Error: (Toon) ----> Line 33 in '/usr/lib/python3/dist-packages/simplejson/scanner.py', function __init__
No devices found ...
UPDATE!!!
I saw there is a update on de plugin.py and I uploaded to the dir and now it works!
I see the toon devices in the list. Good work!
waspy
Post by waspy »
rinyheuvelman wrote: Saturday 23 February 2019 4:26 2019-02-23 04:10:23.669 Status: (Toon) Entering work loop.
followed by:
Riny,
Did you use an unique hardware name?
On start the plugin reads the number of devices that belong to the hardware.
If none, it will add all the devices that belong to the hardware/plugin.
Else it starts updating its devices.
From your log file I think that it somehow detects devices, but then during update it is missing devices that should have been created earlier.
My advise: a clean start
1. Delete the plugin in the hardware page.
2. Stop the domoticz service (sudo service domoticz stop).
3. Remove the plugin from the domoticz plugin folder, e.g. cd /home/pi/dev-domoticz/plugins/; sudo rm -rf toonapilib4domoticz.
4. Double check if you removed the toonapilib4domoticz plugin.
5. clone the toonapilib from git again. (I just updated the script) cd /home/pi/dev-domoticz/plugins; git clone https://github.com/JohnvandeVrugt/toona ... moticz.git
6. Restart the domoticz service
7. Select the toonapilib hardware.
8. Use an unique hardware name.
9. Double check your credentials.
10. Press Add/Toevoegen
Check the log for errors / check if any devices are created.
Just followed the steps myself without any issues.
Good luck!
waspy
Post by waspy »
Attie wrote: Saturday 23 February 2019 10:15 After updating to the latest Beta I've got rit of the "failed to load 'plugin.py'" error and became a lot further.
Here is the log:
Attie,
I think the plugin is not able to create the Toon object of the toonapilib.
Please double check your credentials. (user name, pass, api keys)
Attie
Post by Attie »
waspy wrote: Saturday 23 February 2019 10:47
Here is the log:
Attie,
I was using an older version of the plugin.py from last evening. I saw there was an update this morning and with this version I have no errors and the devices are listed. Updated the post above....
eenernl
Post by eenernl »
My domoticz crashes when plug-in is installed. There is a script working too long... when I remove the “plugin.py” it’s working again...
I installed python3
Then I installed toonapilib
Placed plugin.py in the pluginsfolder
Added hardware
I have a raspberry pi B+
Installed latest beta 4.10447
* Raspberry Pi B rev2 (with latest Beta of Domoticz)
* 1x RFXtrx433E
* 4x TX320 Temperature/humidity sensors
* 6x KaKu ACD-3500 | Kaku ALED-2709 | KaKu ACM-100 | 2x KaKu AMU-500 | KaKu AWMR-300
* 1x Toon Thermostat (via ToonApiLib)
darkrain
Post by darkrain »
eenernl wrote: Saturday 23 February 2019 11:17 My domoticz crashes when plug-in is installed. There is a script working too long... when I remove the “plugin.py” it’s working again...
I installed python3
Added hardware
did you make a folder inside the pluginsfolder?
You have to make a subfolder and place the script "plugin.py" inside that folder.
eenernl
Post by eenernl »
darkrain wrote: Saturday 23 February 2019 11:24
I installed python3
Added hardware
Yes, I made the subfolder.
* 1x RFXtrx433E
dressie
Post by dressie »
I installed python3
Added hardware
Did you get this version:
pip3 install -I toonapilib==3.0.2
eenernl
Post by eenernl »
Yup I installed 3.0.2
But i couldn’t use that command becaus I hadn’t python installed. So I installed python3-pip first. After that I followed the instructions.
* 1x RFXtrx433E
a3vd
Post by a3vd »
Yes it's working again will look in to the scripts later to make the light switch working again but this is great !
Big thanks to John (y)
Raspberry 3+ / 4
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12/Conbee2 (zigbee)
Several Kaku switches/ Weather Underground / Hue
jvliere
Post by jvliere »
Yes! It's working after I've update Domoticz to the betaversion.
Some small issue:
- On top of the gas and elektra graphs, the buttons "back" and "report" are missing.
GCB2016
Domoticz version: V3.9208
Post by GCB2016 »
I just wanted to say THANK YOU to everyone involved with fixing this issue :) Have a nice Sunday.
darkrain
Post by darkrain »
Hi @waspy
How do you want us (me) to report issues, is it OK to use github for this?
Really like this and I am willing to help, but my Python skills are none existing...
But with some help from perhaps others we can make this plugin better and better...
waspy
Post by waspy »
darkrain wrote:Hi @waspy
Github is fine. I'm not a python coder myself, but learn while trying...
Note that I plan to add smoke detector and light/power plug support in the coming days. Same goes for thermostat states and burner states.
Last 2 days I was quite busy supporting users.
Now I want to focus on features once more.
Now its time to ride the woods
Verstuurd vanaf mijn SM-G935F met Tapatalk
Pandabeer
Domoticz version: 10265
Post by Pandabeer »
Great job @Waspy - running in test enviroment on Windows10, Domoticz 4.10449, latest python version en latest (3.06) toonapilib! Should be great to have the other options available but enjoy the good weather and cycling in the woods...!
Little expert running Domoticz on a Raspberry Pi
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |
HansieNL
Post by HansieNL »
@waspy : Thanks for this solution :D
I'm only using just two settings of Toon: Setpoint and Room temperature. If I just remove the other devices will they be added again if check for new hardware? Or have I to strip unused devices from the python script?
Can I remove Toon - Source also? It's not clear to me what it does.
Thanks for your help.
Blah blah blah
