Hall lights
Ronnyboy
Hall lights
Hello
Can someneone tell me what i'm doing wrong with this blockly.
This is the log
21:59:58.221 Error: EventSystem: Lua script error (Blockly), Name: Hal verlichting na zessen_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: 'then' expected near 'comparevariable
And this is the blockly
This is the log
- verlichting.jpg (49.46 KiB) Viewed 6034 times
- jvdz
- Domoticz version: 4.107
Re: Hall lights
Your time condition looks wrong. You have:
Time >18:00 < 23:59
Think that needs to be :
Time > 18:00 And Time < 23:59
Jos
Time >18:00 < 23:59
Jos
Ronnyboy
Re: Hall lights
Changed it,but didnt work!
- nayr
- Domoticz version: github
Re: Hall lights
If (Voordeurcontact = Open and (Time > (( 18:00 < 23:59) & (hal = Off)))
is what you have in your screenshot, totally invalid logic
You have your ands nested incorrectly, try something that looks like:
If - (vooordeurcontact = open) and (hal = off) and ((time > 18:00) and (time < 23:59))
Ronnyboy
Re: Hall lights
hmm.. tried that to,but no response!
- StanHD
Re: Hall lights
The top one is currently my working Blockly. I have edited it to the lower one to emulate your Blockly.
Might help?
Might help?
Python:- Broadlink RM2, Sonos
Ronnyboy
Re: Hall lights
strange,
where did you get that first "and" block from
i cant find it
i cant find it
- StanHD
Re: Hall lights
Right Click the block & select "External Inputs". It works the same but I find it easier to understand when there are nested "And" / "Or" operators.
Ronnyboy
Re: Hall lights
YES that works !! Thank you very much!
behave49
Re: Hall lights
Having the same problem, can't see the solution image anymore.
Can someone help me out here
- jvdz
Re: Hall lights
I would help when you post your script/blockly logic so we can see what is happening.
Jos
Jos
behave49
Re: Hall lights
Wow didnt see youre reply till now haha.
Here is my screenshot. What i want is to give me a notification if my dore is open at night.
I get this error..2019-05-08 17:46:59.429 Error: EventSystem: Lua script error (Blockly), Name: Nacht alarm deur open_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: 'then' expected near 'comparevariable'
I get this error with al my blocky scripts if i want to enter a time schedule
- deuropen.jpg (50.01 KiB) Viewed 4214 times
pvm
- Domoticz version: 4.10538
Re: Hall lights
Using a time frame which passes the 0:00 barrier never worked for me.
I created a dummy switch, turn it on and off using timers and use that switch in blockly
behave49
Re: Hall lights
I tried the time not passing 0:00 but the same error.
Can you tell me ( show me) how you solved that?
pvm
Re: Hall lights
Add dummy hardwarebehave49 wrote: Thursday 09 May 2019 14:46 I tried the time not passing 0:00 but the same error.
Add dummy switch
Set timer on that
In your blockly check switch == on
Do you have a specific question on this?
behave49
Re: Hall lights
I tried the "or" but did not work, same error
tozzke
- Domoticz version: Stable
Re: Hall lights
Could you show your Blockly? I think something else is still wrong. The 'Open' block in your opening post/first Blockly and the 'On' block in your second screenshot are both positioned incorrectly. As @nayr already said but you didn't follow his advice.
