Utility value to dummy percentage
Tarzan737
Post by Tarzan737 »
Hello..
is it possible to convert a value to percent..
if i get a value on my utility sensor from let´s say 0 - 270 but want to see that in percent instead..
like 270 is 100% and 0 is 0
is it any script for that to a dummy sensor? or any solution
felix63
Domoticz version: 2020.1
Re: Utility value to dummy percentage
Post by felix63 »
First create a virtual sensor of type 'percentage'. Lets say 'percentage'. Then create the following dzvents script to convert the value from 'sensor' 0 - 270 to a percentage value in sensor 'percentage'. Haven't tested the script btw. Might contain errors!
	-- 'active' controls if this entire script is considered or not
	active = true, -- set to false to disable this script
	-- trigger
	-- can be a combination:
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			'sensor',
    logging = {
--        level = domoticz.LOG_INFO,
        marker = "Converter"
	-- actual event code
	-- in case of a timer event or security event, device == nil
        domoticz.devices('percentage').updatePercentage(domoticz.utils.round((domoticz.devices('Sensor').nValue/270)*100),2)
Tarzan737
Post by Tarzan737 »
I couldnt really make it work last night with that script. I just renamed sensor and percentage to the name of my devices, something else to do?
Tarzan737 wrote: Tuesday 19 February 2019 6:20 Thanks!
Not every sensor use nValue to store the measured value. What is the type / subtype of your sensor ? (look at the devices tab)
What do you see in the logfile ?
Tarzan737
Post by Tarzan737 »
it looks like this.. and i use denkovi daenetip4 hardware
Screenshot (17).png (373.66 KiB) Viewed 3518 times
Tarzan737 wrote: Tuesday 19 February 2019 17:26 it looks like this.. and i use denkovi daenetip4 hardware
In this deviceType the value is stored in the sValue field. Can you test below script ?
                devices =   {
                                'sensor'
   logging = {
    execute = function(dz, item)
        local dataFromSensor        = item.rawData[1]
        local maxValue              = 270
        local decimals              = 2
        local percentage            = dataFromSensor / maxValue * 100
        local roundedPercentage     = dz.utils.round(percentage,decimals )
        local percentageDevice      = dz.devices('percentage')
        dz.log("Rounded percentage is " ..  roundedPercentage .. "%")
        percentageDevice.updatePercentage(roundedPercentage)
Tarzan737
Post by Tarzan737 »
YEEESSS!! This seems to work!! Thank you very much for help..
if i want to have the opposite.. like value 0 is 100% instead.. because i don´t know how my new sensor works.. (haven`t recieved it)
value 1023 0% and value 0 100%
Tarzan737 wrote: Tuesday 19 February 2019 21:27 YEEESSS!! This seems to work!! Thank you very much for help..
set inverted = true in below script should do that
                devices =   {
                                'sensor'
   logging = {
        local inverted              = false          -- if max value of sensor should be reflected in 0% and 0 in 100%
        local decimals              = 2
        if inverted then
               percentage = 100 - percentage
Tarzan737
Post by Tarzan737 »
Thank u very much!! it works fine!!
Tarzan737
Post by Tarzan737 »
Hello!!
i noticed that my 0 value not always is 0 when calibrating my sensors, it could be like 137 or something so the percentage will not
show correct.
i tried to add the line localMinvalue = 137 but nu success..
not that easy that i thought :(
Tarzan737 wrote: Wednesday 27 February 2019 21:12 Hello!!
show correct.
Could be something like this ? Adjust minValue to what you observe
                devices =   {
                                'sensor'
   logging = {
        local decimals              = 2
        local minValue              = 0
	local percentage            = ( dataFromSensor - minValue ) / maxValue * 100
        if inverted then
Tarzan737
Post by Tarzan737 »
Yepp!! seems to work! Thanks again
Tarzan737
Post by Tarzan737 »
hmm need help again
in my tank level sensor max value is 502 and min value 492
but it does not show correct at all, let´s say my sensor output is 499
with this formula ( dataFromSensor - minValue ) / maxValue * 100
it will take 499-492 = 7 then take 7/502 * 100
and the percentage is not correct..
any idea how to write the code?
Tarzan737 wrote: Tuesday 05 March 2019 19:47 in my tank level sensor max value is 502 and min value 492
Sure but first need to understand :D
So 502 is 100% and 492 = 0% ?
Or do you mean something else ?
Tarzan737
Post by Tarzan737 »
Yepp! Correct. (In this case with tank level)
Tarzan737 wrote: Wednesday 06 March 2019 6:01 Yepp! Correct. (In this case with tank level)
Can you test this ?
                devices =   {
                                'sensor'
   logging = {
        local inverted              = false          -- if max value of sensor should be reflected in 0% and minValue in 100%
        local maxValue              = 502
        local minValue              = 492
        local decimals              = 2
        local percentage            = ( dataFromSensor - minValue ) / ( maxValue - minValue ) * 100
        if inverted then
Tarzan737
Post by Tarzan737 »
Yes that works as i wish, what should i do without you :) thanks again
Tarzan737
Post by Tarzan737 »
Hello..
has anything changed with domoticz?
i cant make this code work anymore..
anyone knows why?
i use the same hardware (daenetip4)
Tarzan737 wrote: Monday 06 April 2020 21:52 Hello..
Yes :D
Please supply some more background. What is your current domoticz version / OS / What do you see in the log / what does not work
Tarzan737
Post by Tarzan737 »
i think i did see now!! in options i had to check the box enable dz vents.. it should be the last version
had som hours just to make domoticz start again :)
