Utility value to dummy percentage
Tarzan737
Hello..
is it possible to convert a value to percent..
if i get a value on my utility sensor from let´s say 0 - 270 but want to see that in percent instead..
like 270 is 100% and 0 is 0
is it any script for that to a dummy sensor? or any solution
- felix63
- Domoticz version: 2020.1
Re: Utility value to dummy percentage
First create a virtual sensor of type 'percentage'. Lets say 'percentage'. Then create the following dzvents script to convert the value from 'sensor' 0 - 270 to a percentage value in sensor 'percentage'. Haven't tested the script btw. Might contain errors!
-- 'active' controls if this entire script is considered or not
active = true, -- set to false to disable this script
-- trigger
-- can be a combination:
devices = {
-- scripts is executed if the device that was updated matches with one of these triggers
'sensor',
logging = {
-- level = domoticz.LOG_INFO,
marker = "Converter"
-- actual event code
-- in case of a timer event or security event, device == nil
domoticz.devices('percentage').updatePercentage(domoticz.utils.round((domoticz.devices('Sensor').nValue/270)*100),2)
Tarzan737
I couldnt really make it work last night with that script. I just renamed sensor and percentage to the name of my devices, something else to do?
- waaren
Not every sensor use nValue to store the measured value. What is the type / subtype of your sensor ? (look at the devices tab)Tarzan737 wrote: Tuesday 19 February 2019 6:20 Thanks!
What do you see in the logfile ?
Tarzan737
it looks like this.. and i use denkovi daenetip4 hardware
- Screenshot (17).png (373.66 KiB) Viewed 3920 times
- waaren
In this deviceType the value is stored in the sValue field. Can you test below script ?Tarzan737 wrote: Tuesday 19 February 2019 17:26 it looks like this.. and i use denkovi daenetip4 hardware
devices = {
'sensor'
logging = {
execute = function(dz, item)
local dataFromSensor = item.rawData[1]
local maxValue = 270
local decimals = 2
local percentage = dataFromSensor / maxValue * 100
local roundedPercentage = dz.utils.round(percentage,decimals )
local percentageDevice = dz.devices('percentage')
dz.log("Rounded percentage is " .. roundedPercentage .. "%")
percentageDevice.updatePercentage(roundedPercentage)
}Debian buster, bullseye on RPI-4, Intel NUC.
Tarzan737
YEEESSS!! This seems to work!! Thank you very much for help..
if i want to have the opposite.. like value 0 is 100% instead.. because i don´t know how my new sensor works.. (haven`t recieved it)
value 1023 0% and value 0 100%
- waaren
set inverted = true in below script should do thatTarzan737 wrote: Tuesday 19 February 2019 21:27 YEEESSS!! This seems to work!! Thank you very much for help..
devices = {
'sensor'
logging = {
local inverted = false -- if max value of sensor should be reflected in 0% and 0 in 100%
local decimals = 2
if inverted then
percentage = 100 - percentage
Tarzan737
Thank u very much!! it works fine!!
Tarzan737
Hello!!
i noticed that my 0 value not always is 0 when calibrating my sensors, it could be like 137 or something so the percentage will not
show correct.
i tried to add the line localMinvalue = 137 but nu success..
not that easy that i thought
show correct.
- waaren
Could be something like this ? Adjust minValue to what you observeTarzan737 wrote: Wednesday 27 February 2019 21:12 Hello!!
show correct.
not that easy that i thought![]()
devices = {
'sensor'
logging = {
local decimals = 2
local minValue = 0
local percentage = ( dataFromSensor - minValue ) / maxValue * 100
if inverted then
Tarzan737
Yepp!! seems to work! Thanks again
Tarzan737
hmm need help again
in my tank level sensor max value is 502 and min value 492
but it does not show correct at all, let´s say my sensor output is 499
with this formula ( dataFromSensor - minValue ) / maxValue * 100
it will take 499-492 = 7 then take 7/502 * 100
and the percentage is not correct..
any idea how to write the code?
- waaren
Sure but first need to understandTarzan737 wrote: Tuesday 05 March 2019 19:47 in my tank level sensor max value is 502 and min value 492
So 502 is 100% and 492 = 0% ?
Or do you mean something else ?
Tarzan737
Yepp! Correct. (In this case with tank level)
- waaren
Can you test this ?
devices = {
'sensor'
logging = {
local inverted = false -- if max value of sensor should be reflected in 0% and minValue in 100%
local maxValue = 502
local minValue = 492
local decimals = 2
local percentage = ( dataFromSensor - minValue ) / ( maxValue - minValue ) * 100
if inverted then
Tarzan737
Yes that works as i wish, what should i do without you
thanks again
Tarzan737
Hello..
has anything changed with domoticz?
i cant make this code work anymore..
anyone knows why?
i use the same hardware (daenetip4)
anyone knows why?
- waaren
Yes
Please supply some more background. What is your current domoticz version / OS / What do you see in the log / what does not worki cant make this code work anymore..
Tarzan737
i think i did see now!! in options i had to check the box enable dz vents.. it should be the last version
had som hours just to make domoticz start again
