Average daily lowest temperature
gertlind1
Post by gertlind1 »
Need some help with a LUA script
Im running this query :
https://xxxx.com/json.htm?type=graph&se ... ange=month
Getting below output, this is great so far.
I want to get out the "tm" temp for the last 7 days, add them and divide by 7.
Where do i start ?
   "result" : [
         "d" : "2019-02-11",
         "hu" : "90",
         "ta" : -0.19,
         "te" : 1.3,
         "tm" : -2.7999999999999998
         "d" : "2019-02-12",
         "hu" : "81",
         "ta" : -2.6800000000000002,
         "te" : -0.90000000000000002,
         "tm" : -4.0
         "d" : "2019-02-13",
         "hu" : "89",
         "ta" : 1.2,
         "te" : 3.2000000000000002,
         "tm" : -2.1000000000000001
         "d" : "2019-02-14",
         "hu" : "89",
         "ta" : 1.4399999999999999,
         "te" : 3.7999999999999998,
         "tm" : -1.2
         "d" : "2019-02-15",
         "hu" : "92",
         "ta" : 2.52,
         "te" : 4.7000000000000002,
         "tm" : 1.5
         "d" : "2019-02-16",
         "hu" : "82",
         "ta" : 2.96,
         "te" : 5.7999999999999998,
         "tm" : 1.2
         "d" : "2019-02-17",
         "hu" : "85.8515625",
         "ta" : -0.63671875,
         "te" : 1.2,
         "tm" : -1.7
   "status" : "OK",
   "title" : "Graph temp month"
Gert
Re: Average daily lowest temperature
gertlind1 wrote: Sunday 17 February 2019 10:45 Im running this query :
Where do i start ?
Try this dzVents script.
-- getweekly average
local httpResponses = "getMonthlyTemperature"
    on      =   {
                    timer           =   { "at 06:07"   },
                    httpResponses   =   { httpResponses .. "*"   }
    logging =   {
                    level           =   domoticz.LOG_DEBUG,
                    marker          =   httpResponses
    execute = function(dz, item)
        -- ****************************** Your settings below this line ***************************************************
        temperatureSensor = dz.devices(880)          -- Replace with ID of your temperature Sensor
        -- ****************************** No changes required below this line *********************************************
        local Time = require('Time')
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function triggerJSON(url, response, delay)
            dz.openURL({    url = url,
                            method = "GET",
                            callback = response }).afterSec(delay or 1)
        local function getAverage(rt)
            local tmSummed = 0
            local days      = 0
            local week = {}
            for day=7,1,-1 do
                week[day] = os.date("%Y-%m-%d",os.time()-day * 24 * 60 * 60)
            for key in ipairs(rt) do
                for day in ipairs(week) do
                    if week[day] == rt[key].d then
                       tmSummed = tmSummed + tonumber(rt[key].tm)
                       days = days + 1
            return dz.utils.round(tmSummed / days,1)
        if not item.isHTTPResponse then
            triggerJSON(dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=month&idx=" .. temperatureSensor.id, httpResponses .. "_graph")
        elseif item.ok then                                      -- statusCode == 2xx
            logWrite("Average tm: ".. getAverage(item.json.result))
            logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")"  ,dz.LOG_ERROR)
            logWrite(item.data)
gertlind1
Post by gertlind1 »
Hi waaren
Thanks for your effort.
I do get an error.
I have only HTTPS enabled.
Tried to enable HTTP port 8080, no improvement.
Also tried to inject user and pw, same problem. WHen i run the query from chrome it works.
2019-02-18 09:23:00.154  Status: dzVents: Info:  getMonthlyTemperature: ------ Start external script: daily_temp_average.lua:, trigger: every minute
2019-02-18 09:23:00.184  Status: dzVents: Debug: getMonthlyTemperature: Processing device-adapter for Ute: Temperature+humidity device adapter
2019-02-18 09:23:00.185  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: url = http://127.0.0.1:8080/json.htm?type=graph&sensor=temp&range=month&idx=19
2019-02-18 09:23:00.185  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: method = GET
2019-02-18 09:23:00.185  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: post data = nil
2019-02-18 09:23:00.185  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: headers = nil
2019-02-18 09:23:00.185  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: callback = getMonthlyTemperature_graph
2019-02-18 09:23:00.185  Status: dzVents: Info:  getMonthlyTemperature: ------ Finished daily_temp_average.lua
2019-02-18 09:23:00.289  Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-02-18 09:23:01.312  Error: Error opening url: http://127.0.0.1:8080/json.htm?type=graph&sensor=temp&range=month&idx=19
2019-02-18 09:23:01.493  Status: dzVents: Info:  Handling httpResponse-events for: "getMonthlyTemperature_graph
2019-02-18 09:23:01.494  Status: dzVents: Info:  getMonthlyTemperature: ------ Start external script: daily_temp_average.lua: HTTPResponse: "getMonthlyTemperature_graph"
2019-02-18 09:23:01.510  Status: dzVents: Debug: getMonthlyTemperature: Processing device-adapter for Ute: Temperature+humidity device adapter
2019-02-18 09:23:01.510  Status: dzVents: Error (2.4.6): getMonthlyTemperature: Could not get (good) data from domoticz. Error (401)
2019-02-18 09:23:01.511  Status: dzVents: Info:  getMonthlyTemperature: ------ Finished daily_temp_average.lua
Another thing that strikes me, maybe range=month is not good. What happens at the month break (feb to mar), will it still be 7 last entries?
Gert
gertlind1 wrote: Monday 18 February 2019 9:26 I do get an error.
If you are not yet familiar with dzvents then please look at the 10 lines using dzVents with Domoticz for an intro to dzVents and howto get this script active in domoticz without errors on 127.0.0.1
the range=month will give the last 30 days or so.
gertlind1
Post by gertlind1 »
Works as a charm now, thanks a lot.
2019-02-18 11:32:00.181  Status: dzVents: Info:  getMonthlyTemperature: ------ Start external script: daily_temp_average.lua:, trigger: every minute
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: Processing device-adapter for Ute: Temperature+humidity device adapter
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: url = http://127.0.0.1:8080/json.htm?type=graph&sensor=temp&range=month&idx=19
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: method = GET
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: post data = nil
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: headers = nil
2019-02-18 11:32:00.197  Status: dzVents: Debug: getMonthlyTemperature: OpenURL: callback = getMonthlyTemperature_graph
2019-02-18 11:32:00.197  Status: dzVents: Info:  getMonthlyTemperature: ------ Finished daily_temp_average.lua
2019-02-18 11:32:00.263  Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-02-18 11:32:01.494  Status: dzVents: Info:  Handling httpResponse-events for: "getMonthlyTemperature_graph
2019-02-18 11:32:01.495  Status: dzVents: Info:  getMonthlyTemperature: ------ Start external script: daily_temp_average.lua: HTTPResponse: "getMonthlyTemperature_graph"
2019-02-18 11:32:01.543  Status: dzVents: Debug: getMonthlyTemperature: Processing device-adapter for Ute: Temperature+humidity device adapter
2019-02-18 11:32:01.544  Status: dzVents: Debug: getMonthlyTemperature: Average tm: -1.3
2019-02-18 11:32:01.544  Status: dzVents: Info:  getMonthlyTemperature: ------ Finished daily_temp_average.lua
Gert
