Send temperature by email with blockly script
julien92
Domoticz version: 4.9701
Post by julien92 »
I’m a newbie this Domoticz and would like to send the external temperature by email every hour, via a blockly script.
In order to manage this, I’m wondering how :
- Get the value of the temperature and put it into a variable
- Send the content of this variable within an email
Could you please help me to achieve this? (I hope without needing to use LUA script, which I don’t know at all ;)
Thanks a lot in advance.
Julien
Xenomes
Domoticz version: 2026.4
Re: Send temperature by email with blockly script
Post by Xenomes »
Try this is email blocky Temperatuur = {{temperaturedevice[273]}}
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
julien92
Post by julien92 »
I've managed to get the temperature and put it into a variable :
temp_ext=$(curl -s 'http://192.168.1.45:8082/json.htm?type=devices&rid=59' | awk -F "\"" '/Data/ {print $4}')
IDX 59 being my temperature sensor
When I type :
echo $temp_ext
It displays the temperature.
BUT when putting it into a shell script, that does not work, and I can't figure out why :
sudo nano /home/pi/scripts/get_sensors_values.sh
#!/bin/bash
sudo chmod +x /home/pi/scripts/get_sensors_values.sh
I then execute the script :
./get_sensors_values.sh
And when typing :
echo $temp_ext
It does not display the last temperature.
Does anybody have any idea how I could fix this?
Once I will have solved that, I still need to figure out how to put this variable within a blockly script, in order to send it by email.
Julien
julien92
Post by julien92 »
I'm still answering to myself :
The script needs to be launched with source command :
source ./get_sensors_values.sh
or
. ./get_sensors_values.sh
It's working fine like this.
Now I just need to know how to make this variable useable by domoticz, so that I can use this variable within an email sent by a blockly script.
I'm still looking for that...
