tixi7 wrote: Saturday 16 February 2019 23:17
dorenberg wrote: Thursday 14 February 2019 11:34
Well I don't think it is a domoticz issue as I can switch the LED with DPS 1 (off and on). However the plug switch is 101, and that is not possible.
I cannot get the reason of your problem. Can you send some debug traces?
An alternative to test is to use a virtual switch and to call directly turnON/OFF as scripts
WITH DPS 101 PLUG SWITCHING
2019-02-18 19:02:46.228 Status: User: Admin initiated a switch command (52/TV plug/Off)
2019-02-18 19:02:46.269 Error: (TV plug) 'onCommand' failed 'KeyError'.
2019-02-18 19:02:46.269 Error: (TV plug) ----> Line 513 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onCommand
2019-02-18 19:02:46.269 Error: (TV plug) ----> Line 450 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onCommand
2019-02-18 19:02:48.444 (TV plug) Pushing 'onHeartbeatCallback' on to queue
2019-02-18 19:02:48.474 (TV plug) Processing 'onHeartbeatCallback' message
2019-02-18 19:02:48.474 (TV plug) Calling message handler 'onHeartbeat'.
2019-02-18 19:02:58.446 (TV plug) Pushing 'onHeartbeatCallback' on to queue
2019-02-18 19:02:58.495 (TV plug) Processing 'onHeartbeatCallback' message
2019-02-18 19:02:58.495 (TV plug) Calling message handler 'onHeartbeat'.
2019-02-18 19:02:58.496 (TV plug) Pushing 'WriteDirective' on to queue
2019-02-18 19:02:58.497 (TV plug) Processing 'WriteDirective' message
2019-02-18 19:02:58.497 (TV plug) Sending 86 bytes of data
2019-02-18 19:02:58.497 (TV plug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 67 77 ..U�...........F{"gw
2019-02-18 19:02:58.497 (TV plug) 49 64 22 3a 22 31 32 37 31 36 34 30 31 38 30 37 64 33 61 37 Id":"12716401807d3a7
2019-02-18 19:02:58.497 (TV plug) 62 35 63 36 62 22 2c 22 64 65 76 49 64 22 3a 22 31 32 37 31 b5c6b","devId":"1271
2019-02-18 19:02:58.497 (TV plug) 36 34 30 31 38 30 37 64 33 61 37 62 35 63 36 62 22 7d 00 00 6401807d3a7b5c6b"}..
2019-02-18 19:02:58.497 (TV plug) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2019-02-18 19:02:58.776 (TV plug) Pushing 'ReadEvent' on to queue
2019-02-18 19:02:58.798 (TV plug) Processing 'ReadEvent' message
2019-02-18 19:02:58.798 (TV plug) Received 331 bytes of data
2019-02-18 19:02:58.798 (TV plug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 01 3b 00 00 00 00 ..U�...........;....
2019-02-18 19:02:58.798 (TV plug) 7b 22 64 65 76 49 64 22 3a 22 31 32 37 31 36 34 30 31 38 30 {"devId":"1271640180
2019-02-18 19:02:58.798 (TV plug) 37 64 33 61 37 62 35 63 36 62 22 2c 22 64 70 73 22 3a 7b 22 7d3a7b5c6b","dps":{"
2019-02-18 19:02:58.799 (TV plug) 31 22 3a 74 72 75 65 2c 22 32 22 3a 22 63 6f 6c 6f 75 72 22 1":true,"2":"colour"
2019-02-18 19:02:58.799 (TV plug) 2c 22 33 22 3a 31 38 30 2c 22 34 22 3a 32 35 35 2c 22 35 22 ,"3":180,"4":255,"5"
2019-02-18 19:02:58.799 (TV plug) 3a 22 31 39 31 37 31 37 30 31 35 33 31 39 31 39 22 2c 22 36 :"19171701531919","6
2019-02-18 19:02:58.799 (TV plug) 22 3a 22 30 30 66 66 30 30 30 30 30 30 30 30 30 30 22 2c 22 ":"00ff0000000000","
2019-02-18 19:02:58.799 (TV plug) 37 22 3a 22 66 66 66 66 35 30 30 31 30 30 66 66 30 30 22 2c 7":"ffff500100ff00",
2019-02-18 19:02:58.799 (TV plug) 22 38 22 3a 22 66 66 66 66 38 30 30 33 66 66 30 30 30 30 30 "8":"ffff8003ff00000
2019-02-18 19:02:58.799 (TV plug) 30 66 66 30 30 30 30 30 30 66 66 30 30 30 30 30 30 30 30 30 0ff000000ff000000000
2019-02-18 19:02:58.799 (TV plug) 30 30 30 30 30 30 30 30 30 22 2c 22 39 22 3a 22 66 66 66 66 000000000","9":"ffff
2019-02-18 19:02:58.799 (TV plug) 35 30 30 31 66 66 30 30 30 30 22 2c 22 31 30 22 3a 22 66 66 5001ff0000","10":"ff
2019-02-18 19:02:58.800 (TV plug) 66 66 30 35 30 35 66 66 30 30 30 30 30 30 66 66 30 30 66 66 ff0505ff000000ff00ff
2019-02-18 19:02:58.800 (TV plug) 66 66 30 30 66 66 30 30 66 66 30 30 30 30 66 66 30 30 30 30 ff00ff00ff0000ff0000
2019-02-18 19:02:58.800 (TV plug) 30 30 22 2c 22 31 30 31 22 3a 74 72 75 65 2c 22 31 30 34 22 00","101":true,"104"
2019-02-18 19:02:58.800 (TV plug) 3a 30 2c 22 31 30 35 22 3a 30 2c 22 31 30 36 22 3a 32 32 38 :0,"105":0,"106":228
2019-02-18 19:02:58.800 (TV plug) 39 7d 7d 2c 32 f4 93 00 00 aa 55 .. .. .. .. .. .. .. .. .. 9}},2��..�U
2019-02-18 19:02:58.800 (TV plug) Pushing 'onMessageCallback' on to queue
2019-02-18 19:02:58.800 (TV plug) Processing 'onMessageCallback' message
WITH DPS 1 (LED SWITCHING)
2019-02-18 19:04:02.001 (TV plug) Pushing 'WriteDirective' on to queue
2019-02-18 19:04:02.001 (TV plug) Processing 'onMessageCallback' message
2019-02-18 19:04:02.001 (TV plug) Calling message handler 'onMessage'.
2019-02-18 19:04:02.001 (TV plug) onMessage called: 192.168.1.102:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x01<\x00\x00\x00\x00{"devId":"12716401807d3a7b5c6b","dps":{"1":false,"2":"colour","3":180,"4":255,"5":"19171701531919","6":"00ff0000000000","7":"ffff500100ff00","8":"ffff8003ff000000ff000000ff000000000000000000","9":"ffff5001ff0000","10":"ffff0505ff000000ff00ffff00ff00ff0000ff000000","101":true,"104":0,"105":0,"106":2296}}\xb28@Q\x00\x00\xaaU'
2019-02-18 19:04:02.002 (TV plug) Updating device from 1:'On' to have values 0:'Off'.
2019-02-18 19:04:02.014 (TV plug) Update TV plug: 0 - 'Off'
2019-02-18 19:04:02.014 (TV plug) Processing 'WriteDirective' message
2019-02-18 19:04:02.014 (TV plug) Pushing 'ReadEvent' on to queue
2019-02-18 19:04:02.015 (TV plug) Sending 86 bytes of data
2019-02-18 19:04:02.015 (TV plug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 67 77 ..U�...........F{"gw
2019-02-18 19:04:02.015 (TV plug) 49 64 22 3a 22 31 32 37 31 36 34 30 31 38 30 37 64 33 61 37 Id":"12716401807d3a7
2019-02-18 19:04:02.015 (TV plug) 62 35 63 36 62 22 2c 22 64 65 76 49 64 22 3a 22 31 32 37 31 b5c6b","devId":"1271
2019-02-18 19:04:02.015 (TV plug) 36 34 30 31 38 30 37 64 33 61 37 62 35 63 36 62 22 7d 00 00 6401807d3a7b5c6b"}..
2019-02-18 19:04:02.015 (TV plug) 00 00 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. ....�U
2019-02-18 19:04:02.015 (TV plug) Processing 'ReadEvent' message
2019-02-18 19:04:02.015 (TV plug) Received 183 bytes of data
2019-02-18 19:04:02.016 (TV plug) 00 00 55 aa 00 00 00 00 00 00 00 07 00 00 00 0c 00 00 00 00 ..U�................
2019-02-18 19:04:02.016 (TV plug) 78 93 70 91 00 00 aa 55 00 00 55 aa 00 00 00 00 00 00 00 08 x�p�..�U..U�........
2019-02-18 19:04:02.016 (TV plug) 00 00 00 8b 00 00 00 00 33 2e 31 32 61 64 31 39 32 39 62 36 ...�....3.12ad1929b6
2019-02-18 19:04:02.016 (TV plug) 34 31 36 32 35 36 66 2b 5a 68 67 79 73 66 71 5a 4e 45 46 6c 416256f+ZhgysfqZNEFl
2019-02-18 19:04:02.016 (TV plug) 61 30 37 38 52 61 61 37 50 79 4f 63 69 30 63 71 46 6f 43 49 a078Raa7PyOci0cqFoCI
2019-02-18 19:04:02.016 (TV plug) 4a 66 4b 49 59 6c 4c 32 6c 61 34 35 42 4b 45 38 74 69 34 30 JfKIYlL2la45BKE8ti40
2019-02-18 19:04:02.016 (TV plug) 37 54 68 6d 70 69 72 38 70 70 58 4f 56 59 32 47 72 59 6a 2f 7Thmpir8ppXOVY2GrYj/
2019-02-18 19:04:02.016 (TV plug) 6e 31 48 6e 70 74 54 34 4b 6e 52 42 61 76 68 55 48 79 62 79 n1HnptT4KnRBavhUHyby
2019-02-18 19:04:02.016 (TV plug) 43 74 4d 35 45 55 56 67 6b 69 4c 55 6e 73 3d 8e ac e2 8c 00 CtM5EUVgkiLUns=���.
2019-02-18 19:04:02.016 (TV plug) 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .�U
2019-02-18 19:04:02.016 (TV plug) Pushing 'onMessageCallback' on to queue
2019-02-18 19:04:02.017 (TV plug) Processing 'onMessageCallback' message
2019-02-18 19:04:02.017 (TV plug) Calling message handler 'onMessage'.
2019-02-18 19:04:02.017 (TV plug) onMessage called: 192.168.1.102:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x07\x00\x00\x00\x0c\x00\x00\x00\x00x\x93p\x91\x00\x00\xaaU\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\x08\x00\x00\x00\x8b\x00\x00\x00\x003.12ad1929b6416256f+ZhgysfqZNEFla078Raa7PyOci0cqFoCIJfKIYlL2la45BKE8ti407Thmpir8ppXOVY2GrYj/n1HnptT4KnRBavhUHybyCtM5EUVgkiLUns=\x8e\xac\xe2\x8c\x00\x00\xaaU'
2019-02-18 19:04:02.021 (TV plug) Pushing 'ReadEvent' on to queue
2019-02-18 19:04:02.067 (TV plug) Processing 'ReadEvent' message
2019-02-18 19:04:02.067 (TV plug) Received 332 bytes of data
2019-02-18 19:04:02.067 (TV plug) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 01 3c 00 00 00 00 ..U�...........<....
2019-02-18 19:04:02.067 (TV plug) 7b 22 64 65 76 49 64 22 3a 22 31 32 37 31 36 34 30 31 38 30 {"devId":"1271640180
2019-02-18 19:04:02.067 (TV plug) 37 64 33 61 37 62 35 63 36 62 22 2c 22 64 70 73 22 3a 7b 22 7d3a7b5c6b","dps":{"
2019-02-18 19:04:02.068 (TV plug) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 22 63 6f 6c 6f 75 72 1":false,"2":"colour
2019-02-18 19:04:02.068 (TV plug) 22 2c 22 33 22 3a 31 38 30 2c 22 34 22 3a 32 35 35 2c 22 35 ","3":180,"4":255,"5
2019-02-18 19:04:02.068 (TV plug) 22 3a 22 31 39 31 37 31 37 30 31 35 33 31 39 31 39 22 2c 22 ":"19171701531919","
2019-02-18 19:04:02.068 (TV plug) 36 22 3a 22 30 30 66 66 30 30 30 30 30 30 30 30 30 30 22 2c 6":"00ff0000000000",
2019-02-18 19:04:02.068 (TV plug) 22 37 22 3a 22 66 66 66 66 35 30 30 31 30 30 66 66 30 30 22 "7":"ffff500100ff00"
2019-02-18 19:04:02.068 (TV plug) 2c 22 38 22 3a 22 66 66 66 66 38 30 30 33 66 66 30 30 30 30 ,"8":"ffff8003ff0000
2019-02-18 19:04:02.068 (TV plug) 30 30 66 66 30 30 30 30 30 30 66 66 30 30 30 30 30 30 30 30 00ff000000ff00000000
2019-02-18 19:04:02.068 (TV plug) 30 30 30 30 30 30 30 30 30 30 22 2c 22 39 22 3a 22 66 66 66 0000000000","9":"fff
2019-02-18 19:04:02.068 (TV plug) 66 35 30 30 31 66 66 30 30 30 30 22 2c 22 31 30 22 3a 22 66 f5001ff0000","10":"f
2019-02-18 19:04:02.068 (TV plug) 66 66 66 30 35 30 35 66 66 30 30 30 30 30 30 66 66 30 30 66 fff0505ff000000ff00f
2019-02-18 19:04:02.069 (TV plug) 66 66 66 30 30 66 66 30 30 66 66 30 30 30 30 66 66 30 30 30 fff00ff00ff0000ff000
2019-02-18 19:04:02.069 (TV plug) 30 30 30 22 2c 22 31 30 31 22 3a 74 72 75 65 2c 22 31 30 34 000","101":true,"104
2019-02-18 19:04:02.069 (TV plug) 22 3a 30 2c 22 31 30 35 22 3a 30 2c 22 31 30 36 22 3a 32 32 ":0,"105":0,"106":22
2019-02-18 19:04:02.069 (TV plug) 39 36 7d 7d b2 38 40 51 00 00 aa 55 .. .. .. .. .. .. .. .. 96}}�8@Q..�U
2019-02-18 19:04:02.069 (TV plug) Pushing 'onMessageCallback' on to queue
2019-02-18 19:04:02.069 (TV plug) Processing 'onMessageCallback' message
2019-02-18 19:04:02.069 (TV plug) Calling message handler 'o
