Zigate - No feedback from devices
deve87
Post by deve87 »
running Zigate USB stabel 4.0 plugin
Got 4 Philip Hue bulbs and devices don't update status in Domoticz. When I turn on wall switch, light will go to 100%, but Domoticz stays in last info.
I also have a Elko GLED316 Zigbee dimmer. It works changed dim, On/Off from Domoticz. But when I do any changes on the dimmer. Domoticz don't get status, and stays on last value.
pipiche
Re: Zigate - No feedback from devices
Post by pipiche »
Not sur if I fully understand your issue.
On hue bulb you say when you power on , what happens if you use the corresponding Domoticz switch widget off/off or even level control ? Does it work ?
Do you have a remote connected to the bulb ? Can you switch off from the remote ? Does the Domoticz switch widget updated ?
Wiki is available here.
Zigbee for Domoticz FAQ
deve87
Post by deve87 »
When I got my Philip Hue Bridge connected to Domoticz. Every time I turned light Off from Domoticz, and then turned 230V wall switch Off and then On again. Hue bridge (and Domoticz) got a report that it was On again. Every time a Hue bulb looses power and regain power. It goes to 100%
Now, I just use Zigate. And when I do the same thing. Domoticz says it's Off, when it's On.
No problem when I just use Domoticz to control it.
And I got a Elko Zigbee dimmer, Domoticz can control it, no problem there. If I manually change dimming directly from the dimmer. Domoticz don't get that updated status.
pipiche
Post by pipiche »
If you have the possibility to switch to branch pre-4.1 , I beleive this reporting should be fixed. If not then we can work to fix it.
While switching to pre-4.1 branch you'll have to take attention has the plugin database must be moved manually into the Data plugin directory
deve87
Post by deve87 »
I'm know on 4.0.7 right?
And now I get feedback from Elko 316GLED dimmer. Only get status On/Off. Dimmer state is not reported. Same issues with Hue lights
pipiche
Post by pipiche »
I believe indeed you are on 4.0.7. As mentioned, the fix is on pre-4.1
deve87
Post by deve87 »
Sry. I forget to type I'm using 4.1 and some problem 😉
What do you mean by moving database manually?
pipiche
Post by pipiche »
when you are on the pre-4.1 branche (which is not the stable one).
You have read the file 00-UPGRADE-FROM-STABLE in order to move your plugin database to the right place.
deve87
Post by deve87 »
I'm sorry. Where do I find that file? :oops:
Edit: In Domoticz log. It says I'm in 4.1 and now, the dimmer reports dimming stat when I do changes on the dimmer it self.
Hue light are same as before
pipiche
Post by pipiche »
Could you tell me the output of the following command:
when in the plugin/Domoticz-Zigate folder
git status
Could you provide the Domoticz Log from the start of the Zigate plugin
deve87
Post by deve87 »
When I "git status"
[pi@Domoticz:~/domoticz/plugins/Domoticz-Zigate $ git status
On branch beta
Your branch is up-to-date with 'origin/beta'.
Untracked files:
  (use "git add ..." to include in what will be committed)
  DeviceList-24.txt
  DeviceList-24.txt_2019-02-15-16:56:24
  DeviceList-24.txt_2019-02-15-17:58:17
nothing added to commit but untracked files present (use "git add" to track)
And Domoticz Log
2019-02-15 19:30:28.784 Status: (Zigbee) Entering work loop.
2019-02-15 19:30:28.784 Status: (Zigbee) Initialized version beta-4.1, author 'zaraki673 pipiche38'
2019-02-15 19:30:28.849 Status: (Zigbee) onStart called - Zigate plugin Beta 4.1.x
2019-02-15 19:30:28.849 Status: (Zigbee) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-02-15 19:30:28.849 [GCC 6.3.0 20170516]
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzVersion: 4.9700
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzHash: a3a45906
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzBuildTime: 2018-06-23 16:24:51
2019-02-15 19:30:28.849 Status: (Zigbee) load PluginConf
2019-02-15 19:30:28.849 Status: (Zigbee) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 19:30:28.853 Status: (Zigbee) Plugin Database: DeviceList-24.txt
2019-02-15 19:30:28.866 Status: (Zigbee) load ListOfDevice
2019-02-15 19:30:28.896 Status: (Zigbee) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-24.txt : 7
2019-02-15 19:30:28.902 Status: (Zigbee) Check for Web update finished!
2019-02-15 19:30:28.903 Status: (Zigbee) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB1
2019-02-15 19:30:28.905 Status: (Zigbee) ZigateConf - Setting UTC Time to : 603574228
2019-02-15 19:30:28.906 Status: (Zigbee) Start network
2019-02-15 19:30:28.906 Status: (Zigbee) Zigate enter in discover mode for 60 Secs
2019-02-15 19:30:29.007 Status: (Zigbee) Major Version Num: 0002
2019-02-15 19:30:29.007 Status: (Zigbee) Installer Version Number: 030e
2019-02-15 19:30:29.108 Status: (Zigbee) Decode8015 : Number of devices recently active in Zigate = 4
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [00] DevID = 32 Network addr = b782 IEEE = 000d6f000e3d8bc7 RSSI = 101 Power = 01 HB = 49 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [01] DevID = 33 Network addr = 76a7 IEEE = 0017880102b352e4 RSSI = 045 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [02] DevID = 34 Network addr = 9c4c IEEE = 0017880102b356a6 RSSI = 076 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [03] DevID = 35 Network addr = cd6b IEEE = 0017880102218ab8 RSSI = 052 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:38.569 (Zigbee) Start Network status : Success
2019-02-15 19:30:38.772 (Zigbee) Ping - received
2019-02-15 19:30:38.467 Status: (Zigbee) Decode8009 : Zigate addresses ieee: 00158d0001ede98c , short addr: 0000
2019-02-15 19:30:38.467 Status: (Zigbee) Decode8009 - Network state UP, PANID: 4302 extPANID: 0xf0eda91da902d771 Channel: 11
2019-02-15 19:30:38.772 Status: (Zigbee) Permit Join is On
pipiche
Post by pipiche »
You are on the beta branch and not the pre-4.1 !
git pull
git checkout pre-4.1
git pull
and then follow the 00-UPGRADE-FROM-STABLE
- then power off the Hue, and power on
deve87
Post by deve87 »
Okay. I see now.
After that and moved DeviceList-24.txt in Data dir.
Plugin won't start
I only get this in Domoticz Log
2019-02-15 20:04:45.550 Status: (Zigbee) Entering work loop.
2019-02-15 20:04:45.551 Status: (Zigbee) Initialized version pre-4.1, author 'zaraki673 pipiche38'
pipiche
Post by pipiche »
Did you restart the plugin or Domoticz
But without logs I cannot really tell much
pipiche
Post by pipiche »
If after a Domoticz restart , remove the various __pycache__ folders under Domoticz-Zigate , Classes/ and Modules/
deve87
Post by deve87 »
That did not help.
I even tried to remove the folder (sudo rm -rf Domoticz-Zigate), reinstall, switched to pre-4.1 again and move my backup DeviceList to Data folder.
Same as before. It just stops after, and nothing more info in log..
pipiche
Post by pipiche »
And what is happening if switching back to beta branch ?
deve87
Post by deve87 »
Everything OK
2019-02-15 20:53:27.138 (Zigbee) PluginConf.txt = {'channel':'11,15,16,21,22','Ping':'1','self.eraseZigatePDM':'0','vibrationAqarasensitivity':'medium','resetMotiondelay':'30','enablegroupmanagement':'0','allowRemoveZigateDevice':'0','allowStoreDiscoveryFrames':'0','logLQI':'0','logFORMAT':'0'}
2019-02-15 20:53:27.139 (Zigbee) Device Management:
2019-02-15 20:53:27.139 (Zigbee) -allowStoreDiscoveryFrames : 0
2019-02-15 20:53:27.139 (Zigbee) -allowForceCreationDomoDevice: 0
2019-02-15 20:53:27.139 (Zigbee) -forceConfigureReporting: 0
2019-02-15 20:53:27.139 (Zigbee) -forceReadAttributes: 0
2019-02-15 20:53:27.139 (Zigbee) -resetMotiondelay: 30
2019-02-15 20:53:27.139 (Zigbee) -vibrationAqarasensitivity: medium
2019-02-15 20:53:27.139 (Zigbee) Zigate Configuration
2019-02-15 20:53:27.139 (Zigbee) -channel: ['11', '15', '16', '21', '22']
2019-02-15 20:53:27.139 (Zigbee) -allowRemoveZigateDevice: 0
2019-02-15 20:53:27.139 (Zigbee) -eraseZigatePDM: 0
2019-02-15 20:53:27.139 (Zigbee) -blueLedOff: 0
2019-02-15 20:53:27.139 (Zigbee) -TXpower: 0
2019-02-15 20:53:27.139 (Zigbee) Plugin Transport
2019-02-15 20:53:27.139 (Zigbee) -zmode: ZigBee
2019-02-15 20:53:27.139 (Zigbee) -reTransmit: 1
2019-02-15 20:53:27.139 (Zigbee) -zTimeOut: 2
2019-02-15 20:53:27.139 (Zigbee) -CrcCheck: 1
2019-02-15 20:53:27.139 (Zigbee) -sendDelay: 0
2019-02-15 20:53:27.139 (Zigbee) -Ping: 1
2019-02-15 20:53:27.139 (Zigbee) Plugin Directories
2019-02-15 20:53:27.139 (Zigbee) -pluginHome: /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-02-15 20:53:27.139 (Zigbee) -pluginData: /home/pi/domoticz/plugins/Domoticz-Zigate/./
2019-02-15 20:53:27.139 (Zigbee) -pluginZData: /home/pi/domoticz/plugins/Domoticz-Zigate/./Zdatas/
2019-02-15 20:53:27.139 (Zigbee) -pluginReports: /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates/zigate/reports/
2019-02-15 20:53:27.139 (Zigbee) -pluginConfig: /home/pi/domoticz/plugins/Domoticz-Zigate/./
2019-02-15 20:53:27.139 (Zigbee) -pluginWWW: /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates/
2019-02-15 20:53:27.139 (Zigbee) -homedirectory: /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-02-15 20:53:27.139 (Zigbee) -filename: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 20:53:27.139 (Zigbee) Groups Management
2019-02-15 20:53:27.140 (Zigbee) -enablegroupmanagement: 0
2019-02-15 20:53:27.140 (Zigbee) -discoverZigateGroups: 1
2019-02-15 20:53:27.140 (Zigbee) -enableConfigGroups: 1
2019-02-15 20:53:27.140 (Zigbee) Reportings and Statistics
2019-02-15 20:53:27.140 (Zigbee) -logLQI: 0
2019-02-15 20:53:27.140 (Zigbee) -networkScan: 0
2019-02-15 20:53:27.141 (Zigbee) createStatusWidget - existing 6 -> Zigate-02-24
2019-02-15 20:53:27.141 (Zigbee) createNotificationWidget - existing 7 -> Zigate-03-24
2019-02-15 20:53:27.173 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b352e4 for NetworkID = 76a7
2019-02-15 20:53:27.176 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b354db for NetworkID = 0eba
2019-02-15 20:53:27.179 (Zigbee) CheckDeviceList - DeviceID (IEEE) = d0cf5efffe40f8a2 for NetworkID = 30f7
2019-02-15 20:53:27.185 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 000d6f000e3d8bc7 for NetworkID = b782
2019-02-15 20:53:27.188 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b356a6 for NetworkID = 9c4c
2019-02-15 20:53:27.193 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102218ab8 for NetworkID = cd6b
2019-02-15 20:53:27.195 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 00178801023f468a for NetworkID = e651
2019-02-15 20:53:27.196 (Zigbee) ListOfDevices :
2019-02-15 20:53:27.196 (Zigbee) ('30f7', {'Stamp': {'MsgType': '8102', 'Time': '2019-02-14 18:25:11'}, 'ZDeviceID': '0850', 'App Version': '17', 'IEEE': 'd0cf5efffe40f8a2', 'SQN': 'a1', 'NbEp': '1', 'RIA': '1', 'MacCapa': '80', 'HW Version': '1', 'Stack Version': '87', 'Battery': {}, 'Heartbeat': '13534', 'ProfileID': 'c05e', 'Model': 'TRADFRI motion sensor', 'Ep': {'01': {'0b05': {}, '0009': {}, '1000': {}, '0001': {}, '0019': {}, '0004': {}, '0003': {}, '0000': {}, 'ClusterType': {'1355': 'Voltage', '1354': 'Switch'}, '0006': {}}}, 'Version': '3', 'RSSI': 228, 'Type': 'Switch/Voltage/', 'Status': 'inDB', 'ReadAttributes': {'Ep': {'01': {'0000': {'0007': '00', '0003': '00', '0010': '86', '0001': '00', '0004': '00', '0002': '00', '0005': '00'}, '0001': {'0007': '86', '0021': '00', '0003': '86', '0001': '86', '0020': '00', '0004': '86', '0002': '86', '0000': '86', '0005': '86', '0006': '86'}}}}})
2019-02-15 20:53:27.196 (Zigbee) ('76a7', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 41, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b352e4', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '4562', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1351': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.196 (Zigbee) ('b782', {'ConfigureReporting': {'Ep': {'01': {'0003': {}, '0000': {}, '0008': '', '0006': '00'}}}, 'MacCapa': '8e', 'SQN': {}, 'HW Version': '1', 'Type': 'LvlControl/Switch/', 'Manufacturer': '1002', 'LogicalType': 'Router', 'RSSI': 99, 'Version': '3', 'Stamp': {'MsgType': '8102', 'Time': '2019-02-15 14:14:18'}, 'DeviceType': 'FFD', 'ZDeviceID': '0101', 'App Version': '0', 'IEEE': '000d6f000e3d8bc7', 'NbEp': '1', 'RIA': '0', 'Battery': {}, 'Heartbeat': '1484', 'ProfileID': '0104', 'Model': 'ElkoDimmerZHA', 'Ep': {'01': {'0003': {}, '0000': {}, 'ClusterType': {'1353': 'LvlControl'}, '0008': {}, '0006': '01'}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {'0007': '00', '0003': '00', '0010': '86', '0001': '00', '0004': '00', '0002': '86', '0005': '00'}, '0001': {'0007': '86', '0021': '86', '0003': '86', '0001': '86', '0020': '86', '0004': '86', '0002': '86', '0000': '86', '0005': '86', '0006': '86'}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.196 (Zigbee) ('0eba', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': {}, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b354db', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '26638', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1352': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('9c4c', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 73, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b356a6', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '4562', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1349': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('cd6b', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0300': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/ColorControl/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 39, 'Version': '3', 'Stamp': {'MsgType': '8102', 'Time': '2019-02-14 07:32:22'}, 'DeviceType': 'FFD', 'ZDeviceID': '0220', 'IEEE': '0017880102218ab8', 'NbEp': '2', 'RIA': '2', 'Battery': {}, 'Heartbeat': '4563', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1352': 'ColorControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0300': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ColorInfos': {'ColorMode': 2, 'X': '29980', 'ColorTemperatureMireds': '366', 'Y': '26875'}, 'ReadAttributes': {'Ep': {'0b': {'0300': {'0007': '00', '0000': '86', '0001': '86', '0004': '00', '0003': '00', '0006': '86', '0005': '86', '0008': '00'}}, '01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('e651', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 55, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '00178801023f468a', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '2337', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1350': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.199 (Zigbee) web source dir : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/
2019-02-15 20:53:27.200 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/reports
2019-02-15 20:53:27.200 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/reports
2019-02-15 20:53:27.200 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js
2019-02-15 20:53:27.200 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js
2019-02-15 20:53:27.200 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js's version
2019-02-15 20:53:27.202 (Zigbee) firstline : ///version:6;
2019-02-15 20:53:27.202 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js version is : 6
2019-02-15 20:53:27.202 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js's version
2019-02-15 20:53:27.203 (Zigbee) firstline : ///version:6;
2019-02-15 20:53:27.204 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js version is : 6
2019-02-15 20:53:27.204 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css
2019-02-15 20:53:27.204 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css
2019-02-15 20:53:27.204 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css's version
2019-02-15 20:53:27.205 (Zigbee) firstline : /*version:1;*/
2019-02-15 20:53:27.205 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css version is : 1
2019-02-15 20:53:27.205 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css's version
2019-02-15 20:53:27.206 (Zigbee) firstline : /*version:1;*/
2019-02-15 20:53:27.206 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css version is : 1
2019-02-15 20:53:27.206 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate.html's version
2019-02-15 20:53:27.207 (Zigbee) firstline : <!--version:1;-->
2019-02-15 20:53:27.207 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate.html version is : 1
2019-02-15 20:53:27.207 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate.html's version
2019-02-15 20:53:27.208 (Zigbee) firstline : <!--version:1;-->
2019-02-15 20:53:27.208 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate.html version is : 1
2019-02-15 20:53:27.208 (Zigbee) Establish Zigate connection
2019-02-15 20:53:27.254 (Zigbee) Connected successfully
2019-02-15 20:53:27.071 Status: (Zigbee) Entering work loop.
2019-02-15 20:53:27.072 Status: (Zigbee) Initialized version beta-4.1, author 'zaraki673 pipiche38'
2019-02-15 20:53:27.136 Status: (Zigbee) onStart called - Zigate plugin Beta 4.1.x
2019-02-15 20:53:27.136 Status: (Zigbee) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-02-15 20:53:27.136 [GCC 6.3.0 20170516]
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzVersion: 4.9700
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzHash: a3a45906
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzBuildTime: 2018-06-23 16:24:51
2019-02-15 20:53:27.137 Status: (Zigbee) load PluginConf
2019-02-15 20:53:27.137 Status: (Zigbee) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 20:53:27.146 Status: (Zigbee) Plugin Database: DeviceList-24.txt
2019-02-15 20:53:27.159 Status: (Zigbee) load ListOfDevice
2019-02-15 20:53:27.182 Status: (Zigbee) Not Loading 767f as Status: UNKNOW
2019-02-15 20:53:27.189 Status: (Zigbee) Not Loading 747d as Status: UNKNOW
2019-02-15 20:53:27.195 Status: (Zigbee) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-24.txt : 9
2019-02-15 20:53:27.208 Status: (Zigbee) Check for Web update finished!
2019-02-15 20:53:27.208 Status: (Zigbee) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB1
2019-02-15 20:53:27.255 Status: (Zigbee) ZigateConf - Setting UTC Time to : 603579207
2019-02-15 20:53:27.255 Status: (Zigbee) Start network
2019-02-15 20:53:27.255 Status: (Zigbee) Zigate enter in discover mode for 60 Secs
2019-02-15 20:53:27.357 Status: (Zigbee) Major Version Num: 0002
2019-02-15 20:53:27.357 Status: (Zigbee) Installer Version Number: 030e
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : Number of devices recently active in Zigate = 4
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : [00] DevID = 32 Network addr = b782 IEEE = 000d6f000e3d8bc7 RSSI = 096 Power = 01 HB = 1484 found in ListOfDevices
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : [01] DevID = 33 Network addr = 76a7 IEEE = 0017880102b352e4 RSSI = 058 Power = 01 HB = 4562 found in ListOfDevices
2019-02-15 20:53:27.459 Status: (Zigbee) Decode8015 : [02] DevID = 34 Network addr = 9c4c IEEE = 0017880102b356a6 RSSI = 075 Power = 01 HB = 4562 found in ListOfDevices
2019-02-15 20:53:27.459 Status: (Zigbee) Decode8015 : [03] DevID = 35 Network addr = cd6b IEEE = 0017880102218ab8 RSSI = 123 Power = 01 HB = 4563 found in ListOfDevices
2019-02-15 20:53:36.880 (Zigbee) Start Network status : Success
2019-02-15 20:53:36.778 Status: (Zigbee) Decode8009 : Zigate addresses ieee: 00158d0001ede98c , short addr: 0000
2019-02-15 20:53:36.778 Status: (Zigbee) Decode8009 - Network state UP, PANID: 4302 extPANID: 0xf0eda91da902d771 Channel: 11
2019-02-15 20:53:37.082 (Zigbee) Ping - received
2019-02-15 20:53:37.082 Status: (Zigbee) Permit Join is On
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Management Network Update. SQN: 00, Total Transmit: 29 , Transmit Failures: 9 , Status: Success)
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 11 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 12 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 13 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 14 Interference: : 175
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 15 Interference: : 167
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 16 Interference: : 174
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 17 Interference: : 180
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 18 Interference: : 169
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 19 Interference: : 185
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 20 Interference: : 166
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 21 Interference: : 161
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 22 Interference: : 164
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 23 Interference: : 165
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 24 Interference: : 163
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 25 Interference: : 165
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 26 Interference: : 162
pipiche
Post by pipiche »
With which version pré-4-1? What did you do ?
deve87
Post by deve87 »
No. It's Beta 4.1 now.
