Zigate - No feedback from devices
running Zigate USB stabel 4.0 plugin
Got 4 Philip Hue bulbs and devices don't update status in Domoticz. When I turn on wall switch, light will go to 100%, but Domoticz stays in last info.
I also have a Elko GLED316 Zigbee dimmer. It works changed dim, On/Off from Domoticz. But when I do any changes on the dimmer. Domoticz don't get status, and stays on last value.
Re: Zigate - No feedback from devices
Not sur if I fully understand your issue.
On hue bulb you say when you power on , what happens if you use the corresponding Domoticz switch widget off/off or even level control ? Does it work ?
Do you have a remote connected to the bulb ? Can you switch off from the remote ? Does the Domoticz switch widget updated ?
Wiki is available here.
Zigbee for Domoticz FAQ
When I got my Philip Hue Bridge connected to Domoticz. Every time I turned light Off from Domoticz, and then turned 230V wall switch Off and then On again. Hue bridge (and Domoticz) got a report that it was On again. Every time a Hue bulb looses power and regain power. It goes to 100%
Now, I just use Zigate. And when I do the same thing. Domoticz says it's Off, when it's On.
No problem when I just use Domoticz to control it.
And I got a Elko Zigbee dimmer, Domoticz can control it, no problem there. If I manually change dimming directly from the dimmer. Domoticz don't get that updated status.
If you have the possibility to switch to branch pre-4.1 , I beleive this reporting should be fixed. If not then we can work to fix it.
While switching to pre-4.1 branch you'll have to take attention has the plugin database must be moved manually into the Data plugin directory
I'm know on 4.0.7 right?
And now I get feedback from Elko 316GLED dimmer. Only get status On/Off. Dimmer state is not reported. Same issues with Hue lights
I believe indeed you are on 4.0.7. As mentioned, the fix is on pre-4.1
Sry. I forget to type I'm using 4.1 and some problem
What do you mean by moving database manually?
when you are on the pre-4.1 branche (which is not the stable one).
You have read the file 00-UPGRADE-FROM-STABLE in order to move your plugin database to the right place.
I'm sorry. Where do I find that file?
Edit: In Domoticz log. It says I'm in 4.1 and now, the dimmer reports dimming stat when I do changes on the dimmer it self.
Hue light are same as before
Could you tell me the output of the following command:
when in the plugin/Domoticz-Zigate folder
Could you provide the Domoticz Log from the start of the Zigate plugin
git status
When I "git status"
And Domoticz Log
[pi@Domoticz:~/domoticz/plugins/Domoticz-Zigate $ git status
On branch beta
Your branch is up-to-date with 'origin/beta'.
Untracked files:
(use "git add ..." to include in what will be committed)
DeviceList-24.txt
DeviceList-24.txt_2019-02-15-16:56:24
DeviceList-24.txt_2019-02-15-17:58:17
nothing added to commit but untracked files present (use "git add" to track)
2019-02-15 19:30:28.784 Status: (Zigbee) Entering work loop.
2019-02-15 19:30:28.784 Status: (Zigbee) Initialized version beta-4.1, author 'zaraki673 pipiche38'
2019-02-15 19:30:28.849 Status: (Zigbee) onStart called - Zigate plugin Beta 4.1.x
2019-02-15 19:30:28.849 Status: (Zigbee) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-02-15 19:30:28.849 [GCC 6.3.0 20170516]
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzVersion: 4.9700
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzHash: a3a45906
2019-02-15 19:30:28.849 Status: (Zigbee) DomoticzBuildTime: 2018-06-23 16:24:51
2019-02-15 19:30:28.849 Status: (Zigbee) load PluginConf
2019-02-15 19:30:28.849 Status: (Zigbee) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 19:30:28.853 Status: (Zigbee) Plugin Database: DeviceList-24.txt
2019-02-15 19:30:28.866 Status: (Zigbee) load ListOfDevice
2019-02-15 19:30:28.896 Status: (Zigbee) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-24.txt : 7
2019-02-15 19:30:28.902 Status: (Zigbee) Check for Web update finished!
2019-02-15 19:30:28.903 Status: (Zigbee) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB1
2019-02-15 19:30:28.905 Status: (Zigbee) ZigateConf - Setting UTC Time to : 603574228
2019-02-15 19:30:28.906 Status: (Zigbee) Start network
2019-02-15 19:30:28.906 Status: (Zigbee) Zigate enter in discover mode for 60 Secs
2019-02-15 19:30:29.007 Status: (Zigbee) Major Version Num: 0002
2019-02-15 19:30:29.007 Status: (Zigbee) Installer Version Number: 030e
2019-02-15 19:30:29.108 Status: (Zigbee) Decode8015 : Number of devices recently active in Zigate = 4
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [00] DevID = 32 Network addr = b782 IEEE = 000d6f000e3d8bc7 RSSI = 101 Power = 01 HB = 49 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [01] DevID = 33 Network addr = 76a7 IEEE = 0017880102b352e4 RSSI = 045 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [02] DevID = 34 Network addr = 9c4c IEEE = 0017880102b356a6 RSSI = 076 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:29.109 Status: (Zigbee) Decode8015 : [03] DevID = 35 Network addr = cd6b IEEE = 0017880102218ab8 RSSI = 052 Power = 01 HB = 1144 found in ListOfDevices
2019-02-15 19:30:38.569 (Zigbee) Start Network status : Success
2019-02-15 19:30:38.772 (Zigbee) Ping - received
2019-02-15 19:30:38.467 Status: (Zigbee) Decode8009 : Zigate addresses ieee: 00158d0001ede98c , short addr: 0000
2019-02-15 19:30:38.467 Status: (Zigbee) Decode8009 - Network state UP, PANID: 4302 extPANID: 0xf0eda91da902d771 Channel: 11
2019-02-15 19:30:38.772 Status: (Zigbee) Permit Join is On
You are on the beta branch and not the pre-4.1 !
and then follow the 00-UPGRADE-FROM-STABLE
- then power off the Hue, and power on
git pull
git checkout pre-4.1
git pull
Okay. I see now.
After that and moved DeviceList-24.txt in Data dir.
Plugin won't start
I only get this in Domoticz Log
Plugin won't start
2019-02-15 20:04:45.550 Status: (Zigbee) Entering work loop.
2019-02-15 20:04:45.551 Status: (Zigbee) Initialized version pre-4.1, author 'zaraki673 pipiche38'
Did you restart the plugin or Domoticz
But without logs I cannot really tell much
If after a Domoticz restart , remove the various __pycache__ folders under Domoticz-Zigate , Classes/ and Modules/
That did not help.
I even tried to remove the folder (sudo rm -rf Domoticz-Zigate), reinstall, switched to pre-4.1 again and move my backup DeviceList to Data folder.
Same as before. It just stops after, and nothing more info in log..
And what is happening if switching back to beta branch ?
Everything OK
2019-02-15 20:53:27.138 (Zigbee) PluginConf.txt = {'channel':'11,15,16,21,22','Ping':'1','self.eraseZigatePDM':'0','vibrationAqarasensitivity':'medium','resetMotiondelay':'30','enablegroupmanagement':'0','allowRemoveZigateDevice':'0','allowStoreDiscoveryFrames':'0','logLQI':'0','logFORMAT':'0'}
2019-02-15 20:53:27.139 (Zigbee) Device Management:
2019-02-15 20:53:27.139 (Zigbee) -allowStoreDiscoveryFrames : 0
2019-02-15 20:53:27.139 (Zigbee) -allowForceCreationDomoDevice: 0
2019-02-15 20:53:27.139 (Zigbee) -forceConfigureReporting: 0
2019-02-15 20:53:27.139 (Zigbee) -forceReadAttributes: 0
2019-02-15 20:53:27.139 (Zigbee) -resetMotiondelay: 30
2019-02-15 20:53:27.139 (Zigbee) -vibrationAqarasensitivity: medium
2019-02-15 20:53:27.139 (Zigbee) Zigate Configuration
2019-02-15 20:53:27.139 (Zigbee) -channel: ['11', '15', '16', '21', '22']
2019-02-15 20:53:27.139 (Zigbee) -allowRemoveZigateDevice: 0
2019-02-15 20:53:27.139 (Zigbee) -eraseZigatePDM: 0
2019-02-15 20:53:27.139 (Zigbee) -blueLedOff: 0
2019-02-15 20:53:27.139 (Zigbee) -TXpower: 0
2019-02-15 20:53:27.139 (Zigbee) Plugin Transport
2019-02-15 20:53:27.139 (Zigbee) -zmode: ZigBee
2019-02-15 20:53:27.139 (Zigbee) -reTransmit: 1
2019-02-15 20:53:27.139 (Zigbee) -zTimeOut: 2
2019-02-15 20:53:27.139 (Zigbee) -CrcCheck: 1
2019-02-15 20:53:27.139 (Zigbee) -sendDelay: 0
2019-02-15 20:53:27.139 (Zigbee) -Ping: 1
2019-02-15 20:53:27.139 (Zigbee) Plugin Directories
2019-02-15 20:53:27.139 (Zigbee) -pluginHome: /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-02-15 20:53:27.139 (Zigbee) -pluginData: /home/pi/domoticz/plugins/Domoticz-Zigate/./
2019-02-15 20:53:27.139 (Zigbee) -pluginZData: /home/pi/domoticz/plugins/Domoticz-Zigate/./Zdatas/
2019-02-15 20:53:27.139 (Zigbee) -pluginReports: /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates/zigate/reports/
2019-02-15 20:53:27.139 (Zigbee) -pluginConfig: /home/pi/domoticz/plugins/Domoticz-Zigate/./
2019-02-15 20:53:27.139 (Zigbee) -pluginWWW: /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates/
2019-02-15 20:53:27.139 (Zigbee) -homedirectory: /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-02-15 20:53:27.139 (Zigbee) -filename: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 20:53:27.139 (Zigbee) Groups Management
2019-02-15 20:53:27.140 (Zigbee) -enablegroupmanagement: 0
2019-02-15 20:53:27.140 (Zigbee) -discoverZigateGroups: 1
2019-02-15 20:53:27.140 (Zigbee) -enableConfigGroups: 1
2019-02-15 20:53:27.140 (Zigbee) Reportings and Statistics
2019-02-15 20:53:27.140 (Zigbee) -logLQI: 0
2019-02-15 20:53:27.140 (Zigbee) -networkScan: 0
2019-02-15 20:53:27.141 (Zigbee) createStatusWidget - existing 6 -> Zigate-02-24
2019-02-15 20:53:27.141 (Zigbee) createNotificationWidget - existing 7 -> Zigate-03-24
2019-02-15 20:53:27.173 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b352e4 for NetworkID = 76a7
2019-02-15 20:53:27.176 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b354db for NetworkID = 0eba
2019-02-15 20:53:27.179 (Zigbee) CheckDeviceList - DeviceID (IEEE) = d0cf5efffe40f8a2 for NetworkID = 30f7
2019-02-15 20:53:27.185 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 000d6f000e3d8bc7 for NetworkID = b782
2019-02-15 20:53:27.188 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102b356a6 for NetworkID = 9c4c
2019-02-15 20:53:27.193 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 0017880102218ab8 for NetworkID = cd6b
2019-02-15 20:53:27.195 (Zigbee) CheckDeviceList - DeviceID (IEEE) = 00178801023f468a for NetworkID = e651
2019-02-15 20:53:27.196 (Zigbee) ListOfDevices :
2019-02-15 20:53:27.196 (Zigbee) ('30f7', {'Stamp': {'MsgType': '8102', 'Time': '2019-02-14 18:25:11'}, 'ZDeviceID': '0850', 'App Version': '17', 'IEEE': 'd0cf5efffe40f8a2', 'SQN': 'a1', 'NbEp': '1', 'RIA': '1', 'MacCapa': '80', 'HW Version': '1', 'Stack Version': '87', 'Battery': {}, 'Heartbeat': '13534', 'ProfileID': 'c05e', 'Model': 'TRADFRI motion sensor', 'Ep': {'01': {'0b05': {}, '0009': {}, '1000': {}, '0001': {}, '0019': {}, '0004': {}, '0003': {}, '0000': {}, 'ClusterType': {'1355': 'Voltage', '1354': 'Switch'}, '0006': {}}}, 'Version': '3', 'RSSI': 228, 'Type': 'Switch/Voltage/', 'Status': 'inDB', 'ReadAttributes': {'Ep': {'01': {'0000': {'0007': '00', '0003': '00', '0010': '86', '0001': '00', '0004': '00', '0002': '00', '0005': '00'}, '0001': {'0007': '86', '0021': '00', '0003': '86', '0001': '86', '0020': '00', '0004': '86', '0002': '86', '0000': '86', '0005': '86', '0006': '86'}}}}})
2019-02-15 20:53:27.196 (Zigbee) ('76a7', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 41, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b352e4', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '4562', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1351': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.196 (Zigbee) ('b782', {'ConfigureReporting': {'Ep': {'01': {'0003': {}, '0000': {}, '0008': '', '0006': '00'}}}, 'MacCapa': '8e', 'SQN': {}, 'HW Version': '1', 'Type': 'LvlControl/Switch/', 'Manufacturer': '1002', 'LogicalType': 'Router', 'RSSI': 99, 'Version': '3', 'Stamp': {'MsgType': '8102', 'Time': '2019-02-15 14:14:18'}, 'DeviceType': 'FFD', 'ZDeviceID': '0101', 'App Version': '0', 'IEEE': '000d6f000e3d8bc7', 'NbEp': '1', 'RIA': '0', 'Battery': {}, 'Heartbeat': '1484', 'ProfileID': '0104', 'Model': 'ElkoDimmerZHA', 'Ep': {'01': {'0003': {}, '0000': {}, 'ClusterType': {'1353': 'LvlControl'}, '0008': {}, '0006': '01'}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {'0007': '00', '0003': '00', '0010': '86', '0001': '00', '0004': '00', '0002': '86', '0005': '00'}, '0001': {'0007': '86', '0021': '86', '0003': '86', '0001': '86', '0020': '86', '0004': '86', '0002': '86', '0000': '86', '0005': '86', '0006': '86'}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.196 (Zigbee) ('0eba', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': {}, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b354db', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '26638', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1352': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('9c4c', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 73, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '0017880102b356a6', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '4562', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1349': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('cd6b', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0300': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/ColorControl/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 39, 'Version': '3', 'Stamp': {'MsgType': '8102', 'Time': '2019-02-14 07:32:22'}, 'DeviceType': 'FFD', 'ZDeviceID': '0220', 'IEEE': '0017880102218ab8', 'NbEp': '2', 'RIA': '2', 'Battery': {}, 'Heartbeat': '4563', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1352': 'ColorControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0300': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ColorInfos': {'ColorMode': 2, 'X': '29980', 'ColorTemperatureMireds': '366', 'Y': '26875'}, 'ReadAttributes': {'Ep': {'0b': {'0300': {'0007': '00', '0000': '86', '0001': '86', '0004': '00', '0003': '00', '0006': '86', '0005': '86', '0008': '00'}}, '01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.197 (Zigbee) ('e651', {'ConfigureReporting': {'Ep': {'0b': {'0000': {}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': ''}}}, 'MacCapa': '8e', 'SQN': {}, 'Type': 'LvlControl/Switch/', 'Manufacturer': '100b', 'LogicalType': 'Router', 'RSSI': 55, 'Version': '3', 'DeviceType': 'FFD', 'ZDeviceID': '0100', 'IEEE': '00178801023f468a', 'NbEp': '2', 'RIA': '0', 'Battery': {}, 'Heartbeat': '2337', 'ProfileID': 'c05e', 'Model': {}, 'Ep': {'0b': {'0000': {}, 'ClusterType': {'1350': 'LvlControl'}, '1000': {}, '0019': {}, '0004': {}, '0003': {}, '0006': {}, '0005': {}, '0008': {}}, 'f2': {'0021': {}, 'ClusterType': {}}}, 'ReceiveOnIdle': 'On', 'ReadAttributes': {'Ep': {'01': {'0000': {}, '0001': {}}}}, 'Status': 'inDB', 'PowerSource': 'Main'})
2019-02-15 20:53:27.199 (Zigbee) web source dir : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/
2019-02-15 20:53:27.200 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/reports
2019-02-15 20:53:27.200 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/reports
2019-02-15 20:53:27.200 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js
2019-02-15 20:53:27.200 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js
2019-02-15 20:53:27.200 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js's version
2019-02-15 20:53:27.202 (Zigbee) firstline : ///version:6;
2019-02-15 20:53:27.202 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.js version is : 6
2019-02-15 20:53:27.202 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js's version
2019-02-15 20:53:27.203 (Zigbee) firstline : ///version:6;
2019-02-15 20:53:27.204 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.js version is : 6
2019-02-15 20:53:27.204 (Zigbee) Old file : /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css
2019-02-15 20:53:27.204 (Zigbee) New file : /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css
2019-02-15 20:53:27.204 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css's version
2019-02-15 20:53:27.205 (Zigbee) firstline : /*version:1;*/
2019-02-15 20:53:27.205 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate/zigate.css version is : 1
2019-02-15 20:53:27.205 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css's version
2019-02-15 20:53:27.206 (Zigbee) firstline : /*version:1;*/
2019-02-15 20:53:27.206 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate/zigate.css version is : 1
2019-02-15 20:53:27.206 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate.html's version
2019-02-15 20:53:27.207 (Zigbee) firstline : <!--version:1;-->
2019-02-15 20:53:27.207 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/www/zigate.html version is : 1
2019-02-15 20:53:27.207 (Zigbee) Reading /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate.html's version
2019-02-15 20:53:27.208 (Zigbee) firstline : <!--version:1;-->
2019-02-15 20:53:27.208 (Zigbee) /home/pi/domoticz/plugins/Domoticz-Zigate/../../www/templates//zigate.html version is : 1
2019-02-15 20:53:27.208 (Zigbee) Establish Zigate connection
2019-02-15 20:53:27.254 (Zigbee) Connected successfully
2019-02-15 20:53:27.071 Status: (Zigbee) Entering work loop.
2019-02-15 20:53:27.072 Status: (Zigbee) Initialized version beta-4.1, author 'zaraki673 pipiche38'
2019-02-15 20:53:27.136 Status: (Zigbee) onStart called - Zigate plugin Beta 4.1.x
2019-02-15 20:53:27.136 Status: (Zigbee) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-02-15 20:53:27.136 [GCC 6.3.0 20170516]
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzVersion: 4.9700
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzHash: a3a45906
2019-02-15 20:53:27.136 Status: (Zigbee) DomoticzBuildTime: 2018-06-23 16:24:51
2019-02-15 20:53:27.137 Status: (Zigbee) load PluginConf
2019-02-15 20:53:27.137 Status: (Zigbee) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/PluginConf.txt
2019-02-15 20:53:27.146 Status: (Zigbee) Plugin Database: DeviceList-24.txt
2019-02-15 20:53:27.159 Status: (Zigbee) load ListOfDevice
2019-02-15 20:53:27.182 Status: (Zigbee) Not Loading 767f as Status: UNKNOW
2019-02-15 20:53:27.189 Status: (Zigbee) Not Loading 747d as Status: UNKNOW
2019-02-15 20:53:27.195 Status: (Zigbee) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-24.txt : 9
2019-02-15 20:53:27.208 Status: (Zigbee) Check for Web update finished!
2019-02-15 20:53:27.208 Status: (Zigbee) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB1
2019-02-15 20:53:27.255 Status: (Zigbee) ZigateConf - Setting UTC Time to : 603579207
2019-02-15 20:53:27.255 Status: (Zigbee) Start network
2019-02-15 20:53:27.255 Status: (Zigbee) Zigate enter in discover mode for 60 Secs
2019-02-15 20:53:27.357 Status: (Zigbee) Major Version Num: 0002
2019-02-15 20:53:27.357 Status: (Zigbee) Installer Version Number: 030e
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : Number of devices recently active in Zigate = 4
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : [00] DevID = 32 Network addr = b782 IEEE = 000d6f000e3d8bc7 RSSI = 096 Power = 01 HB = 1484 found in ListOfDevices
2019-02-15 20:53:27.458 Status: (Zigbee) Decode8015 : [01] DevID = 33 Network addr = 76a7 IEEE = 0017880102b352e4 RSSI = 058 Power = 01 HB = 4562 found in ListOfDevices
2019-02-15 20:53:27.459 Status: (Zigbee) Decode8015 : [02] DevID = 34 Network addr = 9c4c IEEE = 0017880102b356a6 RSSI = 075 Power = 01 HB = 4562 found in ListOfDevices
2019-02-15 20:53:27.459 Status: (Zigbee) Decode8015 : [03] DevID = 35 Network addr = cd6b IEEE = 0017880102218ab8 RSSI = 123 Power = 01 HB = 4563 found in ListOfDevices
2019-02-15 20:53:36.880 (Zigbee) Start Network status : Success
2019-02-15 20:53:36.778 Status: (Zigbee) Decode8009 : Zigate addresses ieee: 00158d0001ede98c , short addr: 0000
2019-02-15 20:53:36.778 Status: (Zigbee) Decode8009 - Network state UP, PANID: 4302 extPANID: 0xf0eda91da902d771 Channel: 11
2019-02-15 20:53:37.082 (Zigbee) Ping - received
2019-02-15 20:53:37.082 Status: (Zigbee) Permit Join is On
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Management Network Update. SQN: 00, Total Transmit: 29 , Transmit Failures: 9 , Status: Success)
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 11 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 12 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 13 Interference: : 173
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 14 Interference: : 175
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 15 Interference: : 167
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 16 Interference: : 174
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 17 Interference: : 180
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 18 Interference: : 169
2019-02-15 20:54:42.024 Status: (Zigbee) Decode804A - Channel: 19 Interference: : 185
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 20 Interference: : 166
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 21 Interference: : 161
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 22 Interference: : 164
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 23 Interference: : 165
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 24 Interference: : 163
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 25 Interference: : 165
2019-02-15 20:54:42.025 Status: (Zigbee) Decode804A - Channel: 26 Interference: : 162
With which version pré-4-1? What did you do ?
No. It's Beta 4.1 now.
