Zigate Tried to add Elko Super TR RF thermostat
deve87
Post by deve87 »
Scandinavian Elko has a Zigbee rotary dimmer and thermostat.
I managed to add the dimmer to Domoticz. And it works, no feedback. But I can change light brightness and On/Off
When I tried to add the thermostat. It loops (after some seconds) on 'Trying to create Domoticz device (s)'
pipiche
Re: Zigate Tried to add Elko Super TR RF thermostat
Post by pipiche »
Can you kindly open an issue on github https://github.com/sasu-drooz/Domoticz-Zigate/issues so we can work in having this working ?
It would be great if you could switch to the pre-4.1 branch which has an implementation of Thermostat.
deve87
Post by deve87 »
In the pre-4.1. The thermostat got joined and I got a 'Set Point' and 'Temp'
The temp don't report any chance. It just give me one temp from when it's joined. I can change setpoint, but it only shows 0.0 and thermostat gets new setpoint
pipiche
Post by pipiche »
Please do check the logs for details ...
pipiche
Post by pipiche »
Could you also do the following:
git pull (on pre-4.1)
Add the following line in the 'middle' of the PluginConf.txt file in Conf folder
'allowStoreDiscoveryFrames':'1',
Remove the Set Point and Temp widget in order to be able to redo a full pairing
Stop the plugin. Check that there is no remaining entry for the Thermostat in DeviceList
Then restart the plugin and do the Pairing.
When the swicth will be created, you'll get a file in Zdata folder in regards to this new device. Please provide it.
deve87
Post by deve87 »
Okay. After git pull the error I got in my other post disappeared. Added the line in PluginConf.txt
After a full join. Setpoint and temp shows again. And temp not updates. It only shows correct temp when joining.
pipiche
Post by pipiche »
I need Logs and as well the file which has been created during the pairing and which is under Zdata folder
If you can reach me on keybase.io @pipiche, it will be easier to troubleshoot and investigate all that.
pipiche
Post by pipiche »
I have created an issue on GitHub: https://github.com/sasu-drooz/Domoticz- ... issues/349
Could you please provide me some details on this Thermostat:
- IS there a Documentation that you can pointed out, so I have view of what is it ?
- Is there a documentation of expected function to work. Only SetPoint and Local temp, or more ?
Is that this one : http://proff.elko.no/elko-smart-home-su ... -1779.html ?
deve87
Post by deve87 »
Yes. That's the correct one.
I noticed that the temp updated after about every 10min. And in log, it seems that setpoint is received as well. But setpoint is just showing as 0.0
2019-02-16 11:46:59.864 (Zigbee) ReadAttributeRequest_0201 - Key: e1a3
2019-02-16 11:46:59.976 (Zigbee) ReadCluster 0201 - Addr: e1a3 Ep: 01 AttrId: 0000 AttrType: 29 AttSize: 0002 Data: 0974
2019-02-16 11:46:59.977 (Zigbee) UpdateDevice - ( Elko super tr) 24.2:24.2
2019-02-16 11:46:59.981 (Zigbee) ReadCluster 0201 - Local Temp: 24.2
2019-02-16 11:46:59.985 (Zigbee) ReadCluster 0201 - Addr: e1a3 Ep: 01 AttrId: 0011 AttrType: 29 AttSize: 0002 Data: 0a28
2019-02-16 11:46:59.985 (Zigbee) ReadCluster 0201 - Cooling Setpoint: 26.0
2019-02-16 11:46:59.989 (Zigbee) ReadCluster 0201 - Addr: e1a3 Ep: 01 AttrId: 0012 AttrType: 29 AttSize: 0002 Data: 05dc
2019-02-16 11:46:59.989 (Zigbee) ReadCluster 0201 - Heating Setpoint: 15.0
The file from DeviceList. In folder Zdata, I only find a 'empty.txt'
e1a3 : {'Hearbeat': 0, 'IEEE': '000d6f001246b282', 'ConfigureReporting': {'Ep': {'01': {'0003': '', '0201': {}, '0402': {}, '0000': {}}}, 'TimeStamps': {'01-0003': 0, '01-0201': 1550311274, '01-0000': 0, '01-0402': 1550311274}}, 'MacCapa': '8e', 'Type': 'Temp/ThermoSetpoint', 'LogicalType': 'Router', 'ZDeviceID': '0301', 'SQN': {}, 'Status': 'inDB', 'Manufacturer': '1002', 'NbEp': '1', 'Bind': {'0402': {'Stamp': 1550311274, 'Status': '', 'Phase': 'requested'}, '0201': {'Stamp': 1550311274, 'Status': '', 'Phase': 'requested'}}, 'ReceiveOnIdle': 'On', 'Model': 'Super TR', 'Stamp': {'MsgType': '8102', 'Time': '2019-02-16 11:31:29'}, 'DeviceType': 'FFD', 'Ep': {'01': {'ClusterType': {'1362': 'Temp', '1363': 'ThermoSetpoint'}, '0003': {}, '0201': '24.7;0;26.0;5.0;0;0', '0402': '24.7', '0000': {}}}, 'Heartbeat': '437', 'Version': '3', 'RIA': '1', 'Battery': {}, 'RSSI': 57, 'ReadAttributes': {'Ep': {'01': {'0201': {'0008': '86', '0010': '86', '0011': '00', '0014': '86', '0012': '00', '0000': '00'}, '0000': {'0010': '86', '0004': '00', '000a': '86', '0005': '00', '0007': '00', '0000': '00'}}}, 'TimeStamps': {'01-0201': 1550313089, '01-0000': 1550311404}}, 'ProfileID': '0104', 'PowerSource': 'Main'}
Correct on?
pipiche
Post by pipiche »
Please use : https://github.com/sasu-drooz/Domoticz- ... issues/349
So we can track this enhacement
I also need the Zdata file as a file, anot as copy past
