Zigbee2MQTT
Re: Zigbee2MQTT
At the end I managed to get rid of the connection refused message by re-installing everything
Now I do see the following passing by in the Domoticz log:
(Zigbee2MQTT) Received available devices list from bridge
(Zigbee2MQTT) Device TRADFRI bulb E27 WS opal 1000lm 0xd0cf5efffef2b3dc (LED1623G12)
But what next? Should I expect to see this bulb in the Domoticz device list? I am a little bit puzzeled.
What to do in Domoticz to use this device?
Re: Zigbee2MQTT
Had the same isseu twice. Reinstalled everything and found out that running the Homekit addon was to blame ,(I guess). Now back at 0,4% usage without it.peerke72 wrote: ↑Saturday 09 February 2019 17:11 Í just got my Zigbee2MQTT installed and it is running finally.
I was wondering if it's normal the Raspberry Pi 3 CPU usage increases from average 2% before installation, to approximately 25% after installation of ZIgbee2MQTT. Or does this suggest something is wrong ?
Re: Zigbee2MQTT
I don't use the HomeKit Addon but maybe there is another conflict.Tuinslang wrote: ↑Thursday 21 February 2019 20:33Had the same isseu twice. Reinstalled everything and found out that running the Homekit addon was to blame ,(I guess). Now back at 0,4% usage without it.peerke72 wrote: ↑Saturday 09 February 2019 17:11 Í just got my Zigbee2MQTT installed and it is running finally.
I still had the increased CPU%. And even worse after a while no RFLink messages could be send or received. Just after installing ZIgb2MQTT RFLink still works OK. Only CPU is increased. Some time later RFLink stops working. After disabling Zigbee2MQTT (sudo systemctl stop zigbee2mqtt) and a reboot of domoticz everything is back to normal. But I would like to use Zigbee and RFLink together.
Because Domoticz is also storing the gas/electricty consumption I hope there is a solution without having to reinstall domoticz from scatch.
What can should I do to find the cause. Is there logging I should look into (where can I find it).
Any advice is welcome!
Re: Zigbee2MQTT
@Mayki as na option I would suggest to install zigbee2mqtt Domoticz Plugin to add native support for zigbee2mqtt without need of additional dzVents/Lus scripts
https://github.com/stas-demydiuk/domoti ... qtt-plugin
Re: Zigbee2MQTT
Look here: viewtopic.php?f=59&t=27499
Re: Zigbee2MQTT
Problems updating zigbee2mqtt
I'm having range issues in my house, i.e. cannot reliably reach some of the door sensors. To overcome that, I picked up an Ikea signal repeater, which is supposed to be supported by zigbee2mqtt (supported devices). When pairing the repeater, I keep on getting an error stating that ModelID Ikea signal repeater is not supported etc. After a bit us studying, seems that I'm running an ancient version (log: Starting zigbee2mqtt version 0.2.0 (commit #b0d3c2f)), but following the updating instructions (bottom of the page), nothing changes: the version remains the same and so on. Rebooting does not help.
Any advice would be highly welcome.
Re: Zigbee2MQTT
Quick solution. Save the 'configuration.yaml' file. Delete the zigbee directory and install zigbee2mqtt again. Then the lastest version should be there.
Put the configuration.yaml file back and start zigbee2mqtt
Re: Zigbee2MQTT
Finally the update was a success, but caused the the zigbee2mqtt plugin in Domoticz failing to start: updating the plugin was required as well, but now things are up and running again.
Although I still don't know if the Ikea repeater is connected or if it actually helps expanding the network. I'll dig into that next.
Re: Zigbee2MQTT
I even looked at the instructions, but couldn't figure out how to get started with that. Found something related to network map on the zigbee2mqtt -website (here, paragraph zigbee2mqtt/bridge/networkmap) but that didn't really help. Any pointers how to get things moving? Do I need a separate MQTT client or what? (As you might notice, I'm not exactly a pro on this )
- Domoticz version: 2020.1
Re: Zigbee2MQTT
Quick and dirty instructions for a Windows client
On Windows install MQTT
Create a client with the MQTT server ip address and port and connect to it
add a subscriber with the topic
zigbee2mqtt/bridge/networkmap/graphviz
hit subscribe
Create a publisher
topic to publish - zigbee2mqtt/bridge/networkmap
payload - graphviz
click on Publish button
the response will show in the subscribe window, something like
"digraph G { node[shape=record]; "0x00124b0014b887ab" [style="bold", label="{0x00124b0014b887ab|Coordinator|No model information available|online}"]; "0x00124b0014b887ab" -> "0x000d6ffffef34d9d" [label="168"] "0x00124b0014b887ab" -> "0x000d6ffffe9a1bc9" [label="129"] "0x00124b0014b887ab" -> "0x000d6ffffee3be1b" [label="182"] "0x00124b0014b887ab" -> "0x000d6ffffed1a718" [label="122"] "0x000d6ffffe9a1bc9" [style="rounded", label="{IkeaRepeater|Router|IKEA TRADFRI signal repeater (E1746"
copy all the text and paste it into http://www.webgraphviz.com/ replacing the dummy text
click on graph button
Re: Zigbee2MQTT
Please could anyone help me?
I successfully paired Aqara wall switch WXKG03LM and in Domoticz there has been created push on button.
Is that correct? I assumed that there will be created selector switch with single click, double click etc instead.
- Domoticz version: V2022.1
Re: Zigbee2MQTT
Does somebody know how good the battery reading is?
I have 2 Xiaomi devices connected. Both give a battery voltage of 3.055V and 100%
For me it is strange, that they are exactly the same.
Before connecting to zigbee2mqtt i connected 1 device to the Xiaomi gateway, than it said the battery was 95%.
Somebody has more information about this?
Otherwise low battery on a smoke detector could be dangerous. Thinking about getting a notification, but there will be non if battery reading is not working.
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
Re: Zigbee2MQTT
I think that above 3.025 Volt everything is 100%
But everything is not very consistent.
I have a 2 device with both 2.995 Volt, one is at 91% and the other is 74%
Might be the difference in battery.
I still have faith in the readings.
Run a script everyday to check the batteries and set a warning below 30% or so.
Re: Zigbee2MQTT and Domoticz on Windows
I am new to Zigbee. At the moment I am using a RFLInk with my Domoticz running on Windows 10.
Can I use the Zigbee2MQTT project when I use Windows 10 as my OS for Domoticz?
Best regards,
Gert
Best regards,
Gert
Re: Zigbee2MQTT
Maybe ask it to the guys in this thread
viewtopic.php?f=68&t=27743
They also have windows 10 and trying to use Zigbee2MQTT
- Domoticz version: 4.9700
Yes. You can add z-wave and Zigbee, etc. etc. You can control it all using Domoticz.
Are you sure?
The zigbee2mqtt install instructions is on linux based.
How to install zigbee2mqtt on Windows? Do you have an installation manual?
That the different protocols Works together, that we know. But the question was how to get zigbee2mqtt working on Windows 10
I don’t have installation instructions for Windows. Sorry. Run Domoticz on a Pi.hoeby wrote: ↑Sunday 23 June 2019 12:50Are you sure?
