dio chacon 54514
opartex
dio chacon 54514
Post by opartex »
I'm a newbie to Domoticz, so please bear with me ;-)
I installed DOMOTICZ on a raspberry pi 2 I had left unused.
I plugged a RFXCOMXL on a usb slot.
I manually added a switch with
Hardware : RFXCOMXL,
Switch type : Dimmer,
Type : AC,
ID : I didn’t change it since it’s the first thing I do on DOMOTICZ
Then I pressed TEST… but nothing happened !
And I tried and tried, I moved the rpi closer to the switch… nothing worked !
HELP !
Thanks for your help.
emme
Domoticz version: latest
Re: dio chacon 54514
Post by emme »
try by add the switch this way:
go to Switch panel
select LEARN LIGHT/SWITCH button
Activate your switch
the learn process should complete and you should get the new switch
"We always done this way"
opartex
Post by opartex »
Hello emme,
I can't activate the swiitch since this device has no button on it.
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Hi ,
the dio 54514 is working on 868 mhz, is your rfxcom aslo a 868 mhz version?
Kind regards
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
opartex
Post by opartex »
I checked on chacon's website, they say it's 433MHz.
Where did you read it's 686 ?
Thanks for your help Lebo2d9.
Lebo2d9
Post by Lebo2d9 »
Hi Opartex,
I saw it on the website of conrad https://www.conrad.be/p/draadloze-knop- ... term=95895
on the website of chacon they are talking about 433 MHZ https://www.chacon.be/nl/verlichting/11 ... 45156.html. On a picrure on the conrad website there is a close-up of the dimmer and there it is indicated 433 MHz.
More to come
Lebo2d9
Post by Lebo2d9 »
I think have to created a switch manualy. For hardware you take the hardware name you used for your rfxcom reciever, select dimmer for type, type is X10, house and unit code you can take what ever you want, as long they are unique.
Then you push the small button (leaning) on the dimmer and then you click test.
I don't own a dimmer but i have several switches. I think i added them this way.
I found also on a french forum a workaround using the remote control http://easydomoticz.com/forum/viewtopic.php?t=2056
Kind regards
Koen
More to come
opartex
Post by opartex »
I Will try with X10 Protocol and I'll let you know.
b_weijenberg
Post by b_weijenberg »
DIO Chacon with address code wheels is an ARC device and with automatic coding is an AC device.
RFX-433, RFX-433EMC, RFX-868
opartex
Post by opartex »
Hello and thank you for your reply b_weijenberg.
I tested AC, ARC and X10 but nothing works !
When I push test, lights are blinking on the RFXcom, but nothing changes on the DIO chacon...
Any idea ?
b_weijenberg
Please test with RFXmngr:
Is the DIO remote received if you enable AC and ARC?
If you don't have a DIO remote pair the module using Lighting2 - AC and select (do not enter) a random ID and Unit code
Lebo2d9
Post by Lebo2d9 »
Do you set the DIO in learn mode?
More to come
opartex
Post by opartex »
Lebo2d9 wrote: Saturday 16 February 2019 10:05 Do you set the DIO in learn mode?
yes I did
Lebo2d9
Post by Lebo2d9 »
Do you have a remote control for the dimmer?
More to come
