read this topic but did not find a solution
Installed pp manager without problems
Install plugins without problems
get a message device created
but under devices there are no new devices to find?
I cannot chance te plugin settings.
log show that everything is correct
Reboot my domoticz multiple time.
- Knipsel12.JPG (96.46 KiB) Viewed 13386 times
my log
2019-03-30 01:59:50.109 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-03-30 01:59:50.119 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2019-03-30 01:59:50.126 Status: Startup Path: /home/gianni/domoticz/
2019-03-30 01:59:50.585 Status: EventSystem: reset all events...
2019-03-30 01:59:50.684 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Gang.lua
2019-03-30 01:59:50.684 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Trap.lua
2019-03-30 01:59:50.685 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Living.lua
2019-03-30 01:59:50.685 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Keuken.lua
2019-03-30 01:59:51.830 Status: PluginSystem: Started, Python version '3.5.3'.
2019-03-30 01:59:52.013 Status: WebServer(HTTP) started on address: :: with port 8085
2019-03-30 01:59:52.041 Status: WebServer(SSL) started on address: :: with port 443
2019-03-30 01:59:52.045 Status: Proxymanager started.
2019-03-30 01:59:52.111 Status: TCPServer: shared server started...
2019-03-30 01:59:52.112 Status: RxQueue: queue worker started...
2019-03-30 01:59:54.122 Status: AppLamp: Worker Started...
2019-03-30 01:59:54.126 Status: Pinger: Started
2019-03-30 01:59:54.126 Status: (Pi_Monitor) Started.
2019-03-30 01:59:54.126 Status: (Mikrotik_Router) Started.
2019-03-30 01:59:54.126 Status: (Batterij_Monitor) Started.
2019-03-30 01:59:54.127 Status: EventSystem: reset all events...
2019-03-30 01:59:54.129 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Gang.lua
2019-03-30 01:59:54.129 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Trap.lua
2019-03-30 01:59:54.130 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Living.lua
2019-03-30 01:59:54.130 Status: dzVents: Write file: /home/gianni/domoticz/scripts/dzVents/generated_scripts/Wissel_Keuken.lua
2019-03-30 01:59:54.130 Status: EventSystem: reset all device statuses...
2019-03-30 01:59:54.314 Status: RFLink: Using serial port: /dev/ttyACM0
2019-03-30 01:59:54.421 Status: PluginSystem: Entering work loop.
2019-03-30 01:59:54.613 Status: OpenZWave: using config in: /home/gianni/domoticz/Config/
2019-03-30 01:59:54.649 Status: OpenZWave: Starting...
2019-03-30 01:59:54.649 Status: OpenZWave: Version: 1.4-2888-g54682370-dirty
2019-03-30 01:59:55.017 Status: OpenZWave: Driver Ready
2019-03-30 01:59:55.094 Status: OpenZWave: Value_Added: Unhandled Label: Seismic Intensity, Unit:
2019-03-30 01:59:55.107 Status: OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 11 (0x0b), Index: 0, Instance: 1
2019-03-30 01:59:55.121 Status: MQTT: Connecting to localhost:1883
2019-03-30 01:59:55.224 Status: MQTT: connected to: localhost:1883
2019-03-30 01:59:55.236 Status: RFLink: Controller Initialized!...
2019-03-30 01:59:55.312 Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2019-03-30 01:59:55.325 Status: MQTT: Subscribed
2019-03-30 01:59:55.336 Status: AppLamp: Bridge found!...
2019-03-30 01:59:55.721 Status: (Pi_Monitor) Entering work loop.
2019-03-30 01:59:55.724 Status: (Pi_Monitor) Initialized version 1.5.18, author 'ycahome'
2019-03-30 01:59:56.758 Status: (Mikrotik_Router) Entering work loop.
2019-03-30 01:59:56.761 Status: (Mikrotik_Router) Initialized version 1.5.18, author 'ycahome'
2019-03-30 01:59:57.946 Status: (Batterij_Monitor) Entering work loop.
2019-03-30 01:59:57.949 Status: (Batterij_Monitor) Initialized version 1.5.18, author 'ycahome'
2019-03-30 01:59:58.192 Status: Python EventSystem: Initalizing event module.
2019-03-30 01:59:58.206 Status: EventSystem: Started
2019-03-30 01:59:58.206 Status: EventSystem: Queue thread started...
2019-03-30 02:00:05.408 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 8 (0x08)
2019-03-30 02:00:15.702 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:00:16.705 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 10 (0x0a)
2019-03-30 02:00:17.707 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 11 (0x0b)
2019-03-30 02:00:18.708 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 13 (0x0d)
2019-03-30 02:00:19.709 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 2 (0x02)
2019-03-30 02:00:20.711 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 2 (0x02)
2019-03-30 02:00:21.713 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 3 (0x03)
2019-03-30 02:00:22.715 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 3 (0x03)
2019-03-30 02:00:23.726 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 4 (0x04)
2019-03-30 02:00:24.728 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 4 (0x04)
2019-03-30 02:00:25.731 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 5 (0x05)
2019-03-30 02:00:26.733 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 5 (0x05)
2019-03-30 02:00:27.735 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 6 (0x06)
2019-03-30 02:00:28.743 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 6 (0x06)
2019-03-30 02:00:39.247 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 2 (0x02)
2019-03-30 02:00:50.387 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 8 (0x08)
2019-03-30 02:01:00.389 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:01.488 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 10 (0x0a)
2019-03-30 02:01:02.490 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 11 (0x0b)
2019-03-30 02:01:03.492 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 13 (0x0d)
2019-03-30 02:01:04.494 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 2 (0x02)
2019-03-30 02:01:05.502 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 3 (0x03)
2019-03-30 02:01:21.311 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:22.313 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:23.315 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:24.317 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:25.318 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:26.324 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:01:35.111 Status: OpenZWave: Unhandled class: 0x87 (INDICATOR), NodeID: 11 (0x0b), Index: 0, Instance: 1
2019-03-30 02:01:37.681 Status: OpenZWave: Awake Nodes queried
2019-03-30 02:01:47.685 Status: OpenZWave: Received timeout notification from HomeID: 3412213077, NodeID: 9 (0x09)
2019-03-30 02:07:25.557 (Batterij_Monitor) Current time:02:07
2019-03-30 02:07:34.427 (Controller) Light/Switch (Alarm Type)
2019-03-30 02:07:34.430 (Controller) Light/Switch (Alarm Level)
2019-03-30 02:07:34.432 (Controller) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-03-30 02:07:34.435 (Controller) Light/Switch (Burglar)
2019-03-30 02:07:34.547 (Controller) Light/Switch (Motion_Living)
2019-03-30 02:08:05.751 (Controller) Light/Switch (Alarm Type)
2019-03-30 02:08:05.758 (Controller) Light/Switch (Alarm Level)
2019-03-30 02:08:05.759 (Controller) General/Alarm (Alarm Type: Burglar 7 (0x07))
2019-03-30 02:08:05.764 (Controller) Light/Switch (Burglar)
2019-03-30 02:08:05.863 (Controller) Light/Switch (Motion_Living)
2019-03-30 02:08:07.714 (RF_433) Temp + Humidity (Baldr)
2019-03-30 02:08:23.307 (Pi_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:08:23.309 (Pi_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:08:23.309 (Pi_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:08:23.309 (Pi_Monitor) onHeartbeat called
2019-03-30 02:08:23.310 (Pi_Monitor) Current time:02:08
2019-03-30 02:08:24.352 (Mikrotik_Router) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:08:24.361 (Mikrotik_Router) Processing 'onHeartbeatCallback' message
2019-03-30 02:08:24.362 (Mikrotik_Router) Calling message handler 'onHeartbeat'.
2019-03-30 02:08:24.362 (Mikrotik_Router) onHeartbeat called
2019-03-30 02:08:24.362 (Mikrotik_Router) Current time:02:08
2019-03-30 02:08:25.533 (Batterij_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:08:25.564 (Batterij_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:08:25.564 (Batterij_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:08:25.564 (Batterij_Monitor) onHeartbeat called
2019-03-30 02:08:25.565 (Batterij_Monitor) Current time:02:08
2019-03-30 02:08:52.764 MQTT: Topic: domoticz/in, Message: {"idx":80,"nvalue":0,"svalue":"113;45120.5","Battery":53,"RSSI":10}
2019-03-30 02:08:52.878 MQTT: Topic: domoticz/in, Message: {"idx":79,"nvalue":0,"svalue":"237","Battery":53,"RSSI":10}
2019-03-30 02:08:52.993 MQTT: Topic: domoticz/in, Message: {"idx":81,"nvalue":0,"svalue":"0.589","Battery":53,"RSSI":10}
2019-03-30 02:09:04.933 (RF_433) Temp + Humidity (Baldr)
2019-03-30 02:09:23.317 (Pi_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:09:23.367 (Pi_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:09:23.370 (Pi_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:09:23.370 (Pi_Monitor) onHeartbeat called
2019-03-30 02:09:23.370 (Pi_Monitor) Current time:02:09
2019-03-30 02:09:24.367 (Mikrotik_Router) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:09:24.372 (Mikrotik_Router) Processing 'onHeartbeatCallback' message
2019-03-30 02:09:24.373 (Mikrotik_Router) Calling message handler 'onHeartbeat'.
2019-03-30 02:09:24.373 (Mikrotik_Router) onHeartbeat called
2019-03-30 02:09:24.373 (Mikrotik_Router) Current time:02:09
2019-03-30 02:09:25.544 (Batterij_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:09:25.575 (Batterij_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:09:25.575 (Batterij_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:09:25.575 (Batterij_Monitor) onHeartbeat called
2019-03-30 02:09:25.576 (Batterij_Monitor) Current time:02:09
2019-03-30 02:10:01.463 (RF_433) Light/Switch ()
2019-03-30 02:10:02.008 (RF_433) Temp + Humidity (Baldr)
2019-03-30 02:10:03.736 MQTT: Topic: domoticz/in, Message: {"idx":83,"nvalue":0,"svalue":"23.7;46.4;1"}
2019-03-30 02:10:04.395 MQTT: Topic: domoticz/in, Message: {"idx":76,"nvalue":0,"svalue":"84;294841.4","Battery":58,"RSSI":5}
2019-03-30 02:10:04.502 MQTT: Topic: domoticz/in, Message: {"idx":75,"nvalue":0,"svalue":"236","Battery":58,"RSSI":5}
2019-03-30 02:10:04.614 MQTT: Topic: domoticz/in, Message: {"idx":77,"nvalue":0,"svalue":"0.633","Battery":58,"RSSI":5}
2019-03-30 02:10:23.329 (Pi_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:10:23.376 (Pi_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:10:23.376 (Pi_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:10:23.376 (Pi_Monitor) onHeartbeat called
2019-03-30 02:10:23.376 (Pi_Monitor) Current time:02:10
2019-03-30 02:10:24.380 (Mikrotik_Router) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:10:24.429 (Mikrotik_Router) Processing 'onHeartbeatCallback' message
2019-03-30 02:10:24.429 (Mikrotik_Router) Calling message handler 'onHeartbeat'.
2019-03-30 02:10:24.429 (Mikrotik_Router) onHeartbeat called
2019-03-30 02:10:24.429 (Mikrotik_Router) Current time:02:10
2019-03-30 02:10:25.554 (Batterij_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:10:25.581 (Batterij_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:10:25.581 (Batterij_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:10:25.582 (Batterij_Monitor) onHeartbeat called
2019-03-30 02:10:25.582 (Batterij_Monitor) Current time:02:10
2019-03-30 02:10:58.461 (RF_433) Temp + Humidity (Baldr)
2019-03-30 02:11:23.341 (Pi_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:11:23.374 (Pi_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:11:23.375 (Pi_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:11:23.375 (Pi_Monitor) onHeartbeat called
2019-03-30 02:11:23.375 (Pi_Monitor) Current time:02:11
2019-03-30 02:11:24.399 (Mikrotik_Router) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:11:24.427 (Mikrotik_Router) Processing 'onHeartbeatCallback' message
2019-03-30 02:11:24.427 (Mikrotik_Router) Calling message handler 'onHeartbeat'.
2019-03-30 02:11:24.427 (Mikrotik_Router) onHeartbeat called
2019-03-30 02:11:24.427 (Mikrotik_Router) Current time:02:11
2019-03-30 02:11:25.566 (Batterij_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:11:25.579 (Batterij_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:11:25.580 (Batterij_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:11:25.580 (Batterij_Monitor) onHeartbeat called
2019-03-30 02:11:25.580 (Batterij_Monitor) Current time:02:11
2019-03-30 02:11:55.569 (RF_433) Temp + Humidity (Baldr)
2019-03-30 02:12:16.548 (Controller) Temp (Temperature_Beneden)
2019-03-30 02:12:23.350 (Pi_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:12:23.373 (Pi_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:12:23.373 (Pi_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:12:23.373 (Pi_Monitor) onHeartbeat called
2019-03-30 02:12:23.373 (Pi_Monitor) Current time:02:12
2019-03-30 02:12:24.416 (Mikrotik_Router) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:12:24.425 (Mikrotik_Router) Processing 'onHeartbeatCallback' message
2019-03-30 02:12:24.426 (Mikrotik_Router) Calling message handler 'onHeartbeat'.
2019-03-30 02:12:24.426 (Mikrotik_Router) onHeartbeat called
2019-03-30 02:12:24.426 (Mikrotik_Router) Current time:02:12
2019-03-30 02:12:25.578 (Batterij_Monitor) Pushing 'onHeartbeatCallback' on to queue
2019-03-30 02:12:25.628 (Batterij_Monitor) Processing 'onHeartbeatCallback' message
2019-03-30 02:12:25.628 (Batterij_Monitor) Calling message handler 'onHeartbeat'.
2019-03-30 02:12:25.628 (Batterij_Monitor) onHeartbeat called
2019-03-30 02:12:25.629 (Batterij_Monitor) Current time:02:12
1 thing i did not find is the update button i only have a add button
