Python Plugins: Site Package directories added to default Python path
Dnpwwo
Post by Dnpwwo »
After recently discovering that behind the scenes Python normally pre-loads the 'site' module and appends additional packages to the Python path, I have pushed a change tonight to make the Python Plugin Framework do the same.
Hopefully the change will make the framework mimic 'normal' Python better and avoid confusion.
Framework now effectively does this prior to the plugin load:
import site
for site in site.getsitepackages():
    sys.path.append(site)
so that you don't have to to use packages installed with pip to the system. On linux you need to use 'sudo pip3...'
This will be in the next beta.
zak45
Domoticz version: V2024.4
Re: Python Plugins: Site Package directories added to default Python path
Post by zak45 »
Great news.
thanks!
pipiche
Post by pipiche »
That is very cool !
pipiche
Post by pipiche »
@dnpwwo any idea since which version of Domoticz it is implemented ?
Dnpwwo
Post by Dnpwwo »
Sorry, I don't.
Maybe you could work it out from the date of the post?
