NUT Mini BATTERY SERVICE
Re: NUT Mini BATTERY SERVICE
I did not quite understand what was going on? I'm just starting to deal with Node Red, and I know very little. It is possible in more detail where and what you need?
- emme
- Domoticz version: latest
uh... that my severe fault!!!!!
mac addresses must be written without :
so if you eneterd aa:bb:cc:dd:ee the correct config is
aabbccddee
I apologize....
aabbccddee
I apologize....
"We always done this way"
OK, I'll try. But it's not your fault, I don't know anything.
- emme
mmh looks like something happend...
the 2 telegrams oare the interface bringing up...
but you have to issue a
sudo systemctl daemon-reload
and then a reboot to be sure.... ( sudo reboot )
that should be hopefully enough
The sudo systemctl daemon-reload command has already been done, and it has disconnected everything that was superfluous, leaving one USB BLE at all. In the evening I will reboot the system and then we'll see.
https://yadi.sk/i/TCQJC1Mezb818g
I did everything, especially nothing has changed
IT WORKED
do some more battery checking
Anyone got the battery checking up and running. it keeps saying the nut is unavailable
It works. Got the wrong id for the check of the nut
Hey. I have a project on the malinka, it works, there is one USB bluetooth, how do I put the second one into error, can this be somehow fixed? Help is needed.
- emme
mh you do want to add a second interface?
if so you have to duplicate the script and configure for hci1 (assuming that hci0 is the onboard one)
Hi, no, I want to connect columns to the built-in hci0, how to configure the script on hci1?
And yet, once a day, it sometimes loses the mac address, and in a minute it finds again, is it possible to eliminate this error? Where to dig?
