landaisbenj
- Domoticz version: stable
Re: machinon theme
Master branch is impacted?
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
- EdddieN
- Domoticz version: 4.9700
Re: machinon theme
Yes, but seems only certains tabs like Switch and Utility
11101101 - www.machinon.com
funky
- Domoticz version: newest
Re: machinon theme
When I installed the theme I lost the setup menu item. How can I fix this?
- EdddieN
Re: machinon theme
This step is very important, have you done it?
sudo cp ~/domoticz/www/styles/machinon/templates/Settings.html ~/domoticz/www/templates/11101101 - www.machinon.com
- EdddieN
Re: machinon theme
Hello all,
Could I ask the community using this theme to let me know if they are using the latest master or beta?
It seems there's a bit of caching issues and I want to make sure the problems described here: https://github.com/EdddieN/machinon-dom ... issues/184 are just that, a caching issue.
It is important to provide feedback so we can move forward, please? We need to merge the beta into the master but only if we have enough feedback.
If you are having similar issues, make sure to:
1.- Fully clear your browser cache with all tabs closed on your browser
2.- Best if you try in Incognito mode
3.- Check if you have in www/js 'domoticz.js.gz', if it is there remove it - CAREFUL! KEEP domoticz.js !!
If you can do the same on a mobile device and even post some screens?
Thanks so much!
Thanks so much!
- EdddieN
Re: machinon theme
Ok, for those with the tile overlay issue, this may be a temporary fix
https://github.com/EdddieN/machinon-dom ... -454532377
Holland
- Domoticz version: Beta Ch
Re: machinon theme
Hi Eddie
I have done 1 to 3, but the issue remains. And it only appears on the Switches and Utility tab
Running the beta version at the moment
- EdddieN
Re: machinon theme
Thanks for the feedback! And the beta shows the overlayed tiles, correct?Holland wrote: Tuesday 15 January 2019 23:19 Hi Eddie
Are you ok to follow this instructions? https://github.com/EdddieN/machinon-dom ... -454532377
I would advice you to create another clone, like beta_test for this one
- EdddieN
Re: machinon theme
Hello all,
I think landaisbenj has managed to fix the theme! Are you able to try the master branch, do a git pull
and then git checkout test-new-master and let us know how it works for you?
- DewGew
- Domoticz version: V4.10618
Re: machinon theme
Look much betterEdddieN wrote: Wednesday 30 January 2019 22:23 Hello all,
- DewGew
Re: machinon theme
New Machinon version 1.6.0 released today.
- DewGew
Re: machinon theme
How to get visual notifcation when a device is changing status or value etc.
Go to notifications
In notifications settings select browser
Go to notifications
- EdddieN
Re: machinon theme
Anyone interested on beta testing a reverse proxy to access Domoticz from the outside world without having to have a VPN or port forwarding?
Re: machinon theme
I'm In for the reverse proxy
Tell me how to test
By the way, any chance to correct the selector graphic bug ?
Tell me how to test
- EdddieN
Re: machinon theme
Selector, is it on GitHub?
Re proxy, drop me a pm and I’ll send you details. You’ll need a GitHub account to access the code
Re: machinon theme
HI
I think it's quite important
Feature request
1. Abbility to hide dew point ( 90% of people don't care about )
2. Abbility to hide "type" eg light/switch, seletector .... since the icon all ready tells you what it is
Feature request
- Minglarn
- Domoticz version: v3.8153
Re: machinon theme
Wow!
Really liked this theme...
Clean...
Big... Maybe to big... Is there any settings to make it more compact? Yepp, tryed the compact mode...
Clean...
- 01.JPG (18.66 KiB) Viewed 3790 times
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
gerwindewit
Re: machinon theme
Thank you for this wonderful piece of art, well appreciated the effort. I registered especially for this big thumbs up...
I installed the beta today and discovered a new feature, embedding a custom page. That's something i was looking for, for "ages"... Now i have both Domoticz and Volumio in one browser instance. That and the Kiosk mode on Google Chrome makes it a perfect combination for me...
- Screenshot at Feb 19 13-40-06kopie.jpg (252.18 KiB) Viewed 4275 times
