NUT Mini BATTERY SERVICE
All kinds of 'OS' scripts
Artursd
Re: NUT Mini BATTERY SERVICE
Post by Artursd »
I did not quite understand what was going on? I'm just starting to deal with Node Red, and I know very little. It is possible in more detail where and what you need?
emme
Domoticz version: latest
Post by emme »
uh... that my severe fault!!!!!
mac addresses must be written without :
so if you eneterd aa:bb:cc:dd:ee the correct config is
aabbccddee
I apologize.... :(
"We always done this way"
Artursd
Post by Artursd »
OK, I'll try. But it's not your fault, I don't know anything.
Artursd
Post by Artursd »
Artursd
Post by Artursd »
emme
Post by emme »
mmh looks like something happend...
the 2 telegrams oare the interface bringing up...
but you have to issue a
sudo systemctl daemon-reload
and then a reboot to be sure.... ( sudo reboot )
that should be hopefully enough
Artursd
Post by Artursd »
The sudo systemctl daemon-reload command has already been done, and it has disconnected everything that was superfluous, leaving one USB BLE at all. In the evening I will reboot the system and then we'll see.
Artursd
Post by Artursd »
https://yadi.sk/i/TCQJC1Mezb818g
I did everything, especially nothing has changed
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
Artursd
Post by Artursd »
IT WORKED
Artursd
Post by Artursd »
THANK
Artursd
Post by Artursd »
do some more battery checking
brianprak
Post by brianprak »
Anyone got the battery checking up and running. it keeps saying the nut is unavailable
It works. Got the wrong id for the check of the nut
Artursd
Post by Artursd »
Hey. I have a project on the malinka, it works, there is one USB bluetooth, how do I put the second one into error, can this be somehow fixed? Help is needed.
emme
Post by emme »
mh you do want to add a second interface?
if so you have to duplicate the script and configure for hci1 (assuming that hci0 is the onboard one)
Artursd
Post by Artursd »
Hi, no, I want to connect columns to the built-in hci0, how to configure the script on hci1?
Artursd
Post by Artursd »
And yet, once a day, it sometimes loses the mac address, and in a minute it finds again, is it possible to eliminate this error? Where to dig?
