update OpenZWave version
john21wall
Re: update OpenZWave version
Stupid me, i updated the libraries for win32, but needed to compile OZW on the RPI as well.
ocmer
If you only need updated Config-files, it may be possible to replace domoticz/Config by the new files that you can download from https://github.com/OpenZWave/open-zwave
I had the issue a Neo Coolcam PIR was not recognized by Domoticz/OpenZwave. I downloaded the source files from github and replaced the Config directory from Domoticz with the config-directory from github. After excluding and including the device, it is recognized properly.
Maybe a dirty hack, but it seems to work so far...
I'm running Domoticz on a Fedora 26 machine. OpenZwave is included in the Fedora distribution. Fedora just updated it from 1.4.164-1.fc26 to 1.5.0-0.20170724gitde1c0e6.fc26.
I've had to put back the 1.4.164 openzwave package in my fc26 repo in order to keep domoticz building.
This is the build result with openzwave 1.5:
https://build.opensuse.org/package/live ... ide/x86_64
I'm willing to test patches, etc.
ben53252642
Interesting it's now 2018 and the latest Domoticz Beta 4.10228 is still running OpenZwave Version 1.4*
v1.5 was released in 2016
https://github.com/OpenZWave/open-zwave/releases
Thank you for sharing this.Kender wrote: Friday 03 February 2017 14:30 Yes,
I followed all the part "Installing from Source"
Update:
After the cloning of the git repository you have to enter in the folder and change the git branch with the comand: git checkout Dev
At this point, if you make openzwave you'll have the 1.5 version.
Now the problem is that I have an error compiling the file Driver.o![]()
jake
Who knows, 1.5 might solve some issues, like dropping some nodes from the network.
