jvdz wrote:You could also test the Dummy sensor by sending a value yourself through a JSON call:
your-domoticz-url:port/json.htm?type=command¶m=udevice&idx=577&svalue=10
Jos
EDIT:
astrapowerrr wrote: Thursday 24 January 2019 21:28
You can get the text when you hit the 3 bars logo at the right top and select view data table...
Ah ..yes, that shows a similar table with the 5 minute interval.
Tested it with jsonand that worked. So I can make sure the dummy is ok.?
And settings in espeasy also ok.
What do I miss??
Update:
I recreated a lux dummy but with no luck.
Then I used idx 588 temp/humidity dummy for my dht 22(waiting for parts).
Then my esp lux value was 6.67 at that moment.
In Domoticz the value of the temp/humidity was 6.
Then I raised the light in the living room.
Pictures will tell more.
So is the conclusion the lux dummy in Domoticz is broken?
You use that dummy to don’t you?
