Hi I have Domoticz installed on a Pi (not 100% sure on model) but it seems sluggish sometimes, If I move it to the latest PI or a Linux Laptop do I just
get Domoticz installed, plug in my Zwave stick and import my latest backup, reboot and away I go with EVERYTHING working as it was?
Lastly if my Zwave USB stick fails, Do I have to re-learn all devices to a new stick?
although I am considering using a Pi Zwave hat going forward
cheers
Move Domoticz to new Pi or Platform
alarm_guy1
- waaren
Re: Move Domoticz to new Pi or Platform
If your backup contains domoticz.db and all subdirectories then yes, You might need to change the usb port name the Z-wave stick uses (in the domoticz hardware page).alarm_guy1 wrote: Wednesday 23 January 2019 20:10 Hi I have Domoticz installed on a Pi (not 100% sure on model) but it seems sluggish sometimes, If I move it to the latest PI or a Linux Laptop do I just
alarm_guy1
Ok cheers, sorry for late response went to bed early
Normally I just use this screen (Pic attached)
Will this be sufficient or do I need to do more.
Cheers
Cheers
- Untitled.png (62.46 KiB) Viewed 3558 times
- waaren
This will only make a backup of your database. Very important but not enough for what you want to do. You will miss external scripts / plugins and some zwave stuff from the config subdirectory. I don't know exactly what you need from that, i normally just copy everything when I create a clone on my test system.alarm_guy1 wrote: Thursday 24 January 2019 9:08 Normally I just use this screen (Pic attached)
alarm_guy1
Cool, cheers
I have a few hours later to play...
