Moderators: leecollings , htilburgs , robgeerts
Lokonli
Posts: 2296 Joined: Monday 29 August 2016 22:40
Post
by Lokonli » Saturday 19 January 2019 21:48
Derik wrote: Saturday 19 January 2019 21:31
Derik wrote: Saturday 19 January 2019 21:30
Lokonli wrote: Saturday 19 January 2019 20:54
Yes, you can install it on the same hardware. What kind of system are you using?
RPi 3 or Xu4 odroid [ testing ]
so what are the commands i need to use?
the wiki from domoticz is very great..
RPi is fine.
From
https://www.domoticz.com/wiki/Dashticz_ ... stallation let's start with:
sudo apt-get update
sudo apt-get install apache2
sudo apt-get install php7.0
sudo apt-get install php7.0-xml php7.0-curl
sudo systemctl restart apache2
If you get any error please post that here.
Derik
Posts: 1605 Joined: Friday 18 October 2013 23:33
Post
by Derik » Saturday 19 January 2019 21:58
Lokonli wrote: Saturday 19 January 2019 21:48
RPi is fine.
From
sudo apt-get update
Done without errors
Lokonli
Post
by Lokonli » Saturday 19 January 2019 22:15
Derik wrote: Saturday 19 January 2019 21:58
RPi is fine.
From
sudo apt-get update
Done without errors
What's the IP-address of your RPi?
Check whether Apache is running by opening 'http://<IP of your RPi> in a web browser.
You should see the Apache demo page.
Derik
Post
by Derik » Saturday 19 January 2019 22:17
Running:
192.168.5.70
Lokonli
Post
by Lokonli » Saturday 19 January 2019 22:22
Good.
Next steps:
cd /home/pi
git clone https://github.com/robgeerts/dashticz_v2 --branch beta
Do you already have a previous install of Dashticz on your RPi? What is the location?
You can copy your previous configuration to the new installation with
cp <Old location>/custom/CONFIG.js dashticz_v2/custom
Derik
Post
by Derik » Saturday 19 January 2019 22:24
Lokonli wrote: Saturday 19 January 2019 22:22
Good.
Next steps:
cd /home/pi
Dashticz is running...
And then?
Lokonli
Post
by Lokonli » Saturday 19 January 2019 22:30
Did you already create the symlink? Otherwise you're probably running the previous Dashticz version.
sudo ln -s /home/pi/dashticz_v2/ /var/www/html
Now open the new Dashticz by browsing to:
http://<your RPi IP>/dashticz_v2
Derik
Post
by Derik » Saturday 19 January 2019 22:33
Lokonli wrote: Saturday 19 January 2019 22:30
i run v2.
Only symlink ?
And now should runt he calendar?
Lokonli
Post
by Lokonli » Saturday 19 January 2019 22:36
Yes, depending on the content of your CONFIG.js.
Check the Dashticz version and PHP version. You can see it in Dashticz: click on the 'settings' icon in the menu bar,and then on the info tab.
Derik
Post
by Derik » Saturday 19 January 2019 22:47
Lokonli wrote: Saturday 19 January 2019 22:36
mmm php not installed says the config from the topbar..
Lokonli
Post
by Lokonli » Saturday 19 January 2019 22:50
Derik wrote: Saturday 19 January 2019 22:47
hmm, not good. Can you post the output of:
Derik
Post
by Derik » Saturday 19 January 2019 22:59
pi@raspberrypi:~ $ cat /var/log/apache2/error.log
[Sat Jan 19 06:25:04.857342 2019] [mpm_prefork:notice] [pid 515] AH00163: Apache/2.4.25 (Raspbian) configured -- resuming normal operations
[Sat Jan 19 06:25:04.857512 2019] [core:notice] [pid 515] AH00094: Command line: '/usr/sbin/apache2'
pi@raspberrypi:~ $
Lokonli
Post
by Lokonli » Saturday 19 January 2019 23:03
Lokonli
Post
by Lokonli » Saturday 19 January 2019 23:30
Lokonli wrote: Saturday 19 January 2019 23:03
and the output of
I guess the Apache php module is not installed. Try
sudo apt-get install libapache2-mod-php
And after that probably you have to set the right permissions:
chmod -R a+rX /home/pi/dashticz_v2
Derik
Post
by Derik » Sunday 20 January 2019 10:29
pi@raspberrypi:~ $ sudo apt-get install libapache2-mod-php
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
libapache2-mod-php is reeds de nieuwste versie (2:7.2+69+0~20181217103149.12+stretch~1.gbpfa617b).
0 opgewaardeerd, 0 nieuw ge▒nstalleerd, 0 te verwijderen en 0 niet opgewaardeerd.
pi@raspberrypi:~ $ sudo systemctl restart apache2
pi@raspberrypi:~ $
And:
pi@raspberrypi:~ $ php -v
PHP 7.2.13-1+0~20181207100540.13+stretch~1.gbpf57305 (cli) (built: Dec 7 2018 10:05:40) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.2.13-1+0~20181207100540.13+stretch~1.gbpf57305, Copyright (c) 1999-2018, by Zend Technologies
pi@raspberrypi:~ $
And is this for the whole map?
Lokonli
Post
by Lokonli » Sunday 20 January 2019 11:34
Derik wrote: Sunday 20 January 2019 10:29
pi@raspberrypi:~ $
And:
pi@raspberrypi:~ $
Let's find out in PM what goes wrong, and we'll post the solution afterwards here and on the Wiki.
Derik
Post
by Derik » Sunday 20 January 2019 22:55
Lokonli wrote: Sunday 20 January 2019 11:34
pi@raspberrypi:~ $
And:
pi@raspberrypi:~ $
Looks he is working now..
Thanks to lokonli
only i mis the returning events in my calendar?
Do have a combi agenda with three other in my master calender are the returning events missing..
Perhaps someone more?
And is there perhaps someone that have a CSS to edit the text in the calendars? Size and colors?
Thanks!!
Derik
Post
by Derik » Wednesday 23 January 2019 20:23
no one edit the text sizes?
Lokonli
Post
by Lokonli » Wednesday 23 January 2019 21:34
Derik wrote: Wednesday 23 January 2019 20:23
Add the following to custom.css:
.items {
font-size: 150%;
color: red;
Derik
Post
by Derik » Wednesday 23 January 2019 21:43
Lokonli wrote: Wednesday 23 January 2019 21:34
.items {
font-size: 150%;
color: red;
THANKS!!!!
Perhaps also a solution for the missing of returning events?
I used a combined calendar.
And in these calendars are returning events...
Only these events are missing in the dash?
They are visible in the calendar...
