Hi guys don't want to make new topic for +- same thing. I have Domoticz on OrangePI, and I have Broadlink RM3 an Logitech Z5500 audio system. I'm looking for some ready solution for volume dimming. Best way to have an slider/dimmer, something like light dimmer to change volume via RF by Broadlink.
As example, to make an range ware i=0 =mute, and i=100 = maximal loudness. And when you change slider as example for 10 points, it will send 10x times signal from Broadlink. Can some body help me with it?
Volume button
frompani
Re: Volume button
EDIT: forgot to say it work from 10 - 99 %
hi ,
like to share my solution ( i use alsamixer to set volume) :
virtual switch with slider (in my system : id=71)
on action run the script set_volume.sh:
pi@tana-rpi1:~/domoticz/scripts $ cat set_volume.sh
v=$(curl -s "http://192.168.10.181:8888/json.htm?typ ... d=71"|grep "Data"|rev |cut -d ":" -f1 |rev |cut -c2-3)
amixer -M sset 'PCM' $v%
hope this help someone
ciao
fab
hi ,
ciao
fab
- 2.jpg (198.32 KiB) Viewed 1874 times
- 1.jpg (120.09 KiB) Viewed 1874 times
