Yeelight - control from LUA
manjh
Domoticz version: 2025.2
Post by manjh »
I just received my first Yeelight RGBW lamp.
First step was to test from the Yeelight app in Android: works fine.
But being a Domoticz addict, I took it to the next level and installed the Yeelight hardware. Before I did this I set the developer mode in the lamp, assigned a static IP address, and enabled the Yeelight hardware line in Domoticz.
Sure enough after a little while a new device showed up. I set the status to "used", and found a neat new device in the switches. With this I can switch on/off, set the color, and dimlevel. Great.
But the next step was not so successful: I created a little LUA script from the Wiki page. Removed a few little glitches, until it ran OK (or at least without error messages).
Still, whatever I do from the matching dummy dimmers, the lamp does not respond at all.
Any hints?
Hans
manjh
Re: Yeelight - control from LUA
Post by manjh »
Anyone?
Hans
JimmyH1969
Post by JimmyH1969 »
I have the same lights so i'm gonna follow this one....
manjh
Post by manjh »
JimmyH1969 wrote: Friday 25 January 2019 10:44 I have the same lights so i'm gonna follow this one....
Just install the Yeelight HW line in Domoticz, and then after a few minutes check the devices tab. All yeelight devices that have been found must be enabled by clicking the green icon, after that a switch will show up and you can use the lamps directly or through a scene.
The problems that I found were in controlling from LUA.
Hans
Antikillerbm
Post by Antikillerbm »
I have same problem
I used lua one year but one week ago something happen and all my yeelight devices are not react to commands from lua events anymore
First I tried to interact with API trough node red - it works like before.
Second - I have downgraded my domoticz to release version - but still have same problem
Samael
Domoticz version: 4.9701
Post by Samael »
I faced with the same problem. This happened after some IP reconfiguration, so Yeelight devices in Domoticz got a new ID numbers. I deleted script and created a new one - only after that Domoticz began use a new ID of the lamp (changing the script did nothing).
Geitje
Post by Geitje »
Be also sure to enable "LAN control" in the Yeelight app. Use static IP's for your lights. For me the script is working right. I followed the description.
Zwave, Zigate, RFlink etc.
