Dashticz - Save option
Re: Dashticz - Save option
Still not working, the same error.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
I have just made a update to a last version, but the websettings still do not save.
- Domoticz version: 2022.2
Any news on this? I did chmod 777 the config file but still cannot save anything.
Maybe you are using it already, but I would advise to use the latest beta version of Dashticz.
First check whether Dashticz indeed finds PHP support: (only works on beta...)
If you press the settings-button (upper right) and then the 'Info' tab, Dashticz should report the PHP version that is being used.
If no PHP version is reported then first you have to fix the PHP installation. See the Wiki for some info:
https://www.domoticz.com/wiki/Dashticz_ ... structions
(don't forget to install the php-xml and php-curl modules)
In case the PHP version is reported correctly already, then try to save the settings. If this still doesn't work, look in the Apache error log.
(I assume you are running the Apache web server). Normally the location is /var/log/apache2/error.log
