Indentify tag id with the Zipato/beNext TagReader
- gijsje
- Domoticz version: Stable
Re: Indentify tag id with the Zipato/beNext TagReader
Is there already an update for the different rfid tags?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
DanM
bit late to reply... but i call it from lua when the tag reader is triggered.
- gijsje
Can you give me an example?
janpascal
Maybe it's a bit late, but here's what works for me to parse the OpenZwave log from a domoticz lua script and log
the tag number. You will need to change the Node003 part of the expression, probably need to change the
openzwave log file location and check if your log lines follow the same format.
You can remove the line if all is working and just use the last tag that has been set in your script (e.g. set a user variable or just log the tag number).
Hope this helps
Jan-Pascal
local zwave_log = "/var/lib/domoticz/OZW_Log.txt"
local event
local tag
for l in io.lines(zwave_log) do
_, _, event, tag = l.find(l, "Node003.*Received:.*0x06, 0x0(%d), 0x01, 0x(%x%x), 0x%x%x")
if tag ~= nil then
tag = tonumber(tag, 16)
domoticz.log('event: ' .. event .. '; tag: ' .. tag, domoticz.LOG_INFO)
domoticz.log(...)Hope this helps
Jan-Pascal
pimseb
- Domoticz version: 2020.1
janpascal I'd like to use your lua script to indentify who is using the tag on my zipato.
However my OZW_Log.txt doesn't say much about it :
The log makes you think it is a fail but domoticz receive indeed the information
Is there a level of lof to change somewhere inorder to see all the details "*Received:.*0x06, 0x0(%d), 0x01..." ?
Thank you
2019-03-17 17:25:05.333 Always, End of queued log message dump
2019-03-17 20:22:57.319 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-03-17 20:22:57.319 Always,
2019-03-17 20:22:57.319 Always, Dumping queued log messages
2019-03-17 20:22:57.319 Always, End of queued log message dump
Thank you
