renerene wrote: Saturday 26 January 2019 23:02
Can a purge function be added?
sure. It is already possible to do that by removing the data file. It will be recreated using the initial values, the next time the global_data script executes.
I use this routine now my main notification tool. Often there is a variable in the text ("temperature is..") which makes the index of the managedNotifications table unique, making the mute function not work for the same message type with another variable value. This is not a big issue. But I don't like the idea of the table building up with values that will be never looked after again.
Therefore: do a once per week purge of messages older than 30 days?
In below script, I added subject as a parameter. This does mean that your scripts calling this helper function need to be modified to insert the subject as 2nd parameter.
Extra's:
- using the subject "delete" will cause the managedNotify table entry with the index "message" to be removed
- using the subject "deleteAll"will cause all managedNotify table entries to be removed.
- managedNotify table entries for a message, created 30 days ago or earlier, will be removed when any new message will be added to this table
-- global_data.lua
data = {
managedNotifications = { initial = {}},
helpers = {
managedNotify = function (dz, subject,message, messageType, muteTimeMin,quietHours)
local now = os.time(os.date('*t')) -- seconds since 1/1/1970 00:00:01
muteTimeMin = muteTimeMin or 1
if subject == nil or string.lower(subject) == "delete" then
dz.globalData.managedNotifications[message] = nil
dz.log("message " .. message .. " on request deleted",dz.LOG_FORCE)
return 3
elseif string.lower(subject) == "deleteall" then
dz.globalData.managedNotifications = nil
dz.log("All messages on request deleted",dz.LOG_FORCE)
return 4
elseif ( not dz.globalData.managedNotifications[message] ) or
(( dz.globalData.managedNotifications[message] + muteTimeMin * 60 ) <= now ) then
if quietHours and dz.time.matchesRule("at " .. quietHours) then
dz.log("Quiet hours: no notification.")
return 1
dz.notify(subject, message,nil,nil,nil,messageType)
dz.globalData.managedNotifications[message] = now
local cleanupPeriod = 30 * 24 * 3600 -- 30 days
for key,timeStamp in pairs(dz.globalData.managedNotifications) do
if ( dz.globalData.managedNotifications[key] + cleanupPeriod ) < now then
dz.globalData.managedNotifications[key] = nil
dz.log("(Old) message " .. key .. " deleted",dz.LOG_FORCE)
return 0
-- No action required yet.
dz.log("Last '" .. message .. "' message was send at " ..
os.date("%A, %d %B %Y (%H:%M)",dz.globalData.managedNotifications[message]) ,dz.LOG_FORCE)
return 2
end,
-- managedNotify test script
on = { timer = { "every minute" }},
execute = function(dz)
-- 1st parm (dz) required
-- 2nd parm (subject) if nil or "deleted" then table entry for message will be removed
-- if "deleteAll" then all table entries will be removed
-- else required => notification subject
-- 3rd parm (message) required except when subject is "deleteAll"
-- 4th parm (notification subsystem) optional but required if any of the next parms in use (when nil defaults to all)
-- 5th parm (frequency in minutes) optional and defaults to 1 but required when using 6th parm.
-- 6th parm (quiet hours) optional
-- dz.helpers.managedNotify(dz, "testMessage_1", "first message", dz.NSS_PUSHOVER, 4)
-- dz.helpers.managedNotify(dz, "testMessage_2", "Next message", dz.NSS_TELEGRAM, 3)
-- dz.helpers.managedNotify(dz, "testMessage_3", "Third message", dz.NSS_GOOGLE_CLOUD_MESSAGING, 7, "10:59-11:15")
-- dz.helpers.managedNotify(dz, "testMessage_4", "4th message", dz.NSS_TELEGRAM, 1, "22:00-11:36")
-- dz.helpers.managedNotify(dz, "testMessage_5", "5th message", dz.NSS_TELEGRAM, 120 )
-- dz.helpers.managedNotify(dz, "testMessage_6", "6th message", nil, 15 )
-- dz.helpers.managedNotify(dz, "delete","6th message") -- the will remove table entry with key
-- dz.helpers.managedNotify(dz, "deleteAll") -- the will remove all notifications in table
dzVents wiki
