Not working Energy counter for Xiaomi smart socket on Zigate
pfloryann
- Domoticz version: 2026.2
Live energy it's working on Xiaomi smart socket...but do not working Energy Counter...it is remain 0 KW.
In attached image Counter is with red circle, same device with yellow and live energy with green
- domoticz.jpg (180.08 KiB) Viewed 1177 times
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Re: Not working Energy counter for Xiaomi smart socket on Zigate
Could you please provide the plugin version you are using ?
I'll have a look this evening at home where I have a Salus plug and a Xiaomi smartplug and are working correctly.
@pfloryann , thanks a lot for reporting that issue.
I've created an issue on Github https://github.com/sasu-drooz/Domoticz- ... issues/322
And it is now fixed.
If you update the plugin to Version 4.0.7 it should be back to normal
Just let me know
Just let me know
pfloryann
Yes is working now after plugin update. Thank you!
pfloryann
I tested today Energy counter...but the counter is not correct in Utility page...but in device log is correct energy counter. Please check
- domoticz2.jpg (210.21 KiB) Viewed 1140 times
version of Domoticz ? I'm on beta V4.10355 and have similar issue with an other Plug from Salus
pfloryann
I use 4.9700
Could you kindly open an issue on GitHub ?
We can track it: https://github.com/sasu-drooz/Domoticz-Zigate/issues
pfloryann
I created now on github
If you can test the latest version o fthe plugin against the beta branch ( git checkout beta) , I would be interested to have your feedbacks
pfloryann
I have tested with the beta version of plugin and with domoticz 4.1 and data counter is wrong, the counter show live energy does not calculate total consumption and in device log he storing the highest level power used.pipiche wrote: Friday 18 January 2019 13:20 If you can test the latest version o fthe plugin against the beta branch ( git checkout beta) , I would be interested to have your feedbacks
- domoticz3.jpg (307.7 KiB) Viewed 1093 times
Please could you check with Domoticz forum if it is not the expected behaviour as we are not doing anything fancy in the plugin except providing the instant consumption.
