alignment of text in a dummy text device
JuanUil
- Domoticz version: 4.11083
is there a way to change the alignment in a dummy text device in LUA?
I would also like to change the color of the text is that possible?
Thank you for any help
Juan
Juan
freijn
- Domoticz version: Stable
Re: alignment of text in a dummy text device
I believe the sensor does accept html format. try that.
JuanUil
and how do you do that in LUA?
sorry a newbie in programming
freijn
Try this in your " <font color="red">This is some text!</font>"
not sure thought... sorry..
- jvdz
- Domoticz version: 4.107
That indeed works fine.
JuanUil
So for instance
meldtekst= <font color="red">Dit is een melding</font>
should work?
this gives me a fault unexpeted symbol near <
should work?
- jvdz
That should be: meldtekst= '<font color="red">Dit is een melding</font>'JuanUil wrote: Sunday 13 January 2019 17:34 So for instance
should work?
Jos
JuanUil
No, not working.
Jos I use this in the afvalwijzer.
I now get the <fontcolor> in the text device
txt ='<font color="red">txt..web_afvaldate .. " = " .. web_afvaltype .. "\r\n"</font>'Your mind is like a parachute,
- jvdz
Yes, that won't work.
Try this version:
Jos
Try this version:
txt = txt..'<font color="red">'..web_afvaldate .. " = " .. web_afvaltype .. "</font>'\r\n"
JuanUil
nope, now I get
<font color="red">vr 18 jan = Plastic, Metaal en Drankkartons</font>' <font color="red">vr 18 jan = GFT</font>'Your mind is like a parachute,
- jvdz
I've just actually tried it with a text sensor and worked fine for me.
How does it look for you?
ps: I do see there is an single quote too many at the end, so the line should be:
Jos
txt = txt..'<font color="red">'..web_afvaldate .. " = " .. web_afvaltype .. "</font>\r\n"
JuanUil
Hoi Jos,
I now get in the TAB others the right format. but I also placed the textbox on my floorplan.
here I get So the alignment is crap and the color is not coming over.
JuanUil
no Idea why the textbox on the floorplan is different then in devices
- jvdz
I don't know either, I am not using àny floor plans, but guess the text isn't treated as regular HTML in the floorplan, unlike the Text sensor text display.
Maybe somebody knows.
JOs
JOs
JuanUil
Anybody who can help me further with this.
any help is very appreciated.
JuanUil
Nobody?
