alignment of text in a dummy text device
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
is there a way to change the alignment in a dummy text device in LUA?
I would also like to change the color of the text is that possible?
Thank you for any help
Juan
freijn
Domoticz version: Stable
Re: alignment of text in a dummy text device
Post by freijn »
I believe the sensor does accept html format. try that.
JuanUil
Post by JuanUil »
freijn wrote: Sunday 13 January 2019 17:02 I believe the sensor does accept html format. try that.
and how do you do that in LUA?
sorry a newbie in programming :o
freijn
Post by freijn »
Try this in your " <font color="red">This is some text!</font>"
not sure thought... sorry..
jvdz
Domoticz version: 4.107
Post by jvdz »
That indeed works fine. :)
JuanUil
Post by JuanUil »
So for instance
meldtekst= <font color="red">Dit is een melding</font>
should work?
this gives me a fault unexpeted symbol near <
jvdz
Post by jvdz »
JuanUil wrote: Sunday 13 January 2019 17:34 So for instance
should work?
That should be: meldtekst= '<font color="red">Dit is een melding</font>'
Jos
JuanUil
Post by JuanUil »
No, not working.
Jos I use this in the afvalwijzer.
I now get the <fontcolor> in the text device
txt ='<font color="red">txt..web_afvaldate .. " = " .. web_afvaltype .. "\r\n"</font>'
jvdz
Post by jvdz »
Yes, that won't work. ;)
Try this version:
                     txt = txt..'<font color="red">'..web_afvaldate .. " = " .. web_afvaltype .. "</font>'\r\n"
Jos
JuanUil
Post by JuanUil »
nope, now I get
<font color="red">vr 18 jan = Plastic, Metaal en Drankkartons</font>' <font color="red">vr 18 jan = GFT</font>'
jvdz
Post by jvdz »
I've just actually tried it with a text sensor and worked fine for me.
How does it look for you?
ps: I do see there is an single quote too many at the end, so the line should be:
                     txt = txt..'<font color="red">'..web_afvaldate .. " = " .. web_afvaltype .. "</font>\r\n"
Jos
JuanUil
Post by JuanUil »
Hoi Jos,
I now get in the TAB others the right format.
but I also placed the textbox on my floorplan.
here I get
So the alignment is crap and the color is not coming over.
JuanUil
Post by JuanUil »
no Idea why the textbox on the floorplan is different then in devices
jvdz
Post by jvdz »
I don't know either, I am not using àny floor plans, but guess the text isn't treated as regular HTML in the floorplan, unlike the Text sensor text display.
Maybe somebody knows.
JOs
JuanUil
Post by JuanUil »
Anybody who can help me further with this.
any help is very appreciated.
JuanUil
Post by JuanUil »
Nobody? :o :o
