script error 512
All kinds of 'OS' scripts
axel2906
Domoticz version: V3.8926
script error 512
Post by axel2906 »
I try to run a sh in domoticz but i've always an error :
Error: Error executing script command (/home/pi/domoticz/scripts/vacuum_cuisine.sh). returned: 512
this is my script
#!/bin/bash
mirobo --ip MYIP --token MYTOKEN zoned-clean [[26044,17953,30944,21153,1]]
i've already make a chmod 777 on this sh file
If i do ./vacuum_cuisine.sh in putty it works
somebody can maybe help me ?
RPi3 - RfxComm - Milight - OWL160
jvdz
Domoticz version: 4.107
Re: script error 512
Post by jvdz »
Probably a path issue. I normally use the fully qualified path like:
script:///home/pi/domoticz/scripts/vacuum_cuisine.sh
Also ensure the execute attribute is set for the script.
Jos
axel2906
Post by axel2906 »
jvdz wrote: Saturday 12 January 2019 13:27 Probably a path issue. I normally use the fully qualified path like:
Jos
I tried with script:///home/pi/domoticz/scripts/vacuum_cuisine.sh and set file permission to 777
but with same result
axel2906
Post by axel2906 »
I testing it in command line and i think that domoticz cannot execute this sh file
If I lauch it in the command line whis the pi user it works
i've made the domoticz user on the rpi3 and launch the same command and i have an error :
with domoticz user
with pi user
So wich user use Domoticz to launch bash files ? or is it an other way to do this ?
I've already set the chmod 777 on the file
axel2906
Post by axel2906 »
i've find the solution !
i must add to my sh script sudo -H -u pi
so script is
sudo -H -u pi mirobo --ip MYIP --token MYTOKEN zoned-clean [[26044,17953,30944,21153,1]]
