Ok.
Great you found the problem
Ok.
hkhk wrote: ↑Saturday 29 December 2018 13:15 Hi,
Have been running domoticz 4.9700 on ds1813+ (DSM 6.2.1) for long time and works fine except for the errors below when starting.
Starting Domoticz ...
insmod: ERROR: could not insert module /lib/modules/usbserial.ko: File exists
insmod: ERROR: could not insert module /lib/modules/ftdi_sio.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/cp210x.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/pl2303.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ch341.ko: File exists
insmod: ERROR: could not insert module /usr/local/domoticz/modules/ti_usb_3410_5052.ko: File exists
ln: failed to create symbolic link ‘/lib/udev/rules.d/60-synocommunity.domoticz.rules’: File exists
How do I fix that since cannot use USB/Serial port in domoticz now.
Are you sure you have installed the right domoticz version? If you have an old 6.1 version the drivers is not the same as 6.2.hkhk wrote: ↑Wednesday 16 January 2019 11:13 Hi,
Asked this question some time ago but no response.
Does that mean nobody knows or it is a known issue?
I could not find any hint to solve it.
I see the same message at every start. But they do not imply you cannot use your serial ports. They just say the files / symbolic links are already there.hkhk wrote: ↑Wednesday 16 January 2019 11:13 Hi,
I'm pretty sure I used 6.2 but to be 100% sure I installed again. Same messages though. Could not download beta because of connection issues.jumbotroll wrote: ↑Wednesday 16 January 2019 12:01Are you sure you have installed the right domoticz version? If you have an old 6.1 version the drivers is not the same as 6.2.hkhk wrote: ↑Wednesday 16 January 2019 11:13 Hi,
Try to reinstall domoticz for DSM6.2 and test the beta version.
http://www.jadahl.com/domoticz_beta_6.2 ... 0354-8.spk
There are not any another users that reported this problem using arch-cedarview..
Ok. But when in Hardware page, there are no serial ports to select from on a device. Or does the (USB)device need to be connected to the NAS before it boots?waaren wrote: ↑Wednesday 16 January 2019 12:22I see the same message at every start. But they do not imply you cannot use your serial ports. They just say the files / symbolic links are already there.hkhk wrote: ↑Wednesday 16 January 2019 11:13 Hi,
You give me very limited info.
Fixed it. Thanks for the feedback.jumbotroll wrote: ↑Wednesday 16 January 2019 21:13You give me very limited info.
What USB device are you trying?
Have you tried to reboot with the USB device connected?
Can you see the USB device in the info center on your synology?
Have you tested with the latest beta for arch-cedarview?
Because it was updated to new version to dayhkhk wrote: ↑Wednesday 16 January 2019 21:20 Downloading cedarview beta (http://www.jadahl.com/domoticz_beta_6.2 ... 0343-8.spk) causes a 404 error.
Try this Python 3 version: https://archive.synology.com/download/P ... 1-0104.spkOmeAnne wrote: ↑Thursday 17 January 2019 21:27 Hey there,
Got a DS216play running DSM 6.2.1-23824 and had an older version of Domoticz running. Wanted to upgrade to Domoticz Stable V4.9700 for DSM 6.2 with Python. (yes got monaco version)
Somehow the install didn't work So I uninstalled Domoticz....and then tried again. Yeah it worked.
But it does not run. Uninstalled phyton 3 uninstalled Domoticz. Tried version without Python. Yeah it worked and it runs! (ofcourse all of my previous stuff gone, it's okay I'll do it over and better).
Installed Phyton 3 again. Installed version with Python. Computer says no....it will not start. Can someone help me?
DS 212+ use arch-88f6282iMoi wrote: ↑Friday 18 January 2019 19:35 Hi there,
I'm a complete newbie to both Synology and Domoticz (but I'm familiar to Raspberry). I have a brand new DS212+ (DSM 6.2, more precision below) and just installed Domoticz. Unfortunately, when I try to launch it, it seems to do so, but stops and the status remains "Stopped". Even after rebooting the NAS, it keeps doing so. Any idea why ?
thanks a lot !
i-Moi
Information :
DS 212+ (INTEL Celeron J3355)
DSM 6.2.1-23824 Update 4
Domoticz (domoticz_apollolake-6.2_4.0.9700-7.spk) and node-mydomoathome-0.2.39.spk.
Thank you very much, I have a 213j and I just installed it without problems, now to install xiaomi vaccumjumbotroll wrote: ↑Saturday 05 January 2019 21:39 You find my packages here: http://www.jadahl.com
Beta packages is only manual update now. Download and install.
Try to do an update DS418 use arch-rtd1296 packages.
http://www.jadahl.com/domoticz_beta_6.2/
Always take backup of database (domoticz.db)Ectholian wrote: ↑Sunday 03 February 2019 9:02 What is the suggested way to update from the stable dsm to the beta (and vice versa)?
- backup config file
- backup database in domoricz just in case
- uninstall current package
- install new package
- restore config
- database should still be there configured?
Thank you. Now i need to wait patietly for the next beta build so I can use my Anna Thermostatjumbotroll wrote: ↑Sunday 03 February 2019 11:47Always take backup of database (domoticz.db)Ectholian wrote: ↑Sunday 03 February 2019 9:02 What is the suggested way to update from the stable dsm to the beta (and vice versa)?
- restore config
- database should still be there configured?![]()
Then you can download domoticz beta and update..
No need to reinstall.
Remember, you can't downgrade. If you want to use an older version (beta or stable), you have to uninstall/reininstall.
I can build a beta for you, what NAS do you have and for DSM 6.2 with or without python plugin?Ectholian wrote: ↑Sunday 03 February 2019 13:23Thank you. Now i need to wait patietly for the next beta build so I can use my Anna Thermostatjumbotroll wrote: ↑Sunday 03 February 2019 11:47Always take backup of database (domoticz.db)Ectholian wrote: ↑Sunday 03 February 2019 9:02 What is the suggested way to update from the stable dsm to the beta (and vice versa)?
- restore config
Remember, you can't downgrade. If you want to use an older version (beta or stable), you have to uninstall/reininstall.![]()
