ZXT-120
- gizmocuz
Re: ZXT-120
No it does not work, this device needs thermostat state changes to control it, and this is not yet implemented
Thermostat Command Classes: (not supported)
- Thermostat Mode Command Class
- Thermostat Fan Mode Command Class
- Thermostat Set‐point Command Class
Mgros
Re: ZXT-120
FR
Bonjour
Je comptais acheter le ZXT120 avec un clée USB ZWAVE.
Etes vous sur de la non compatibilité car dans le dossier config il y a bien un fichier xml .... domoticz/config/remotec/zxt-120.xml
ENG
Hello
I intended to buy the ZXT120 with USB ZWAVE key.
Are you sure about the compatibility ... because in the config file there is a good xml file ?.... domoticz/config/REMOTEC/zxt-120.xml
Bonjour
ENG
Hello
mickeys
Re: ZXT-120
hello
FR
Je viens d acheter le ZXT-120
il est bien reconnu dans domoticz , par contre une fois reconnu je ne sais pas comment le configurer
ENG
I Have ZXT-120 and i installed this module in domoticz
domoticz recognized my ZXT-120
how to configure the module once recognized ?
thank
FR
ENG
thank
mickeys
Re: ZXT-120
Hello
i search a config file for ZXT-120 please
how to create a paramaters with Command Class
cordialement
cordialement
mickeys
Re: ZXT-120
i find a class ThermostatFanMode: public CommandClass in domoticzThermostat Command Classes: (not supported)
mickeys
Re: ZXT-120
hey
How to configure different commandClass in domoticz or what file need modify please
I have 2 devices Zwave thermostat
if I click the button (Download configuration file)
i have :
i have :
<?xml version="1.0" encoding="UTF-8"?>
-<Driver poll_interval_between="0" poll_interval="60000" controller_capabilities="28" api_capabilities="8" node_id="1" home_id="0x014d0cc7" version="3" xmlns="http://code.google.com/p/open-zwave/">
-<Node version="3" query_stage="Complete" max_baud_rate="40000" routing="false" beaming="true" frequentListening="false" listening="false" type="Controller" specific="1" generic="2" basic="1" location="" name="" id="1">
-<Manufacturer name="Aeon Labs" id="0086">
<Product type="0002" name="Z-Stick S2" id="0001"/>
</Manufacturer>
-<CommandClasses>
-<CommandClass version="1" name="COMMAND_CLASS_WAKE_UP" id="132" request_flags="2">
<Instance index="1"/>
</CommandClass>
</CommandClasses>
</Node>
-<Node version="4" query_stage="Complete" max_baud_rate="40000" routing="true" beaming="true" frequentListening="true" listening="false" type="General Thermostat V2" specific="6" generic="8" basic="4" location="" name="" id="7">
-<Manufacturer name="Remotec" id="5254">
<Product type="0101" name="ZXT-120" id="8377"/>
</Manufacturer>
-<CommandClasses>
-<CommandClass version="1" name="COMMAND_CLASS_BASIC" id="32" request_flags="4" mapping="64">
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_SWITCH_ALL" id="39" request_flags="4">
-<Value type="list" index="0" size="1" vindex="0" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Switch All" instance="1" genre="system">
<Item label="Disabled" value="0"/>
<Item label="Off Enabled" value="1"/>
<Item label="On Enabled" value="2"/>
<Item label="On and Off Enabled" value="255"/>
</Value>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_SENSOR_MULTILEVEL" id="49">
<Value type="decimal" index="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="C" label="Temperature" instance="1" genre="user" value="24"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_THERMOSTAT_MODE" id="64" request_flags="4">
-<Value type="list" index="0" size="1" vindex="0" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Mode" instance="1" genre="user">
<Item label="Off" value="0"/>
<Item label="Heat" value="1"/>
<Item label="Cool" value="2"/>
<Item label="Resume" value="5"/>
<Item label="Fan Only" value="6"/>
<Item label="Dry Air" value="8"/>
<Item label="Auto Changeover" value="10"/>
</Value>
-<SupportedModes>
<Mode index="0" label="Off"/>
<Mode index="1" label="Heat"/>
<Mode index="2" label="Cool"/>
<Mode index="5" label="Resume"/>
<Mode index="6" label="Fan Only"/>
<Mode index="8" label="Dry Air"/>
<Mode index="10" label="Auto Changeover"/>
</SupportedModes>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_THERMOSTAT_SETPOINT" id="67" request_flags="4" base="0">
<Value type="decimal" index="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="C" label="Heating 1" instance="1" genre="user" value="28"/>
<Value type="decimal" index="2" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="C" label="Cooling 1" instance="1" genre="user" value="25"/>
<Value type="decimal" index="6" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="C" label="Unused 6" instance="1" genre="user" value="0.0"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_THERMOSTAT_FAN_MODE" id="68" request_flags="4">
-<Value type="list" index="0" size="1" vindex="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="false" units="" label="Fan Mode" instance="1" genre="user">
<Item label="Auto Low" value="0"/>
<Item label="On Low" value="1"/>
<Item label="Auto High" value="2"/>
<Item label="On High" value="3"/>
<Item label="Unknown 4" value="4"/>
<Item label="Unknown 5" value="5"/>
</Value>
-<SupportedModes>
<Mode index="0" label="Auto Low"/>
<Mode index="1" label="On Low"/>
<Mode index="2" label="Auto High"/>
<Mode index="3" label="On High"/>
<Mode index="4" label="Unknown 4"/>
<Mode index="5" label="Unknown 5"/>
</SupportedModes>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_CONFIGURATION" id="112" request_flags="4">
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" id="114" request_flags="4">
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_BATTERY" id="128" request_flags="4">
<Value type="byte" index="0" max="255" min="0" poll_intensity="2" verify_changes="false" write_only="false" read_only="true" units="%" label="Battery Level" instance="1" genre="user" value="95"/>
</CommandClass>
-<CommandClass version="1" name="COMMAND_CLASS_VERSION" id="134" request_flags="4">
<Value type="string" index="0" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Library Version" instance="1" genre="system" value="6"/>
<Value type="string" index="1" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Protocol Version" instance="1" genre="system" value="3.42"/>
<Value type="string" index="2" max="0" min="0" poll_intensity="0" verify_changes="false" write_only="false" read_only="true" units="" label="Application Version" instance="1" genre="system" value="1.07"/>
</CommandClass>
</CommandClasses>
</Node>
</Driver>-
mickeys
Re: ZXT-120
it is planned in the domoticz development ?
maximilien72
Re: ZXT-120
avez vous des rpeonses je posssede un remotec zxt 120 comment le faire marcher dans domoticz ?
maximilien72
Re: ZXT-120
when zxt-120 remotec will be work in domoticz please emmergency
Raspberry Piet
Re: ZXT-120
Call 112maximilien72 wrote:when zxt-120 remotec will be work in domoticz please emmergency
- mbliek
Re: ZXT-120
Haha like this reaction.Raspberry Piet wrote:Call 112maximilien72 wrote:when zxt-120 remotec will be work in domoticz please emmergency
Op zoek naar een Domoticz Start Set?
maximilien72
Re: ZXT-120
hello I call 911 he told me to go fuck myself! good without laughter is actually how the REMOTEC zxt 120 domoticz full of people asking the question please guys
Raspberry Piet
Re: ZXT-120
maximilien72 wrote:hello I call 911 he told me to go fuck myself!
Somebody allready asked for implementation:maximilien72 wrote:good without laughter is actually how the REMOTEC zxt 120 domoticz full of people asking the question please guys
http://www.domoticz.com/forum/tracker.php?p=2&t=277
It is seen by Gizmocuz, just be patient don't chase.
Can't believe there is any emergency at all.
- gizmocuz
Re: ZXT-120
In version #2122:
Implemented:
- COMMAND_CLASS_THERMOSTAT_MODE
- COMMAND_CLASS_THERMOSTAT_FAN_MODE
Also updated the ZXT-120 configuration file
After the update:
- stop domoticz (from the ssh shell)
- Edit the file Config/zwcfw_xxxxxx.xml) remove all ZXT-120 nodes, be carefull here
- If the above step is to complex, you can also delete this file, but you might need to wakeup all your nodes to get all information correct
- start domoticz (from the ssh shell)
- wait at least 10 minutes, or until you see the log message 'all awake nodes queried'
You should now get the THERMOSTAT_MODE and THERMOSTAT_FAN_MODE devices in the devices tab, and you can add them to the system.
Also you should now be able to configure the device ! (set right IR code etc)
I have a device on 'loan' (thanks bdw!), and did not connect it to an actual FAN, but it seems to be working alright
(Update is building and takes at least an hour....pffff)
Hope all works well ! It took a lot of time/effort to build/support this
Implemented:
After the update:
bourrin
Re: ZXT-120
I have test the ZXT 120. It works in the interface but not in lua script.
Here are the log ( print from the demo script )
Mon Nov 17 23:19:00 2014 LUA: Unknown
Mon Nov 17 23:19:00 2014 LUA: Cool Salon
Mon Nov 17 23:19:00 2014 LUA: Heat Salon
Mon Nov 17 23:19:00 2014 LUA: Mode Salon
Mon Nov 17 23:19:00 2014 LUA: Salon
Mon Nov 17 23:19:00 2014 LUA: otherdevices_svalues
Mon Nov 17 23:19:00 2014 LUA: Fan Salon
Mon Nov 17 23:19:00 2014 LUA: 0.00
Mon Nov 17 23:19:00 2014 LUA: 22.0
Here are the values in devices menu
81 Zwave Network 0000D06 1 Unknown Thermostat SetPoint 0.0 12 - Add Device Log 2014-11-17 18:39:38
80 Zwave Network 0000D04 1 Unknown Thermostat SetPoint 0.0 12 - Add Device Log 2014-11-17 18:39:38
79 Zwave Network 3329 1 Salon Temp TFA 30.3133 22.0 C 12 90 Remove Device Log 2014-11-17 18:40:01
78 Zwave Network 00000D01 1 Fan Salon General Thermostat Fan Mode Auto High 12 - Remove Device 2014-11-17 18:40:04
75 Zwave Network 0000D02 1 Cool Salon Thermostat SetPoint 25.0 12 - Remove Device Log 2014-11-17 18:39:38
74 Zwave Network 0000D01 1 Heat Salon Thermostat SetPoint 21.0 12 - Remove Device Log 2014-11-17 18:39:38
73 Zwave Network 00000D01 1 Mode Salon General Thermostat Mode Heat 12 - Remove Device 2014-11-17 18:40:03
I can't get the right values and the command commandArray['Mode Salon']='Off' does not work.
Does someone have an idea ?
mlopez2192
Re: ZXT-120
Thanks gizmocuz for your time and effort in making possible to support ZXT-120.
I have a ZXT-120 with firmware 1.6E, on Domoticz-win32-2_2139.
There is mistake in the configuration tab for ZXT-120 the parameter 33, says Sourround IR control and is AC function swing control.
The AC controlled is FUJITSU, the parameter 27 was 16, so at first try this work for me.
I can start the AC at predefined time using for example the heat set point timer, but I can't find a way to stop (Off) the AC at a predefined time.
I must do it manual from the Utilities tab, Thermostat Mode, Edit option, drop down menu option Off and click in update.
Is there a way to have a timer in Thermostat Mode with the options that are available now and make a predefined time for Off AC?
For example something like: (File attached)
Thanks.
Thanks.
- Have a timer in Thermostat Mode
- Thermostat_Mode1.jpg (253.36 KiB) Viewed 11130 times
bourrin
Re: ZXT-120
I have the same problem, ZXT120 work manualy, but don't in blockly or LUA script.
bourrin
Re: ZXT-120
I try to build a scene but no parts of the zxt120 appears in device list.
Christian
Re: ZXT-120
Same problem for me, how can I use zxt120 in lua script ? (It don't appear in blockly)
I only need to manage Off, Heat and Cool by script. The script will make the regulation based on a temp. sensor.
do you get some news?
thanks in advance for help
RPI B (Domoticz slave + Razberry + RFXComUSB) + 1 RPI model 2 (Domoticz master) + 2 RPI B+ (Openelec)
5 THGR122+THWR800 + 3 OWL180
Oregon Rain + wind + UV meters
FGBS001 + FGMS001
3 blinds BLYSS + 3 blinds Fibaro + 14 switches+ 2 dimers
2 remotec ZXT120
FGBS001 + FGMS001
2 remotec ZXT120
