Restore database via curl
All kinds of 'OS' scripts
survivor182ca
Post by survivor182ca »
We can do a backup via curl script easily :
/usr/bin/curl -s http://127.0.0.1:8080/backupdatabase.php > /var/tmp/domoticz_backup/$BACKUPFILE
My question is : can we do database restore via curl command???
Thank in advance!
Re: Restore database via curl
survivor182ca wrote: Tuesday 08 January 2019 19:03 Hi,
Thank in advance!
Not using the http://127.0.0.1:8080 This is pointing to an active domoticz.
If you would setup another server on your system like with
cd /var/tmp/domoticz_backup
sudo python -m SimpleHTTPServer 8081
You could then use (from another window)
cd domoticzdir
sudo curl -o domoticz.db2 localhost:8081/$BACKUPFILE
#db2 to ensure you do not overwrite your database by accident
but why ? Why not simply use
cd domoticzdir
sudo cp /var/tmp/domoticz_backup/$BACKUPFILE  domoticz.db2
survivor182ca
I want the curl restore because I run Domoticz on OpenWRT router and the database is always empty when the process starts.
Also the database is stored on the temporary drive /tmp/ ... this is why the database is empty at starts
I could run a CRON job that just restore my database every day if a curl command exist.
Copying the database to the path when the process is started does not work =(
