We can do a backup via curl script easily :
/usr/bin/curl -s http://127.0.0.1:8080/backupdatabase.php > /var/tmp/domoticz_backup/$BACKUPFILE
Thank in advance!
Not using the http://127.0.0.1:8080 This is pointing to an active domoticz.survivor182ca wrote: ↑Tuesday 08 January 2019 19:03 Hi,
We can do a backup via curl script easily :My question is : can we do database restore via curl command???Code: Select all
Thank in advance!
cd /var/tmp/domoticz_backup
sudo python -m SimpleHTTPServer 8081
cd domoticzdir
sudo curl -o domoticz.db2 localhost:8081/$BACKUPFILE
#db2 to ensure you do not overwrite your database by accident
cd domoticzdir
sudo cp /var/tmp/domoticz_backup/$BACKUPFILE domoticz.db2
