I'll try to look at this post more often now .
Désolé pour ma "non réponse" je ne recois aucune notif du forum depuis quelques temps....
S'il faut faire des tests ou aider j'essaierai de passer plus régulièrement
Hi tixi7! Sorry for the very late reply. It was a stupid mistake with the wifi net that I was using.tixi7 wrote: Saturday 13 October 2018 16:21 Can you provide more details:
- the plugin: plug or bulb?
- the version of the plugin, since the post I patch the bulb plugin to avoid a similar behavior
- some logs information
- device informations,
Can you try with the latest stable version of domoticz? I observe that some beta version causes problems: a bug report for domoticz is on my todo list.
jslegers, for sure the plugin is not define for it and i don't know if the library can get it or not. Can you send me the result of the script get_dps.py.
pi@domoticz:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ ./get_dps.py 192.168.1.126 00621010cc50e3c3d408
A problem occur please retry...I've read all this thread. It mention something related to the firmware version. In my case both MCU & Wifi firmware are always the same, as follows:tixi7 wrote: Sunday 30 December 2018 19:52 Thanks, but it is not a bug.
Unfortunately this is mandatory to not disconnect the connection between the device and the plugin to avoid unexpected behavior for some tuya devices.
You can have a look at this thread: https://github.com/codetheweb/tuyapi/issues/84
Moreover, have in mind that only one connection is possible. That's why it is not possible to have the tuya app running and the domoticz plugin. And the same for Alexa. A way to handle it is to use Alexa with domoticz.
I've compared the code for the Tuya-SmartBulb plugin.py and the SmartPlug. It looks to me the Bulb one is not updated. I wonder if when the persistent socket issue was discovered, the SmartBulb code was also updated?jordipalet wrote: Sunday 30 December 2018 20:33I've read all this thread. It mention something related to the firmware version. In my case both MCU & Wifi firmware are always the same, as follows:tixi7 wrote: Sunday 30 December 2018 19:52 Thanks, but it is not a bug.
- Smart Plug: 1.0.0 - it works both with Alexa and Domoticz, no issues after several hours testing
- Switch module: 1.0.3 - same as above, no issues at all
- Dimmer module: 1.0.0 - it work fine with Alexa or Domoticz, but not with both.
So I really wonder if the persistent socket is needed, if both the smart plug and the switch module are working fine.
I have followed the steps but the app gives an network error when trying to refresh the devices.tixi7 wrote: Thursday 20 December 2018 21:05 Can you try to extract the devID with this method:
https://github.com/codetheweb/tuyapi/bl ... s/SETUP.md
To be sure you have the correct information.
Users browsing this forum: fdemees and 1 guest
