deCONZ plugin not updating status or switches
matrixus
Post by matrixus »
I'm running deCONZ plugin successfully agains a deconz docker with Connbee stick. I can turn off or on lights both through Phosconn webapp (PWA) as well as Domoticz. However if I turn off a light through the Phosconn app the state of the light is not updated in Domoticz. I can turn on the same light by first turning it off again in Domoticz despite it already off and then turn on again.
I also have two different Xiaomi zigbee switches as well as Trådfri switch and motion sensor. They all work well in Phosconn but I don't receive any status update in Domoticz if I click a switch, not even from Xiamo ones. It also doens't matter if a switch is added to a group or not in PWA...
I tried to enable all debugging for deconz plugin but don't see any state change or anything at all when I click a switch nor does "learn a switch" work. The switches and all the lights are otherwise created in Domoticz.
Plugin updated today from Git and Docker running latest deconz (2.05.52 / 2018-12-16). Domoticz docker is Version: 4.10301
Any ideas?
ivarka
Re: deCONZ plugin not updating status or switches
Post by ivarka »
Are you using the correct websocket port?
matrixus
Post by matrixus »
ivarka wrote: Sunday 30 December 2018 9:25 Are you using the correct websocket port?
No I was not. :o
Did: GET /api/<apikey>/config
And sure enough the websocket port was different from the plugin settings. Now it seems to work and I can see updates in the log when I change state. Thanks :D
